Calculating Uncertainty of g in Propagation of Error
  • Thread starter Thread starter smithg86
    Error Propagation
This discussion focuses on calculating the uncertainty of the damping constant g in the context of a damped harmonic oscillation, represented by the equation y = Ae^(-gt). The user seeks to understand how to incorporate uncertainties in amplitude (A) and time (t) into the calculation of g. The proposed method involves using differential calculus to derive the uncertainty in y based on the uncertainties in A and t, leading to the formula dy = e^(-gt) * {(dA)^2 + A^2 (e^(-2gdt) – 2e^(-gdt) + 1)}^(1/2).
  • Understanding of damped harmonic motion and its mathematical representation.
  • Familiarity with differential calculus and its application in error propagation.
  • Knowledge of exponential functions and their properties.
  • Experience with data analysis tools like Excel for graphing and data visualization.
  • Study the principles of error propagation in physics experiments.
  • Learn about the application of differential calculus in uncertainty analysis.
  • Explore the use of Excel for performing regression analysis and uncertainty calculations.
  • Investigate the effects of varying parameters in exponential decay models.
Students and researchers in physics, particularly those involved in experimental mechanics and data analysis, will benefit from this discussion on uncertainty calculation in damped harmonic oscillations.
smithg86
this is regarding propagation of error for a lab i did:
we measured the amplitude of a damped harmonic oscillation over a time period, taking amplitude measurements every 1 second for 14 seconds. when graphed (by excel), the plot has the form of y = Ae^(-gt), where A is the amplitude, t is time and 1/g = the damping time.
how would the uncertainty of g be calculated, if the uncertainties of A and t are known for each measurement?
i have no idea how to do this.
The effect of an uncertainity in A is simple, if you double A what effect does this have on y ? Similairly if A changed by 10% what effect would this have on y?
T is a bit more complicated but you can always do this experimentally if you can't do the maths.
Calculate y for some value of t, now change t by a small amount and see how y changes.
Do this for a few values and you will see if the change in y is proportional to change in t or some other function.
This is what I did. Tell me if I’m wrong:
Let:
y(A,t) = Ae^(-gt)
uncertainty of A = dt
uncertainty of t = dt
uncertainty of y = dt
then:
dy = {[dy1)^2 + [dy2]^2}^(1/2)
such that:
dy1 = y(A + dA, t) – y(A, t)
dy2 = y(A, t + dt) – y(A,t)
dy1 = dA e^(-gt)
dy2 = Ae^(-g(t+dt)) – Ae^(-gt)
= Ae^(-gt-gdt) – Ae^(-gt)
dy2 = Ae^(-gt) [e^(-gdt) – 1]
dy = e^(-gt) * {(dA)^2 + A^2 (e^(-gdt) – 1)^2}^(1/2)
so:
