How Can I Search for Specific Characters in .html and .txt Files Offline?
The discussion revolves around searching for specific characters within .html and .txt files offline, particularly focusing on the limitations of Windows Vista's search capabilities compared to earlier versions like Windows XP. Participants explore various methods and tools for achieving this task.
  • One participant expresses frustration with Windows Vista's search functionality, noting it only searches for filenames rather than strings within files.
  • Another participant mentions that Windows XP has a feature that allows searching for phrases within files, inviting comments from Vista users.
  • A suggestion is made to try the XP search feature as a potential solution, along with the idea of using Google desktop search or creating a custom program for the task.
  • A participant introduces the "find" command in Windows XP's command window as an alternative method, providing details on its usage and options available.
Participants do not reach a consensus on the effectiveness of the search tools available in Windows Vista compared to Windows XP, indicating that multiple views on the best approach remain unresolved.
Limitations include the specific operating systems discussed and the potential lack of awareness of other offline search tools that may exist outside the mentioned options.
Ara macao
So I want to look for specific characters within my .html and .txt files offline. But even when I google offline search engine, I can't find a suitable search engine. Windows Vista Search doesn't seem to have a search engine that works for strings within particular files (it just seems to work for filenames).
Technology news on Phys.org
I haven't used Vista, I'm running xp, but in the xp search there is a box to search for a phrase within files... anyone with vista want to comment?
The first thing I would try is the XP search mentioned above. Then I would probably check out Google desktop search or program one to do it myself.
There is a "find" command in windows xp's command window. Try going to start, run, type in "cmd," then type "find /?" and see if this will work for you if the "search for a phrase within files" suggestion doesn't work right for you.
Actually, here's the printout from running "find /?"
C:\>find /?
Searches for a text string in a file or files.
FIND [/V] [/C] [/N] [/I] [/OFF[LINE]] "string" [[drive:][path]filename[ ...]]
/V Displays all lines NOT containing the specified string.
/C Displays only the count of lines containing the string.
/N Displays line numbers with the displayed lines.
/I Ignores the case of characters when searching for the string.
/OFF[LINE] Do not skip files with offline attribute set.
"string" Specifies the text string to find.
Specifies a file or files to search.
If a path is not specified, FIND searches the text typed at the prompt
or piped from another command.
  • · Replies 187 ·
11K
  • · Replies 18 ·
  • · Replies 16 ·
