Why do you aerospace engineers have such a hard time making spacecraft?
The discussion revolves around the challenges and considerations in designing cost-efficient spacecraft, particularly regarding the use of multiple types of rocket engines for different atmospheric levels and the implications of such designs on weight, efficiency, and costs. Participants explore various concepts related to manned and unmanned space flight, engine types, and launch strategies.
  • Some participants propose the idea of using multiple types of rocket engines on a single spacecraft to optimize performance at different atmospheric levels.
  • Others argue that adding many engines increases costs and complexity, as each engine requires certification and adds weight.
  • A participant mentions that current spacecraft designs already utilize multiple stages rather than a single-stage-to-orbit approach due to the high costs associated with carrying all components to orbit.
  • There is a suggestion that variable-geometry nozzles could improve efficiency, although this does not address the issue of dead weight from unused engines.
  • One participant highlights the potential of using high-altitude aircraft to launch spacecraft, referencing the strategy used by Scaled Composites for the X-Prize competition.
  • Concerns are raised about the feasibility of retaining all engines without discarding spent stages, as this would lead to significant dead weight that complicates reaching orbit.
  • Some participants discuss the concept of morphing engines that could transition between different types of propulsion, such as turbojets to scramjets to rocket engines, but acknowledge the challenges in developing such technology.
  • There is mention of the historical context of hypersonic research and the ongoing challenges related to materials that can withstand high temperatures during flight.
Participants express a range of views on the feasibility and practicality of using multiple engines and the implications of such designs. No consensus is reached, as various competing ideas and concerns are presented throughout the discussion.
Participants note the complexities involved in spacecraft design, including the need for certification, weight considerations, and the challenges of managing dead weight from unused engines. The discussion also touches on the limitations of current technologies and the need for further advancements in propulsion systems.
Oomair
isnt possible to make cost efficient spacecraft by putting multiple types of rockets on a ship which can then alternate rocket engine at different levels of the atmosphere and eventually escape into space?
Let's start with the easiest question for you...Are you referring to manned or non-manned space flight?
Every engine that gets put on an aircraft has to get certified (expensive). Every engine has to have its associated components (weight). Every engine costs money to make (again, expense). The more engines you have the more complicated the control system is (cost)...There are a whole lot of tradeoffs to consider other than an engine's Isp in a vehicle design.
russ_watters said:
Lots of engines? Sounds expensive...
It also sounds inefficient, as the rocket engines not in use at a given time just become extra dead weight that the engine in use has to lift
This is exactly what we do right now. We do not use a single-stage-to-orbit. The systems that carry vehicles from the Earth's surface to space comprise a number of rockets. Multiple stages are needed because a single-stage-to-orbit vehicle would need to carry its entire empty structure all the way to orbit. With present fuel technologies, doing so be very expensive.
There is a compromise approach, but it's still not as good as dropping dead stages. Variable-geometry nozzles such as the (still experimental?) linear aerospike can operate at peak efficiency throughout the climb. That doesn't resolve the issue of all the dead weight, but jettisonable fuel tanks would help.
The most efficient I'm thinking right now at the moment is the strategy made by Scaled Composites for the X-Prize competition. Have an aircraft carry the spacecraft from high altitudes and launch it from there. I think the Antonov An-225 could do just that for heavier manned orbital flights.
But maybe in the future, an aircraft could be made just for that and could cruise above 70,000 ft and still carry very heavy payloads, that makes a good launching platform. Instinctively, this craft would be BWB or possibly a high aspect ratio flying wing with extended booms for elevator pitch control, that makes for a high L/D craft with high altitude capability with excellent structural integrity for carrying heavy payloads.
There is no aerospike that has flown to my knowledge. There are engines that have movable skirts to help compensate for altitude, but not to the extent of the spike.
Launching a vehicle from an aircraft worked for SpaceShipOne precisely because it was only a suborbital vehicle. SpaceShipOne had a maximum specific energy of about 1 megajoule. Compare this to a vehicle in low Earth orbit, which has a specific energy of 32 megajoules or more. Launching a vehicle from an aircraft doesn't buy much capability in terms of getting a spacecraft into orbit. The first stage would still be needed. Much better is to make the various stages completely reusable (Rocketplane-Kistler K1, Space-X Falcon-9).
what I am trying to say is that, why doesn't NASA develop manned vehicles with multiple types of engines, for example, the ship uses let's say engine A to get to one point of the atmosphere,
then engine A is shut off but not broken off the ship, then you activate engine B, C, and eventually escape into space
that way the engines are saved so NASA doesn't have to waste money to make new ones
Oomair, many reasons why it's not done like that were already given in the previous answers you got...
The crucial phrase here is "but not broken off the ship". If the vehicle doesn't discard spent stages it has to haul all that dead weight into orbit. The http://en.wikipedia.org/wiki/Tsiolkovsky_rocket_equation" says this is cannot be done. It would be better to have a single-stage-to-orbit vehicle (which we can't do yet) than a multi-stage-to-orbit that doesn't discard spent stages. Moreover, returning this dead weight to Earth will be a considerable challenge. The return vehicle will have to be a lot heftier to be able to keep that awkward weight under control when it hits the atmosphere at Mach 25. That's even more dead weight that has to be hauled into orbit.
Oomair, you might be getting misled by some ideas that have been kicking around for atmospheric machines, such as taking off with turbojets and switching to scramjets when supersonic. Those things are not intended to go orbital, and they don't have to carry an oxydizer.
Oomair may have a point, but not literally with multiple engines. I've read about some 'single stage' concepts put forth by reputable aircraft companies. One of them actually envisioned a turbojet that 'morphed' and doubled as rocket engine. The turbojet seemed to close it's inlet, compressor and combustion area, and used the nozzle section as the rocket engine.
I was thinking that turbojets are rather complex and heavy. So I might propose a ramjet instead that morphs to scramjet, and finally morphing to rocket engine to reach orbit. Scramjet are indeed not intended to go orbital and that's when the rocket engine or 'rocket mode' takes over.
The idea understandably, makes the vehicle carry much less oxidizer needed than would a pure-rocket design, that enormous fuel weight saved could directly translate to greater payloads carried and of course, much improved economy of space flights. The challenge now is designing a morphing engine that is efficient in wide range of flight regimes as well as light in weight.
There has been real plans to use the the scramjet for use with single stage orbital vehicles, but scramjet technology and hypersonic flight is still relatively early as of now. There's not even one manned flight conducted to date.
@D H, the energy comparison, is very enlightening to know, thanks, so that would make aerial launches very much insignificant gain in energy
Hypersonic research has been going on since the 60's gaming_addict. The problem has been finding materials that will survive the high viscous heating.
ok one thing i want to get straight in my head here is that does a space shuttle that is returning to orbit just dive into orbit at a high speed and makes a landing like a plane or does it stay in a suborbital area for a few hours by slowly coming down each atmospheric level so that the heat doesn't dissolve it?
It takes a little over an hour to start from deceleration burn to landing. And yes, you are right with your 2nd statement.
-It starts by deceleration burn
-Skips over the upper atmosphere, much like a skipping stone thrown over the surface of a lake
-By maintaining high angle of attack, you create a 'lot of drag' and the glide path steepens <-do that if you think you might overshoot your target landing area, conversely, you reduce angle of attack if you feel like coming short.
-You could also do a series of 'S-Turns' or steep break turns left and right to bleed more speed if you think you might overshoot
^^All of the above maneuvers are done above 200,000 ft traveling at hypersonic velocities.
When you have gone below hypersonic at lower altitudes, the glide bath then becomes more steep.
So to summarize, glide path during high altitude hypersonic phase is relatively shallow, done at high angle of attack(to expose the more heat resistant bottom tiles) and to experience the least heating possible(least aerodynamic pressures) but at a longer period of time. Once the craft have gone supersonic, lower altitude, and nearing the landing area, that's when the glide path becomes very steep, to have good speed for landing, and of course to make up for the space shuttle's very poor aerodynamic efficiency :)
You really should be careful with the words you choose. I have been on a couple of programs that looked into hybridization between air breathing and rocket propulsion systems. That's exactly what they are, hybrids. The whole "morphing" thing, other than sounding cool, is a pipe dream brought about, mostly, by people looking for government research funding. I can imagine my Chevy Blazer morphing into a Ferrari when I want to go into "race car" mode. You're saying the same thing.
I would challenge you to look at the weight of a turbojet versus the combined weight of a thruster package and the associated turbo pumps and delivery systems.
Oh yeah...those pesky details we have to think about I guess. Morphing...light...efficient over a wide operating range...That's not a challenge. That's unrealistic dreaming.
Considering that the first real scramjet model research craft testing was in 2002 and then 2004, it may be a bit of a stretch to say "we haven't even had a manned flight yet." There's at least a couple of decades of research and development before we see anything close to a manned flight.
Yep, that 'hybrid' term didn't come to mind so I used 'morph' instead. When I meant the 'morphing' thing, here's what I meant:
http://en.wikipedia.org/wiki/Pratt_&_Whitney_J58
That's a real example of an engine that 'morphed' into another, from a turbojet into ramjet. So 'hybrid' it is! Sorry I'm not a native speaker so I could get lost with words :)
I know one of them will be heavier(the turbojet will be the lighter in weight, I assume), and I presume you'd say it won't matter if I used ramjets or turbojets. But I prefer using the ramjet because, it will be used from high subsonic to mach 4 in which, a ramjet will by far outperform a turbojet in thrust levels. Turbojets can only match a ramjet in reheat but it becomes so inefficient
But you're right, these things, ramjet to scramjet, then rocket, is still decades away.
My best bet at present would still be a BWB because it can be stiffened so easily and made very strong. Thus a very light body and yet strong could be made, making single stage flight possible and reentries safer.
-Skips over the upper atmosphere, much like a skipping stone thrown over the surface of a lake ...
This is all wrong. The Shuttle has only done a skip reentry in simulations. It has never done one in reality. Skip reentry has a very low Technology Readiness Level (TRL 3, to be precise). It is one of the many technologies that need to be beefed up considerably before we even consider sending people to Mars.
The thing about the J58 is that it "morphs" into a different version of the same class of engine, i.e. air breathing. It's a big difference from trying to go between air breathing and non-air breathing. The technical difficulties that immediately come to mind to marry the two is pretty substantial.
I don't know how practical it would be, but my approach would be to use an air-breathing rocket with a variable geometry nozzle and something like a APU turbine to run the compressor. At ram speed, the compressor could be bypassed, then cut in the oxydizer pumps when the air runs out.
Plausible, Fred? :confused:
If I understand you correctly, the first two issues would be
1) Exhaust gas temps from the rocket would be waaay too high for any known made turbine to date. You would have to make some pretty big leaps in materials to do that. The existing rocket chambers are made of pretty exotic stuff like Columbium (Niobium) and Rhenium. Very tough stuff to manufacture parts with let alone complex geometries like a turbine.
2) Getting the variable nozzle to be effective over a wider altitude range (that is a very realistic goal to shoot for).
Thanks for the response, Fred. You did apparently misunderstand about item #1, though. The rocket would be just a rocket, with no turbine or compressor inherent to its design. The compressor would be a separate structure which could be ducted into the system with a bypass circuit to force-feed the engine at low speed. With ram speed attained, the diverter valve would be flipped to 'straight-through' from the intake to the rocket. I was thinking of an aircraft APU or electric motor to power it, rather than tapping into the rocket.
Nice to know. I only experienced the skipping portion in X-plane shuttle simulation, it has way too much speed to start with(perhaps, very little fuel for reentry rocket burn).. I followed everything you read in books with success but it never mentioned the skipping part.. In x-plane you have to hand fly all the reentry phase up to touchdown, and I have a success rate of 3 of 10 attempts. I either crashed or went too short or overshot Edwards AFB :)
Same here, one air-breathing hybrid(ramjet/scramjet) but my rocket would be an entirely separate unit located in the rear. The rocket nozzles when not in use will be covered by disposable/detachable aerodynamic fairings. Even the ramjet/scramjet can be discarded and reused. But like it is, the technological hurdle is the hybrid ramjet/scramjet. For now, very light weight BWB(with excellent fuel fraction) and aerospike nozzles are within reach.
But I have to ask this time, maybe we are thinking of fuel economy of space flights, but do they contribute significantly to cost of space flights or is the maintenance/manufacture of space vehicles or other things?
I got you now. I can't say it's unfeasible technically. It may tough to match an APU big enough to drive a reasonable sized compressor and not go through the roof on weight.
I would have to figure out the entire cycle though and where you would insert the compressor to help the rocket at low speeds. I'm just not seeing that being any help. Do a sketch...those are always a huge help.
Will do. It'll take a while, though, because I'll be using Illustrator. That entails filtering it through Photoshop in order to get a format that Imageshack will accept. I did that crappy little turbine sketch in Paint, but I hate that program.
http://www.aiaa.org/content.cfm?pageid=406&gTable=mtgpaper&gID=14589
The plume physics behind aerospike nozzle altitude compensation and slipstream effect
J. H. Ruf and P. K. McConaughey (NASA, Marshall Space Flight Center, Huntsville, AL)
AIAA-1997-3218
AIAA/ASME/SAE/ASEE Joint Propulsion Conference and Exhibit, 33rd, Seattle, WA, July 6-9, 1997
http://www.aerospaceweb.org/design/aerospike/losses.shtml
Test flight of aerospike engine - see figures 5 & 6
http://www.maecourses.ucsd.edu/mae155a/nlv.pdf
I am not sure that aerospikes can be scaled up for large rocket motors though. There comes a point where storage of cryogenic hydrogen becomes in issue, which is why Saturn V was based on kerosene/LOX.
Back in the days of large thermonuclear devices, the Pentagon embarked on a program for nuclear propulsion to launch them. Then the guys at the Livermore and other labs got innovative and the size of the TN's got smaller such that conventional rockets could launch them. Then nuclear propulsion was realigned to interplanetary travel - which then died in the early 1970's.
As for power, many systems use a power head or bleed and feed system.
http://shuttle.msfc.nasa.gov/SSME.cfm
http://www.engineeringatboeing.com/dataresources/SpaceShuttleMainEngineThirtyYearsOfInnovation.doc
See also - http://www.space.com/businesstechnology/technology/sli_cobra_020904.html
Hey, Fred... I finally got a chance to do that sketch up. As you can see, I didn't go into any detail; it's just an overview of what I have in mind. I didn't bother drawing the 3rd configuration, which seals the combustion chamber from atmosphere for straight rocket operation.
"[IMG[/URL]
Nice drawings Danger. You even included the preheat/cooling coils on the nozzle.
I think the idea is feasible. There would be a couple of tricky spots to it if it ever got off the ground (pardon the pun):
- You would have an aerodynamic flowpath into the top of the rocket chamber. That flow would be pretty tough to have behave. It would take some doing but not impossible.
- The typical smaller rocket engine chamber pressure is around 150 psia (from what I have seen). That would mean you would either have to size the compressor to have the same final pressure rise or increase the wall thickness on the chamber which would usually mean huge dollars.
- The compressor section would have to decouple some how from the chamber. Typical rocket chamber temps are wicked hot*. The thermal soakback would be tremendous. Thermal management in general would be tough.
* Technical engineering term for high temperature.[/size]
- The only other thing I can think of off the top of my head is how would this thing run when in the air breathing mode? I don't think it would be easy to get the equivalent burn out of the air breathing side versus the rocket side simply because the air is a different oxidizer. Would you get the same burning characteristics out of the same fuel using two very different oxidizers? I don't know.
Still, I don't think it would be beyond anyone to try this configuration. I think the toughest part would be to sell someone to fund it!
  • · Replies 22 ·
  • · Replies 35 ·
  • · Replies 17 ·
