Brain Teaser that is impossibly solvable
  • Context: High School
  • Thread starter Thread starter kinnabird5
    Brain
The discussion revolves around a brain teaser involving a geometric problem where participants must determine if a continuous line can be drawn through all sides of a specified arrangement of rectangles without overlapping or retracing any side. The scope includes mathematical reasoning and exploration of graph theory concepts.
  • Some participants describe the problem as potentially impossible based on the configuration of sides and rectangles, noting that odd-numbered sides complicate the ability to draw a continuous line.
  • Others propose that if the problem allows for a continuous curve rather than a strict line, it may be solvable, though this interpretation is contested.
  • One participant suggests that alternative methods, such as "punching holes" in the paper, could provide a solution, although this is challenged by others who insist on a strict interpretation of the problem.
  • Several participants engage in a detailed analysis of the degrees of vertices in the graph representation of the problem, referencing Euler paths and the conditions for their existence.
  • There are claims that the problem resembles classic problems in graph theory, such as the Bridges of Königsberg, and discussions about the implications of these similarities.
  • Some participants express frustration over the lack of clarity in the problem's phrasing and the resulting ambiguities that affect the solvability discussion.
  • A later reply emphasizes that a more liberal interpretation of the problem might lead to a solution, suggesting that assumptions made by earlier participants could be limiting.
Participants do not reach a consensus on the solvability of the problem. There are multiple competing views regarding the interpretation of the problem and the implications of graph theory on its solution.
Limitations include the ambiguity in the problem's phrasing, the definitions of a line versus a continuous curve, and the assumptions about intersections and sides. The discussion also highlights the dependence on the specific arrangement of rectangles and the mathematical properties of the shapes involved.
Readers interested in mathematical puzzles, graph theory, and geometric reasoning may find this discussion relevant and engaging.
  • #61
can we enter a line, then trace along it for a while without having "crossed it twice"
Mathematics news on Phys.org
  • #62
___________
|_____|_____|
|__|_____|__|
This is basically what the image looks like, and yes it is impossible. If you look, you'll see any rectangle has either 4 or 5 sides (even or odd). Now if you were to start inside an odd one, you eventually would have to end up on the outside and if there were two odd box's it would be fine but there are three... it's hard to explain, but it's impossible. I actually devised a way to find out whether or not a puzzle like this is impossible or possible. First add up all the rectangles with even "doorways" and odd ones. Cancel every even with every even, and every odd with every odd. I found that's it's not possible if you end up with an odd. It's possible: if they all cancel out, if you have a remaining even. However there is a special case if you end up with 1 even and 1 odd; If you have an odd amount of odds (3, 5, 7...) then it's not possible, But it is for 1.
As I read over that, it's a little difficult to understand, read it carefully.
So if we look at the original we see that we have 3 odds and 2 evens:
o oo ee . The paired ones cancel out so we have an o remaining. If you look back at my list, a remaining odd is...Not Possible, hence the puzzle is unsolvable.
Note: I haven't showed this mathematically, I made puzzle types a bunch of times and tried them, the ones that weren't possible and the ones that were possible had the same properties, that's what this is based upon. You can try it yourself.
  • #63
Yea i was thinking that too, can the line trace a lot the sides abit, then it will be simple.
  • #64
the rules
you can go over a line one time
you can't go along a line
you can start in the middle or outside
you can have a straight line or a curved line
you can't cut or go through corners
  • #65
Brainteasercool said:
the rules
With those rules, the problem has been shown (many times in this thread) to be insoluble.
  • #66
this seems to be impossible because first of all there is an even number of lines to cross for one line to go through and second of all i have made a NOTEBOOK of individual papers that have front and back non repetitive attempts...i lie to you not this is impossible...i have lost time trying to figure this out on a state high school test that determines if i pass high school! (Breathing hard like a maniac while saying that) ... ... yes I am okay but i tell you with confidence for all who read this that it is impossible
  • #67
Wow... you really haven't read the earlier posts in this thread have you? :rolleyes:
  • #68
fun, will insert another quarter :(
  • #69
i think this one is right?
  • #70
Nope... you missed a side. It is impossible!
  • #71
i have a new one with all lines but it adds up to 17? maybe unsolvable
  • #72
I'd second that.
  • #73
Why doesn't someone make a computer program to see if its solvable? might be easier and it could do calculations or attempts hundreds of times faster than us.
  • #74
Because that would be entirely pointless, for as it has been said numerous times in this thread it is simply not possible.
  • #75
This thing is like crack cocaine! I don't know what its called so I just call it Mind Crack. I've been doing this puzzle for about 6 months now and haven't figured it out. It was shown to me by a neighbor who says he's seen the answer but had been done on a computer. Whether that's true or not I do not know. Seeing as he's an alcoholic but still. If anyone has the true answer. Quit hiding it and reveil it! Because I am sure there is otehr people out there that are craving to know the answer!
...Mind Crack
  • #76
...Mind Crack
Why don't you read the n posts above telling you that this is impossible! There's a proof of this in one of the early replies.
  • #77
Icarus said:
I've removed my posting of the solution so that anyone who wants to follow up on baffledMatt's excellent insight will have a chance to do so!
i want to see your solution...
  • #78
i want to see your soltution to this problem.i have been trying for 2 years and still can not seem to find any answer
  • #79
As has been said many, many times before (and proven once), this problem has no solutions. Therefore, it serves no purpose to continue to seek solutions to this problem and hence any discussion on the topic is also useless.
Thread closed.
  • · Replies 23 ·
  • · Replies 179 ·
29K
  • · Replies 42 ·
