Calculating Electric Potential in A Uniform Electric Field
The problem involves calculating the electric potential at a second point in a uniform electric field, given the potential at the first point and the characteristics of the electric field. The context is within the subject area of electrostatics.
  • Participants discuss the formula for electric potential and the significance of the direction of the electric field. There are attempts to calculate the potential difference using different approaches, including considering the angle and the distance between points.
Some participants have provided guidance on how to approach the problem, emphasizing the importance of the direction of the electric field and the correct application of the potential difference formula. Multiple interpretations of the problem are being explored, particularly regarding the calculation of distance and the sign of the potential change.
There is a noted confusion regarding the sign of the potential change and the relevance of the angle in the context of a uniform electric field directed along the x-axis. Participants are working within the constraints of the problem as presented, without additional information.
Moxin
Here's the problem:
Two points are in an E-field: Point 1 is at (x1,y1) = (4,4) in m, and Point 2 is at (x2,y2) = (13,13) in m. The Electric Field is constant, with a magnitude of 65 V/m, and is directed parallel to the +x-axis. The potential at point 1 is 1000 V. Calculate the potential at point 2.
IT IS ABSOLUTELY SICKENING How Many Times I Attempted this Seemingly Easy Problem And Got it WRONG...so apparently, this isn't as easy as I thought !
I KNOW this problem Has to utilize the formula V = Ed (or perhaps V = Edcos(theta) ?)
for d i get sqrt((13-4)^2 + (13-4)^2) = 12.7279
and E is given
soooooooooo... for the change in potential i get 827. I then add that to the potential of point 1 to get the potential of point 2 and I get 1827. But apparently that's wrong. So are the answers 1000, 1585, and 1292 which I got from slightly tweaking the main formula in different ways. I have no clue what else to try...any help ?
First of All look at the direction of Electric field it is in +x direction So Potential is going to decrease in +x direction
Moreover Apply
[tex]E\cos(45)^0r=|\Delta V|[/tex]
himanshu121: Do you really need to worry about the angle? Since the Field is directed in the x-direction, the potential only changes in that direction. For a constant field intensity, F, the change in potential is F times the change in x coordinate. In this problem the x coordinate changes from 4m to 13m (a change of 13-4= 9m) and F= 65 V/m so the change in potential is 65 V/m * 9 m= 585 V. As himansh121 pointed out, this is a decrease so it is -585 volts. Now, you know the potential at (4,4) so what is the potential at (13,13)?
Yup, rcos45=13-4, I got ur reply Halls
the equipotential surface is a planar surface hence it would be same for x=c which is || yz
AHHHHHHHHHHHHHHHHH so my main problem was the sign... lol dang I got to becareful of that, thanks.. and thanks himanshu
  • · Replies 22 ·
