Solving large #s raised to a large # with the mod function
  • Thread starter Thread starter Fresh4Christ
    Function
This discussion focuses on solving large exponentiation problems using the modulus function, specifically 252^(611) mod 1207 and 8126^(3461) mod 8549. The key takeaway is the application of modular exponentiation techniques to manage large numbers efficiently. The method involves breaking down the exponentiation into smaller, manageable parts and utilizing previously computed powers to simplify calculations. The discussion emphasizes the importance of reducing numbers using the modulus before performing exponentiation to avoid overflow errors in calculators.
  • Understanding of modular arithmetic
  • Familiarity with exponentiation techniques
  • Knowledge of the modulus function and its properties
  • Experience with large number calculations
  • Study modular exponentiation algorithms, such as the square-and-multiply method
  • Learn about the properties of modular arithmetic in number theory
  • Explore Python's built-in pow function for efficient modular exponentiation
  • Investigate applications of modular arithmetic in cryptography
Mathematicians, computer scientists, students tackling advanced algebra problems, and anyone interested in efficient computation methods for large numbers.
Fresh4Christ
Both of these questions are similar but the second is much larger so I thought I would post them both.
Solve:
1) 252^(611) mod 1207
2) 8126^(3461) mod 8549
Well, the most difficult part is that the numbers are so large you cannot just put it in the calculator.
When you mod a number you are just looking for the remainder after you divide.
First I tried just putting it in my calculator and my calculator responded with infinity as the answer, which is not correct.
So I started thinking about what I know about mod's. I know my answer for the first question will be in the quantity 0<=ANSWER<=1206 and my second question will be 0<=ANSWER<=8548.
So I tried to break up the exponent into smaller values such as 252^10 * 252^10 * ... but I realized that this would take really long and for my second question, that method would not be practical. So there has got to be someway to break the number down to a size the calculator can handle. Also the mod function by definition would be a great way to reduce that number if there was some way I could mod the number before taking the exponents when I break it down, but I'm not sure the rules and manipulates required to adjust the problem. There just has to be a better way to solve this type of a problem. Could you help? Thanks.
If you just want to calculate them you can do it this way. Take your first example. Find
252^2 mod 1207=740. Now to get 252^4 square 740 mod 1207.
252^4 mod 1207=829. Now to get 252^8 square 829 mod 1207.
252^8 mod 1207=458. Keep repeating
252^16 mod 1207=953
252^32 mod 1207=545
252^64 mod 1207=103
252^128 mod 1207=953
252^256 mod 1207=545
252^512 mod 1207=103
Now 611=512+64+32+2+1. So you can just multiply the corresponding numbers from the table and reduce mod 1207. If you are clever, you can save even more time. Notice the 16 and 128 entries are the same. So 252^(128-16) mod 1207=1. Can you see how that would help?
  • · Replies 28 ·
