Learn the general case first, or the special case first?
  • Context: Undergrad
  • Thread starter Thread starter andytoh
    General
The discussion revolves around the optimal order of studying general cases versus special cases in learning mathematical and theoretical concepts, particularly in relation to topics such as Hilbert spaces, metric spaces, and Riemannian geometry. Participants explore the implications of each approach on understanding and retention.
  • Some participants argue that studying the general case first provides a broader understanding and makes related topics easier to grasp later.
  • Others suggest that beginning with a special case allows for quicker comprehension and enjoyment of the material, as it provides immediate context.
  • A participant notes that learning Riemannian geometry before pseudo-Riemannian geometry may be beneficial, indicating a potential contradiction in their own reasoning.
  • One participant expresses a preference for starting with special cases, citing a programming background that favors incremental problem-solving.
  • Another participant believes that studying special cases first can enhance appreciation for the general case, suggesting a balance between efficiency and enjoyment in learning.
Participants do not reach a consensus on whether to study general cases or special cases first. Multiple competing views remain, with some advocating for the general case and others for the special case, highlighting the subjective nature of the learning process.
Participants express varying opinions on the effectiveness of each approach, with some acknowledging that time constraints often dictate the order of study in educational settings. The discussion reflects personal experiences and preferences rather than a definitive methodology.
andytoh
By studying the generalization of a topic, you learn all the properties that other related topics share with the topic you want to study, and thus you can more easily learn the other topics due to the foreknowledge you've gained, and also should understand the original topic more. On the other hand, by studying a special case of the topic, you learn specialized properties which does not hold in the general case and you understand the original topic more quickly.
I believe both the special case and the general case should be studied to get a full understanding of the topic. My question which is the better ORDER to optimize your understanding during the learning process?
Mathematics news on Phys.org
In case you find my question too vague, let me give you an example. Suppose you wanted to study Hilbert spaces, which is an inner product space that is complete in its norm. Should you directly jump into the study of Hilbert spaces? This would certainly make you understand Hilbert spaces quickly.
Or should you first more generally study the properties of metric spaces (and the properties of Cauchy sequences in metric spaces) which has complete normed spaces as a special case, and/or the property of normed spaces (or even more general, Banach spaces) instead of specifially the norm obtained from an inner product. By doing this, you get a better understanding of completeness and norms and so when finally going into Hilbert spaces it is all so much clearer than if you jumped into Hilbert spaces immediately.
Is it better to study Riemannian geometry first or the more general pseduo-Riemannian geometry first, if you want to apply your knowledge to general relativity (which uses the latter)?
And let us assume that time is not a factor. Which is the better order in which to study (and to teach as well)?
I believe that learning the general case first is better, since the special case makes much more sense when you study it after the general case. Learning related topics then usually does not require backtracking and the related topics seem much more related than without having studied the general case first. However, we are usually taught the special case first though due to time constraints.
However, for some reason I find learning Riemannain geometry before pseudo-Riemannian geometry may be better, contradicting myself, and I can't pinpoint why. Also, I studied the projective space before studying the more general Grassmanian manifold and due to the complexity of the the Grassmanian, I think it was the correct order, supporting the opposite view again.
I find that the study of the special case helps me appreciate, more so enjoy, the general case. For maximal efficiency, I would say to do the general case first, and for maximal enjoyment I would say to do the special case first.
Wow. So general case vs. special case is efficiency vs. joy?
I do special cases then work out to the general case.
It's probably a byproduct of being a programmer: trying to solve the entire problem in one go is suicide.
I don't view studying the generalizations to be "solving an entire problem in one go". I think its more like postponing the special topic for later, and collecting more general information first. The special topic can then be learned much more clearly (and probably faster) after having first developed a solid general background.
  • · Replies 17 ·
