How do you find the frictional force acting on an object if it is decelerating?
The problem involves a train of mass 8.0 × 10^6 kg that is decelerating from a speed of 30 m/s to rest over a period of 25 seconds. The questions focus on calculating the frictional force acting on the train during deceleration and determining the stopping distance.
  • Participants discuss the application of Newton's second law and the relationship between net force and acceleration. There is uncertainty regarding the calculation of acceleration and whether the net force can be considered zero during constant deceleration. Some participants question the use of specific kinematic equations for calculating distance.
The discussion is ongoing with participants exploring different interpretations of the problem. Some guidance has been offered regarding the calculation of acceleration and the appropriate equations to use, but there is no explicit consensus on the correct approach yet.
Participants are grappling with the definitions of acceleration and net force in the context of deceleration, as well as the assumptions underlying the kinematic equations being discussed.
lina45
Q : A train of mass 8.0 [tex]\times[/tex] 10[tex]^{}6[/tex] kg, traveling at a speed of 30 m s[tex]^{}-1[/tex], brakes and comes to rest with a constant deceleration in 25s.
(a) Calculate the frictional force acting on the train while decelerating.
(b) Calculate the stopping distance of the train.
I have no idea which equations to use...
Well... first i found the net force which is zero because it is contant negative acceleration. I then attempted a diagram. I don't know what do do next.
Are you sure? Would Newton's second law agree with that statement?
In the first question, you are asked for a force. I know an equation that gives you the net force, namely: F = m a. But, there is an unknown in it, the acceleration. Since you know the initial velocity and stopping time, can you calculate the acceleration from this? And once you have the net force, is this also the force requested or might this be a sum of the force you actually want and some other force(s)?
In b, you need an equation that will give you the distance. Try [tex]s = \tfrac12 a t^2[/tex] - which unknowns are there and how can you determine them?
but wouldn't the net force be zero because when you use the formula F = ma isn't constant deceleration regarded as zero acceleration?
Careful. Constant velocity is zero acceleration.
howcome the formula s = [tex]\frac{}{}1/2[/tex] at[tex]^{}2[/tex] used instead of s = ut + [tex]\frac{}{}1/2[/tex] at[tex]^{}2[/tex]
Using s to denote displacement and u to denote velocity, the full kinematics equation for displacement is [tex]s = s_0 + u_0 t + \frac{1}{2} at^2[/tex], where [itex]s_0[/itex] is initial displacement and [itex]u_0[/itex] is initial velocity. If both of these are zero, they just drop out. So that just leaves us with [tex]s = \frac{1}{2} at^2[/tex]. Hope this helps.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 21 ·
