Fluid Flows - Complex potential function and general equation of a streamline
The discussion focuses on deriving the general equation of a streamline using a complex potential function and stream function in fluid dynamics. The complex potential function provided is (3x^2)/2 - (3y^2)/2 + 6y, while the stream function is x(3y-6). The velocity function q(z) is expressed as q(z) = dx/dt + i dy/dt = x + (6-y)i, leading to the differential equations dx/dt = 3x and dy/dt = 6 - 3y. The resulting general streamline equation is x(2-y) = C', representing a family of hyperbolas.
  • Understanding of complex potential functions in fluid dynamics
  • Familiarity with stream functions and their applications
  • Knowledge of differential equations and integration techniques
  • Basic concepts of hyperbolas and their properties
  • Study the derivation of complex potential functions in fluid mechanics
  • Learn about the relationship between stream functions and potential functions
  • Explore methods for solving separable differential equations
  • Investigate the properties of hyperbolas and their applications in fluid flow
Students and professionals in fluid dynamics, mathematicians dealing with differential equations, and engineers focusing on fluid flow analysis will benefit from this discussion.
fr33d0m
Hi All
I'm having some problem with this question and was hoping that someone could help me with it. I think I have the first two bits but the rest I'm totally stuck
For part (ii) I have the complex potential function as (3x^2)/2 - (3y^2)/2 +6y and the stream function as x(3y-6). Is this correct and if so, how do I use these to calculate part (iii). In other words how can i determine the equation of a general streamline for q? Can someone please help me?
"Ignorance is always ready to admire itself. Procure yourself
critical friends."
Nicolas Boileau, 1674
It's been a long time since I have done problems like that but here's how I would do it (perhaps awkwardly):
In the complex plane, writing z= x+ iy, the velocity function, [itex]q(z)= dx/dt+ i dy/dt= \overline{z}+ 6i= x- iy+ 6i= x+ (6-y)i[/itex] which gives the two differential equations dx/dt= 3x and dy/dt= 6- 3y. You can integrate those directly or divide one by the other to eliminate t and get dy/dx= (6-3y)/3x. I would be inclined to go ahead and cancel "3"s. dy/dx= (2-y)/x. That is a separable equation: dy/(2-y)= dx/x and integrating -ln(2-y)= ln(x)+ C or 1/(2-y)= C'x so x(2-y)= C', a family of hyperbolas. That is, except for a factor of 3 which is now incorporated in the constant, what you have for the stream lines. The "equi-potential" lines are always orthogonal to the stream lines so they are given by
dy/dx= -x/(2- y). (2-y)dy= -xdx so 2y- y2/2= -x2/2+ C That is the same as x2/2- y2/2+ 2y= C or x2- y2+ 4y= C' (C'= 2C), the family of hyperbolas orthogonal to the stream lines. That is also, except for the factor of 3, what you have.
To answer (c), determine C' in x(2-y)= C'. For example, the stream line through (0,0) has both x and y= 0 so 0(2-0)= C'. C'= 0 so x(2-y)= 0 which is only satisfied by (0,0) (that's your "degenerate" stream line). The stream line through 1+i= (1,1) has x=y= 1 so 1(2-1)= C'. C'= 1 and the stream line is the hyperbola x(2-y)= 1. From dx/dt= x, we see that, at x= 1> 0, x is increasing. The direction of flow is to the right.
  • · Replies 19 ·
11K
  • · Replies 48 ·
