Solving the Sliding Rod Equilibrium Problem on a Wall
  • Thread starter Thread starter daniel_i_l
    Rod Sliding Wall
The discussion centers on solving the Sliding Rod Equilibrium Problem involving a rod of length L and mass M leaning against a frictionless wall at a 30-degree angle. The initial calculation for static friction was incorrectly stated as Ustatic >= 0.6sqrt(3), while the correct threshold is Ustatic >= 0.5sqrt(3). Key forces considered include gravity, the horizontal force from the wall, and the vertical normal force from the floor, which must be analyzed for both translational and rotational equilibrium.
  • Understanding of static friction and equilibrium conditions
  • Knowledge of forces acting on inclined objects
  • Familiarity with torque and its calculation
  • Basic principles of mechanics, including translational and rotational equilibrium
  • Study the principles of static equilibrium in physics
  • Learn about torque calculations in inclined systems
  • Explore the effects of friction on equilibrium conditions
  • Investigate similar problems involving inclined rods and forces
This discussion is beneficial for physics students, educators, and anyone interested in mechanics, particularly those studying static equilibrium and forces acting on inclined objects.
daniel_i_l
Here's a question (not homework) that someone asked me a few days ago:
you have a rod with length L and mass M that's leaning against a frictionless wall and makes a 30deg angle with the floor. what does the static friction have to be inorder for the stick to stay inequilibrium?
What i did was to pretend that all the mass was at the center of the rod. then i split the force mg on that point into two parts - "along the rod" and perpendicular to the rod. the force along the rod pushes the bottom of the rod into the ground with and angle of 30 bellow the ground. the perp force induces a normal force which also has two parts - along the rod and perp to the rod going up. this perp force creates a torque which also pushes the bottom of the stick into the ground.
So basically i summed up all these forces and got the answer:
But the real answer is
Ustatuc >= 0.5sqrt(3)
What it the correct way to deal with this problem?
Thanks.
Whether "homework" or not, all textbook/coursework-type questions should be posted in the appropriate "Homework Help" section. I'll move it. :smile:
I can't really follow what you are doing here. To solve this, just consider all the forces acting on the ladder:
(1) Gravity, which acts down through the center of mass (you started off with that)
(2) The force from the wall--since there's no friction, it acts horizontally
(3) The force from the floor--break it into two components: friction force (horizontal) and normal force (vertical)
Now just apply the conditions for translational and rotational equilibrium.
thanks, i got it now.
  • · Replies 20 ·
18K
