Calculate the percentage difference
  • Thread starter Thread starter physicsnewby
    Difference
The discussion revolves around calculating the percentage difference between two experimental values related to spring constants. The original poster expresses confusion over their calculations and the resulting discrepancy.
  • The original poster attempts to calculate the discrepancy using defined equations but questions the validity of their results, particularly regarding units and error values. Some participants suggest alternative methods for calculating percentage difference, while others raise concerns about the appropriateness of comparing two experimental values directly.
Participants are exploring different methods for calculating percentage difference and discussing the implications of using experimental values without a known correct value. There is no explicit consensus, but some guidance has been provided regarding statistical approaches.
The original poster notes potential issues with unit consistency and the nature of the values being compared, indicating a lack of a reference value for comparison.
physicsnewby
This is related to my last post. Again, I am getting a ridiculous answer hoping someone can help. I need to calculate discrepancy between two calculated values.
EQN 1 difference between values = Value 2 - Value 1
EQN 2 error of values = square root of (error value 1 ^2 + error value 2 ^2)
discrepancy = EQN 1/EQN2
When I use EQN 1, I'm subtracting one value of spring constant k from another. The difference between my values is in the 3000 range. For EQN 2, my error value is in 2 x 10^-3.
When I divide 3000/2x10^-3 I get 1500000 ! The answer should be relatively close to 2!
Now, my previous post was regarding units for k. Could this be the problem? The error values I calculated though were based on the data given in cm, g, seconds squared, etc. Does this matter? It seems strange to me that my calculate K is say 14000.00 +/- 0.003 (for example). Small error for such a large number!
Are'nt you suppose to calculate the percentage difference, [tex]p[/tex], between the two values? If the "correct" value is [tex]k_o[/tex] and the experimental value is [tex]k_e[/tex]
[tex]p = 100 \times \frac{|k_o - k_e|}{k_o}[/tex]
I don't have a correct value to compare to. I have two experimental values I'm comparing.
Well the formula will give the percentage difference (with the average) if you take half the difference between the two and use the average for the "correct value". It is not really sensible to compare measurements with each other this way though. Statistically one normally calculate the standard deviation and the average of a larger set of measurements.
Thanks! Figured it out :smile:
  • · Replies 25 ·
  • · Replies 29 ·
