Find Work Done in Thermo Question | Monatomic Gas | Calculation Help
  • Thread starter Thread starter suspenc3
    Thermo
The discussion revolves around calculating the work done in a thermodynamic process involving a monatomic gas. Participants are exploring the area under curves in a pressure-volume diagram to determine work done during various segments of the process.
  • Participants discuss finding work by calculating the area under curves and suggest integration as a method for determining these areas. Questions arise regarding the setup of integrals and the application of principles for isentropic processes.
There are multiple approaches being explored, including the use of integrals and the application of specific formulas for isentropic processes. Some participants are questioning the assumptions made about the gas being monatomic and how that influences the calculations.
There is a reference to an attachment that is not visible to all participants, which may limit the context for some. Additionally, the discussion includes specific conditions for reversible adiabatic processes and the need to clarify the gas type and its properties.
suspenc3
See Attachment
Well to start off I know the gas is monatomic
I can find the work done by finding the area under each curve/line:
[tex]W_{AB} = p_0(2v_0-v_0) = p_0v_0[/tex]
[tex]W_{CD} = (p_0/32)(8v_0-16v_0) = \frac{-p_0v_0}{4}[/tex]
I can't think of how to find the area under the other two curves, I am guessing integration but I don't know how to set it up.
After I find these other to, what do I do?
Thanks
I can't see the attachment yet, but finding the area between two curves is easy. The easiest way to do it is to subtract the area under the lower curve from the area under the upper curve.
If you did it in one integral, you could set up the limits of integration from one curve to the other.
for isentropic expansion and compression in ICEs we use the same principle u used to find the first 2 works.
we use : W= (PoVo-PoVo/4)/(1-k) k=Cp/Cv. for isentropic adiabatic compression or expansion.
How did u know the gas was monoatomic?
Where do you get this? It works for BC but not DA
Generally, for reversible adiabatic paths:
(1) [tex]W = K\frac{V_f^{1-\gamma} - V_i^{1-\gamma}}{1-\gamma}[/tex]
where [itex]K = PV^\gamma[/itex]
This is just the integral [itex]\int dW[/itex] where [itex]dW = dU = PdV = KV^{-\gamma}dV[/itex] (dQ=0)
Since for DA [itex]P_f = 32P_i[/itex] and [itex]V_f = V_i/8[/itex] the numerator in (1) is simply:
[tex]P_fV_f - P_iV_i = 32P_iV_i/8 - P_iV_i = 3P_iV_i[/tex]
for BC, [itex]P_f = P_i/32[/itex] and [itex]V_f = 8V_i[/itex] the numerator in (1) is simply:
[tex]P_fV_f - P_iV_i = 8P_iV_i/32 - P_iV_i = -3P_iV_i/4[/tex]
Apply the adiabatic condition [itex]PV^\gamma = constant[/itex] to one of the adiabatic paths and solve for [itex]\gamma[/itex].
AM
Thanks Andrew
