Incline Plane with Friction with one object hanging?
The discussion focuses on calculating the acceleration of two objects connected by a pulley system, specifically a 7.00 kg object on an incline and a 12.0 kg hanging object. The coefficient of kinetic friction between the 7.00 kg object and the incline is 0.250. The derived acceleration for the system is 7.64 m/s², assuming both objects share the same acceleration due to the constraints of the pulley. Participants emphasize the importance of maintaining a consistent sign convention for the forces acting on both objects to ensure accurate calculations.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of friction coefficients and their application in physics
  • Familiarity with pulley systems and tension in ropes
  • Basic trigonometry for resolving forces on inclined planes
  • Study the effects of varying coefficients of friction on acceleration in pulley systems
  • Learn about the dynamics of multiple connected objects in motion
  • Explore advanced topics in mechanics, such as energy conservation in pulley systems
  • Investigate the role of sign conventions in physics problem-solving
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of pulley systems and friction in action.
myelevatorbeat
Find the acceleration reached by each of the two objects shown in Figure P4.49 if the coefficient of kinetic friction between the 7.00kg object and the plane is 0.250
Here is a picture of the problem: http://a496.ac-images.myspacecdn.com/images01/90/l_1488ef92fb0cdcd21ba1febcabca499f.jpg
F=ma
I'm calling the 7.00 kg object M1 and the 12.0kg object M2.
<b>For M1</b>
(Fnet)x=ma
T+mgsin37degrees-fk=m1a
(Fnet)y=ma (a=o)
n1-mgcos37degrees=0
n1=mgcos37degrees
<b>For M2</b>
(Fnet)y=m2a
T-m2g=m2a
T=m2a+m2g
I take this equation and put it in the (Fnet)x equation I got for M1:
m2a+m2g+mgsin37degrees-fk=m1a
m2a+m2g+mgsin37degrees-(0.250)mgcos37degrees=m1a
m2g+mgsin37degrees-(0.250)mgcos37degrees=m1a-m2a
a=m2g+mgsin37degrees-(0.250)mgcos37degrees / (m1-m2)
a=7.64 m/s^s
Now, my question is: It says "Find the acceleration reached by <b>each</b> of the two objects. Now, I know with an ideal pulley the tensions on both side of the equation are equal, but I'm not sure if the acceleration is. I would assume so cause it's one rope and one rope can't move at two different speeds at once, but I could be wrong. So, is that the answer to the acceleration of both blocks or merely the acceleration of the 7.00kg object and there is further work to be done to find the acceleration of the 12.0kg object?
You can assume accelerations are the same... But careful about signs... if you assume the acceleration of M1 is a acting upward to the right... then you must assume that the acceleration of M2 is a downward... so this will affect the signs in your equations.
also here:
<b>For M1</b>
(Fnet)x=ma
I think you should have T - m1gsin37 - fk = m1a. (minus instead of plus)
And since you've assumed that a is upward to the right for M1... it is downward for M2... so
T - m2g = m2(-a)
myelevatorbeat said:
<b>For M1</b>
(Fnet)x=ma
The tension and the component of the weight act in different directions.
In calling the acceleration "a", be sure to use a consistent sign convention for M1 & M2: If M1 accelerates up the incline, M2 must accelerate down.
That is correct and is essential to solving the problem.
  • · Replies 35 ·
