Are You Ready to Challenge Your Integral Solving Skills?
  • Context: Undergrad
  • Thread starter Thread starter Gib Z
    Integrals
The thread revolves around participants sharing and solving indefinite integrals, with varying levels of difficulty. The discussion includes requests for integrals, attempts at solving them, and exchanges of hints and strategies for integration techniques.
  • Homework-related
  • One participant requests a variety of indefinite integrals to assess their skills and learn from the community.
  • Another participant suggests starting with the integral of sqrt(tan(x)).
  • A different integral involving sin(x) is proposed, leading to expressions of confusion from some participants.
  • Several participants express difficulty with the proposed integrals and seek guidance on substitution methods.
  • Hints are provided, including suggestions for substitutions like u = tan(x) and changes of bounds to simplify integrals.
  • Participants discuss the use of integration by parts and hyperbolic substitutions, with varying levels of understanding and confidence.
  • There are corrections and clarifications regarding differentiation and integration techniques, highlighting misunderstandings among participants.
  • Some participants express frustration or confusion over the complexity of the integrals and the solutions provided.
There is no clear consensus on the best approach to solving the integrals, with multiple competing views and methods suggested. Participants express varying levels of understanding and confidence, leading to a mix of agreement and confusion.
Participants demonstrate uncertainty regarding the application of integration techniques and the correctness of their approaches. Some mathematical steps remain unresolved, and there are dependencies on specific substitutions that may not be universally understood.
  • #31
hmm ill be up hours tonight doing that :D ty NTUENG
  • #32
Gib Z said:
Umm ok I am having numerous troubles with the sqrt tan x one, I am giving up..ill get back to it later when i get better..As to the one Hootenanny gave me, if i try the suggestion let z= tan x/2, i need help expressing (sin [x/2])^2 in terms of z, if someone can do that ill be able to keep on going..
EDIT: umm help with doing the same with cos instead of sin would be ok as well.
Check reply #17 and #25 of where I gave the hint of sqrt(tanx) problem.
  • #33
cristo said:
I don't think a trig sub will work. Try writing the denominator as [itex](u^2-\sqrt 2u+1)(u^2+\sqrt 2u+1)[/itex], then use partial fractions. It should work, but it won't be pretty!
Yes, partial fractions will definitely work. The original integral is [tex]\int \sqrt{\tan x} dx[/tex]. After letting tan x = u², u convert it to [tex]2\int \frac{u^2}{1+u^4} du[/tex]. Complete the square at the bottom to get (u²+1)²-2u² = [tex](u^2-u\sqrt{2}+1)(u^2+u\sqrt{2}+1)[/tex]. Your integral becomes [tex]\int \frac{u^2}{(u^2-u\sqrt{2}+1)(u^2+u\sqrt{2}+1)} du[/tex]. By partial fractions, [tex]\frac{u^2}{(u^2-u\sqrt{2}+1)(u^2+u\sqrt{2}+1)} = \frac{Au+B}{u^2+u\sqrt{2}+1} + \frac{Cu+D}{u^2-u\sqrt{2}+1}[/tex]. Compare coefficients on both sides to get A=[tex]-\frac{1}{2\sqrt{2}}[/tex], C=[tex]\frac{1}{2\sqrt{2}}[/tex] and B=D=0. After that, manipulate the integral by factorization, completing the square and expressing the result in terms of ln and [tex]\tan^{-1}[/tex], finally u get the answer [tex]\frac{\sqrt{2}}{8} ln \frac{u^2-u\sqrt{2}+1}{u^2+u\sqrt{2}+1} + \frac{\sqrt{2}}{4} \tan^{-1} (u\sqrt{2}-1) - \tan^{-1} (u\sqrt{2}+1) + C[/tex]. The last step is to convert u back to original variable x using the relation u² = tan x and u get your answer in terms of x.
Haha, isn't that a good solution ??!
  • #34
Thats really good, thanks for that. For the partial fractions one, I actually managed to get A and C before, but I could only reduce it to B+D=0, I couldn't acutally get the values themselves. You could explain how you got that one?
Even if I did get B and D, What steps did you do to get to the next result? I have no idea...sorry about that.
  • #35
As for ssd's let's z= sin x - cos x...i can't see how to manipulate your expression for that to help me..
  • #36
Ok when u multiply the partial fraction identity by their common denominator, u get [tex]u^2 = (A+C)u^3 + (B+D+(C-A)\sqrt{2})u^2 + (A+C+(D-B)\sqrt{2})u + B + D[/tex]. Compare coefficients of descending powers of u, u get A+C =0, B+D+(C-A)[tex]\sqrt{2}[/tex]=1, A+C+(D-B)[tex]\sqrt{2}[/tex]=0 and B+D=0. Sub. eqn 1 into eqn 3, u get (D-B)[tex]\sqrt{2}[/tex]=0. Thus D-B must be 0. B=D=0. (shown!)
For the next part, u use the values of A,B,C and D to express the integral as partial fractions. The resultant integral is [tex]\int \frac{-\frac{u}{2\sqrt{2}}}{u^2+u\sqrt{2}+1} + \frac{\frac{u}{2\sqrt{2}}}{u^2-u\sqrt{2}+1} du[/tex]. U can factor out the constant [tex]\frac{1}{2\sqrt{2}}[/tex]. After that, try to make the top a derivative of the bottom into the form f'(u)/f(u) where the result is in terms of ln function. For the denominator, u need to complete the square and u get integral of the form [tex]\int \frac{du}{u^2+a^2}[/tex] where the result is in terms of [tex]\tan^{-1}[/tex] function. Rationalise all the terms with surds at the bottom and use identity ln a - ln b= ln(a/b) to combine the 2 ln terms together. U'll eventually get the answer in thread #33.
  • #37
Write sqrt(tanx) = sqrt(sinx)/sqrt(cosx) and similarly write cotx. Simplify sqrt(tanx)+sqrt(cotx)... check that the numerator = dz/dx=(sinx+cosx). Write the denominator as mentioned in reply #17.
  • #38
Hmm ok I've managed to do it the u^2=tan x method, thanks guys. But i want to learn ssd's method, it looks simpler and shorter, and seeing as he posted the question I think he might know how to do it the best, no offense guys. ssd: When I make the numberator of the first part dz/dx, i get the 2nd parts numerator being z, I can't work out how to finish this off.
  • #39
Do the two parts separately.
Put u= sinx+cosx in the second part. You get -du/dx=sinx-cosx= the numerator of the second part. Use 2sinx.cosx = (sinx+cosx)^2 -1.
You appear right in the sense that I feel its the simplest and shortest method when the answer is not known beforehand.
  • #40
Hey, I know its been a while since I've posted on this thread, sorry about that guys. Ok well, Could someone give me another integral? Maybe one abit easier than that sqrt tanx
  • #41
No worries. Okay a simpler one for you; Evaluate the following integral
[tex]\int\frac{8\; dx}{\left(4x^2+1\right)^2}[/tex]
  • #42
I used some trig substitution and got [tex]\int (\frac{2}{\sec \theta})^2 d\theta[/tex]. Lost from there..
  • #43
Which substitution did you use? I would recommend the following one;
[tex]x:=\frac{1}{2}\tan\theta[/tex]
  • #44
[tex]\int \frac{8dx}{\sec^2 \theta}[/tex]...still lost
  • #45
O wait, I get [tex]\int 4 d\theta[/tex]...I don't Understand what to do now..the answers 4theta? What..
  • #46
Correct!
You now have to do the integration with respect to theta. What happens when you integrate a number with respect to something?
  • #47
Yes, and now express theta in terms of the initial variable, x. Add the integration constant.
Daniel.
  • #48
So is the solution [tex]4\arctan 2x[/tex]...Hey wait, i derived it, it works :), anuda one?
Edit: Forgot the +C
  • #49
Looks good to me.
  • #50
And now for something a little different;
[tex]I = \int x^2\sin x\;dx[/tex]
  • #51
Awesome :) Let's try another :)
Edit: didnt see that post
  • #52
you were correct. it comes out to be [tex]\int \frac{4}{\sec^{2} \theta} d\theta[/tex] which is equal to [tex]\int 4\cos^{2} \theta d\theta[/tex]. now use the identity [tex]2\cos^{2}\theta = 1 + \cos(2\theta)[/tex]
  • #53
I did integration by parts a few times, I got [tex]I=\frac{\sin^2 x}{2} - x^2 \cos x[/tex] :D I think that's right.
Note: This ones for x^2 sin x dx.
  • #54
I've already got that one, but knowing how to do it that way would be good. I understand that identity, but can't see how that will help me..
Edit: Wait gimme a min, i think i see it..
Edit 2: I Get [tex]2\theta + \sin 2\theta[/tex] Then what do i do..
  • #55
does the answer come out to be [tex]-x^2\cos^{2}x + 2x\sin x + 2\cos x + C[/tex]?
  • #56
Neither is correct, but murshid is closer than Gib.
  • #57
Umm Ok Ok, Problem 1. I can't see what to do with murshid_islams method, and When I found the derivative of my solution to I, for x^2 sin x dx, I get (2x + cos x)sin x, that doesn't work..
Edit: Ok i was wrong lol, Ill try it again
  • #58
lol. the answer i came up with is
[tex]-x^2\cos x + 2x\sin x + 2\cos x + C[/tex]
i think this is correct.
you used the substitution [tex]x = \frac{1}{2}\tan\theta[/tex]
from this, you get, [tex]\tan\theta = 2x[/tex] and from this, you get [tex]\theta = \arctan(2x)[/tex] and [tex]\sin\theta = \frac{2x}{\sqrt{4x^2+1}}[/tex] and [tex]\cos\theta = \frac{1}{\sqrt{4x^2+1}}[/tex].
and you also know that [tex]\sin 2\theta = 2\sin\theta\cos\theta = \frac{4x}{4x^2+1}[/tex]
so your answer will be
[tex]2\theta + \sin2\theta = 2\arctan(2x) + \frac{4x}{4x^2+1}[/tex]
  • #59
This is indeed correct.
  • #60
Ok, I made a few mistakes the first time, I got [tex]I = x^2 + 2x \sin x + \cos x + C[/tex], but when I derive it it doesn't work again :'(
EDIT: AWW KILL ME! Sorry Guys, I got the same answer and Murshid, Its just that during my working I wrote down [tex]x^2 -\cos x[/tex]...It was ment to me the multiplication of these 2, or -x^2 (cos x), but I took it as x^2 minus cos x...:'( sorry guys
  • · Replies 57 ·
10K
  • · Replies 22 ·
