Trigonometric functions of the unit cirlce
The discussion centers on calculating the cosecant (csc) of the angle t = -2π/3 radians, which is equivalent to -120 degrees. The user initially calculated csc(-2π/3) as -2√3/3, while the textbook provided the answer as -2√3/2. The user correctly identified that the sine of -2π/3 is -√3/2, leading to the conclusion that the cosecant should indeed be the reciprocal of sine, resulting in -2√3/3. The discrepancy indicates an error in the textbook.
  • Understanding of trigonometric functions, specifically cosecant and sine.
  • Knowledge of angle conversion between radians and degrees.
  • Familiarity with the unit circle and its properties.
  • Basic algebra skills for manipulating square roots and fractions.
  • Review the properties of trigonometric functions on the unit circle.
  • Practice calculating cosecant values for various angles in radians.
  • Explore common errors in trigonometric calculations and how to avoid them.
  • Study the relationship between sine and cosecant in greater detail.
Students studying trigonometry, educators teaching trigonometric functions, and anyone seeking to clarify misconceptions about cosecant and sine calculations.
AznBoi
I just came across a problem that wants you to solve for csc of an angle in radians... However, I'm confused about the answer given.
Here is the problem:
Find the csc when t=-2pi/3, which is equivalent to -120 degrees right?
I got -2sqrt.(3)/3 but the answer in the back is -2sqrt.(3)/2 Why is it a 2 instead of a three??
The sin is -sqrt.(3)/2 and it is correct, so shouldn't the csc be the reciprocal of sin?? 1/sin theta?? so 1/(-2sqrt.(3)/3)?
Thanks!
Your book is wrong. [tex]cosec(\frac{-2\pi}{3}) = \frac{-2\sqrt{3}}{3}[/tex]
wow... I think I've actually seen quite a few with 2's as the denominator. I'm pretty sure that I was right and the book was wrong. I'm astonished though, this book sucks! =/
Thanks for helping me check btw! =]
  • · Replies 28 ·
