Finding the concentration of a gas (thermodynamics)
The discussion revolves around calculating the concentration of oxygen gas using thermodynamic principles, specifically focusing on the relationship between pressure, volume, temperature, and molecular velocity. Participants explore various equations and methods to derive the concentration in terms of particles per volume.
  • Homework-related
  • One participant presents a method to calculate the concentration of oxygen using the root mean square velocity and the ideal gas law, arriving at a concentration of approximately 4.899 m-3.
  • Another participant clarifies that the mass used in the calculations refers to an individual oxygen molecule and suggests ensuring the correct value for the gas constant R to maintain consistent units.
  • A different participant asserts that the interpretation of concentration as particles per volume is correct for this physics problem, supporting their choice of R.
  • One participant acknowledges the initial method as correct but points out a potential missing factor in the final calculation, suggesting that the final number may be close but not verified.
  • Another participant provides a detailed calculation using a different approach, yielding a concentration of approximately 4.9006 x 1024 molecules/m3, while expressing a desire to verify unit consistency.
Participants express differing views on the correctness of the calculations and methods used, with some supporting the initial approach while others suggest corrections or alternative methods. No consensus is reached on a definitive answer or method.
Participants note potential issues with unit consistency and the need for careful selection of constants, indicating that assumptions about conditions such as temperature and pressure may influence the results.
raul_l
Hi.
The root mean square velocity of oxygen molecules is 480m/s while the pressure is 20kPa.
What is the concentration (particles/volume) of oxygen?
PV=nRT
[tex]E_{kin}=\frac{m \overline{v}^2}{2}=\frac{3}{2}kT[/tex]
[tex]m \overline{v}^2=3kT \Rightarrow T= \frac{m \overline{v}^2}{3k}[/tex]
[tex]PV=nR \frac{m \overline{v}^2}{3k} \Rightarrow n=\frac{3kPV}{Rm \overline{v}^2}[/tex] where [tex]m=2 \times 16 \times 1.66 \times 10^{-27} kg[/tex]
I set V=1m^3 and get n=8.137mol and therefore [tex]\frac{n \times n_{a}}{V}=4.899 m^{-3}[/tex] where [tex]n_{a}=6.02 \times 10^{23}[/tex]
Is this correct? I'm sure there's a simpler way to do this.
Note that the mass refers to an individual oxygen molecule (from what I recall at the moment), (16 grams of Oxygen/mole of Oxygen)(1 mole/6.022 x 10^23 atoms)(1 kilogram/1000 grams)(2 atoms of Oxygen/1 diatomic molecule)=____...the setup should be solved for n/V, this means that you need to incorporate a particular value of R, choose from the list on the page that can be linked to through the below text so that the final units for n/V is respect to moles/liter.
http://en.wikipedia.org/wiki/Gas_constant
Actually, since this is one of my physics class problems (not chemistry) concentration really does mean particles/volume in this case. Which means that I have chosen the right value for R, I think.
You're missing a factor of 10^{24} in that final bit.
The method is perfectly correct - I haven't checked the numbers, but I believe the final number looks close enough (I happen to know that the RMS speed of oxygen molecules at room temperature is about 500m/s, and at NTP, a mole of atoms occupies about 22.4 liters, so at a fifth of an atmosphere, the concentration would be roughly 6/(5*0.0224)*10^{23} per cubic meter, which is about 10% higher than your number, but this is very rough estimate.)
As for a simpler way, I think this is as simple as it gets. Only, notice that since R=k*Na, and M=m*Na, your final expression simplifies to n=3PV/Mv^2 (in moles).
(n/v)=20 kPa(1000 Pa/1 kPa)(1.3806503 × 10-23 m2 kg s-2 K-1)3/[8.314472 m^3 · Pa · K-1 · mol-1(16 grams of Oxygen/mole of Oxygen)(1 mole/6.022 x 10^23 atoms)(1 kilogram/1000 grams)(2 atoms of Oxygen/1 diatomic molecule)(480 m/s)^2]= 0.00813782909722 moles/m^3
(0.00813782909722 moles Oxygen/L)(6.022x10^23 molecules Oxygen/mole)= 4.900600682 x 10^24 molecules/m^3
So there's everything done in a perfunctory fashion for ya, I wanted to see what answer would result with the "chemist" method.:smile:
I'm going to need to see if the units cancel out exactly...
