Air Puck Correct Method or not
  • Thread starter Thread starter rash219
    Air Method
The discussion revolves around a physics problem involving an air puck tied to a string, which revolves in a circle on a frictionless table while a mass hangs in equilibrium. The participants are examining the tension in the string, the horizontal force acting on it, and the speed of the puck.
  • Participants discuss the calculations for tension and centripetal force, with some questioning the reasoning behind the original poster's approach. There are inquiries about the requirements for determining the horizontal force and the implications of Newton's Third Law.
The discussion includes varying levels of confidence in the original poster's calculations, with some participants affirming the correctness of certain parts while others express uncertainty about the reasoning and the need for additional information regarding angles.
There is a mention of needing an angle to determine the horizontal force, indicating potential missing information in the problem setup.
rash219
Air Puck ! Correct Method or not...
An air puck of mass 0.25kg is tied to a string and allowed to revolve in a circle of radius 1.0m on a frictionless horizontal table. The other end of the string passes through a hole in the center of the table and a mass of 1kg is tied to it. The suspended mass remains in equilibrium while the puck on the tabletop revolves
a. What is the tension in the string ?
b. What is the horizontal force acting on the string ?
c. What is the speed of the puck ?
[tex]\Sigma[/tex]F = m * a
F_c = (m * v^2) / r
a_c = v^2 / r
a.
[tex]\Sigma[/tex]F_y = m * a = 0
T - mg = 0
T = mg = 1.0kg * 9.8m/s^2 = 9.8N
b.
F_c = Tension on th string = 9.8N
c.
F_c = (m * v^2) / r = 9.8N
(0.25kg * v^2) / 1.0m = 9.8N
v = [tex]\sqrt{39.2}[/tex] = 6.3 m/s
Is this correct...THANKS!
You seem to have it under control.
3a. is correct, but it has incorrect --as near as I can tell- reasoning. Just recall Newton's Third Law for centripetal forces. Also, for 3b. it asks what is the horizontal force is; which requires an angle for the center of the system; not certain on how you are supposed to acquire that answer.
Thanks a lot !
very very helpful
