Redirect Output in UNIX: How to Use freopen() to Print to Console
  • Thread starter Thread starter ptabor
    Unix
The discussion focuses on using the C standard library function freopen() to redirect output from stdout to a file and then back to the console in a UNIX environment. The recommended approach to redirect output back to the console is to use freopen("/dev/tty", "w", stdout), which effectively points stdout back to the terminal. However, caution is advised as this method may disrupt user-defined redirections. An alternative method involves using a temporary file pointer to switch between stdout and a file, allowing for more controlled output management.
  • Understanding of C programming language
  • Familiarity with standard I/O functions in C
  • Basic knowledge of UNIX file system and device files
  • Experience with file handling in C
  • Research the freopen() function in the C standard library
  • Learn about device files in UNIX, specifically /dev/tty
  • Explore advanced file handling techniques in C, including using multiple file pointers
  • Investigate best practices for managing output streams in C applications
C developers, UNIX system programmers, and anyone looking to manage output streams effectively in C applications.
ptabor
So I'm using freopen to redirect output from stdout to a file... How do I redirect it back to the screen?
relevant code:
FILE *stream = freopen("data.txt", "w", stdout);
/* print stuff */
How the heck do I get the output stream to point to the console again?
Technology news on Phys.org
On Unix, you can access "the screen" (and every other device) via a filename. /dev/tty is a good bet for what stdout was attached to.
freopen("/dev/tty",...) should work.
But this isn't a very polite thing to do, because stdout might have been redirected by the user.
Another idea would be something like this:
FILE *myfile;
FILE *datafile = fopen("data.txt"...);
Then do
myfile = stdout;
or
myfile = datafile;
(filp back and forth as often as you like)
and do all your I/O to myfile.
