Calculating 2nd and 3rd Resonant Lengths
  • Thread starter Thread starter soulja101
    Resonant
The second and third resonant lengths of a closed air column, given that the first resonant length is 30.0 cm, are calculated as 90.0 cm and 150.0 cm, respectively. The calculations are based on the relationship that the resonant lengths correspond to odd multiples of the fundamental frequency, specifically using the formula for closed air columns where the wavelength is four times the length of the column. The wavelength for the first resonant length is determined to be 120 cm, which is essential for understanding the subsequent resonant lengths.
  • Understanding of wave mechanics and resonance
  • Knowledge of closed air column properties
  • Familiarity with the concept of nodes and antinodes
  • Basic algebra for manipulating equations
  • Study the properties of standing waves in closed and open air columns
  • Learn about the harmonic series in wave physics
  • Explore the mathematical derivation of resonant frequencies
  • Investigate the applications of resonance in musical instruments
Students studying physics, particularly those focusing on wave mechanics, as well as educators and anyone interested in the principles of sound resonance in closed air columns.
soulja101
The 1st rensonat length of a closed air column occurs when the length is 30.0cm. what will the send ond and third be?
I did the pattern thign like 3/4 but i got the wrong answer.
i multplied the legth 3/4 but i got the wrong answer.
Second = 30.0*3=90.0 (cm)
Third= 30.0*5 = 150.0(cm)
u can draw graphs to know why.
A node is situated at the closed end an antinode at the open end. The "smallest structure" of the wavelength that can accommodate this is a quarter wavelength.Which means that the wavelength is 120 cm. The next waveform will be three quarters of a wavelength (again a node at the closed end and an antinode at the open end).
  • · Replies 33 ·
