A climber throws 2 stones 1.00s apart and they hit at the same time
  • Thread starter Thread starter ~christina~
    stones Time
The problem involves a climber throwing two stones vertically downward from a height of 50 feet, with the first stone thrown with an initial velocity of 2.00 m/s and the second stone thrown 1.00 second later. The climber observes that both stones hit the water simultaneously, prompting questions about the time taken for each stone to reach the water and the initial velocity required for the second stone to achieve this.
  • Participants discuss the kinematic equations applicable to the problem, with some attempting to derive the time taken for each stone to hit the water and the initial velocity of the second stone. There are questions regarding the treatment of acceleration due to gravity and the initial conditions for each stone.
The discussion is ongoing, with various approaches being explored. Some participants have provided calculations for the time it takes for the first stone to hit the water and the initial velocity of the second stone, while others express uncertainty about the assumptions made regarding the motion of the stones and the implications of their relative velocities.
There is a noted confusion regarding the height measurement (feet vs. meters) and the treatment of initial velocities as positive or negative based on the direction of motion. Additionally, the timing of the throws and the resulting equations are under scrutiny, with participants questioning the adequacy of the information provided to fully resolve the problem.
~christina~
A climber throws 2 stones 1.00s apart and they hit at same time h=50ft
height of cliff = 50ft I think there is enough info now...
A climber climbs a cliff overhanging a calm pool of water and throws 2 stones vertically down 1.00 s apart. The climber then observes that they cause a single splash. The first stone has a initial v of 2.00m/s
a) how long will it take after the release of the stones do the 2 stones hit the water.
b) what is the inital velcocity of 2nd stone if they are to hit simultaneously?
c) What is the speed of each at the instant the 2 stones hit the water?
If I'm not incorrect in which eqzn I used...
then Position as a function of velocity and time...
xf= xi + 1/2(vxi + vxf)t
a.)
d= 50 m ===>since it is starting from 0 if I'm not incorrect and flung downward then the final distance is 50 so it's negative 50...I think
diference in time thrown is = 1.00s
vi stone 1 = 2.00m/s
a= -9.80m/s^2
___________________
xf= xi + vxi (t) + 1/2 (ax)(t^2)
-50m= 2.00t + .5(-9.80m/s^2)
0= 50m+ 2.00t -4.9t^2
through quadradic formula I found that
t= -2.00+/-rad (2.00)^2 - 4*(-4.9)*50
-9.8
and for that I found that t= 3.40s since the neg can't be used as a valid time
_____________________
Then for b)
I equated the 2 equations leaving out vxi for one side and for the time since they say a difference of 1.00s I went and added it to the time found for the first stone and used that but I'm not sure about that. (Assuming that the sencond stone was thrown after the first one) Is acceleration -9.8? since the person is throwing the stone not dropping it I wasn't sure about that.
xi-xf + vxi*(t)+ 1/2*ax*t^2 = xi-xf + vxi*(t)+ 1/2*ax*t^2
stone 1-------------------------stone 2
-50 + 2.00m/s*3.40s + 1/2*-9.80m/s^2*(3.40s)^2= -50 + vxi*4.40s+ 1/2*(-9.80m/s^2)*(4.40s)^2
-99.84= -144.864 + vxi*4.40s
45.024 = vxi*4.40s
vxi= 10m/s
_____________________________
For C.) I don't know how to approach that..which equation do I use?
I know it's a kinematic one but I'm not sure which to use...
Thanks :confused:
Not enough information is given. Enough is given to figure out the velocity and position of the first stone the instant the second stone is thrown (I do that below), and after that point in time you can ignore gravity to find when they meet because they are free-falling (in their own inertial reference frame). But you still can't figure out when they meet because you don't know their relative velocity. Picture the extremes when the second stone is thrown:
1. The second stone is fired downward at an immense velocity, causing the stones to meet almost instantaneously. In this case, the time in the air is 1 second.
2. The second stone is thrown downward with a velocity just barely faster than that of the first stone, and it takes ages for them to meet.
At least you can figure out the position and velocity of the first stone when the second is thrown:
First, I take it you mean the first stone has an initial v of -2m/s (negative because its going down). So...
Vfinal = Vinitial + acceleration * time
V1 = -2m/s + -9.81m/s * 1 = -11.81m/s
And the position (relative to the climber) of the first stone when the second stone is thrown is...
Yfinal = 1/2 acceleration * time2 + Vinitial * time
Y1 = 1/2(-9.81) * 12 + -2 * 1 = -6.905
So when the second stone is thrown, the first stone is falling at 11.81m/s and is 6.9 meters below the climber. At the point the second stone is thrown, the two stones are free falling and we only need to know when they meet, so we don't need to worry about gravitational acceleration. However, when they meet depends on the relative velocity of the first stone, so we don't know when they meet, and thus don't know when they hit, and thus don't know the answers to any of the other questions.
They share the area a and b. So area c and d need to be the same as area e (use the known value of the gradient). Hope it helps!
Another approach that generates an additional relationship (in which case you have two equations with two unknowns):
You can calculate the initial distance, [tex]d_o[/tex], between the two stones and the speed of the first one at the stage that the second one is thrown. Also the relative speed of the two stones stays the same throughout the motion, that is if their initial speed are [tex]u_1,\ u_2[/tex], it follows from
[tex]v_1 = u_1 +gt[/tex]
and
[tex]v_2 = u_2 +gt[/tex]
that
[tex]v_{rel} = u_2 - u_1[/tex]
which is not time dependent. Therefore we can say that
[tex]v_{rel} = u_2 - u_1 = \frac{d_o}{T_{rel}}[/tex]
where [tex]T_{rel}[/tex] is the elapsed time since the second stone were cast until they met (at the surface of the pool).
I don't get it so you say that I can't find out the time they hit the water...
for the relative velocity ... how would I find the value for d and vrel if they are unknowns??
And why can't I use the equationI used before?
I have a difficult time choosing equations.
I forgot to mention that the height of the cliff is 50ft
I was trying to solve the problem without the height. When the height is given the problem becomes much easier!
In post #1 you say:
the intial speed is also downwards so it should also be negative (you forgot the t squared in the last term). If you choose downwards as positive all three terms are positive (you also said that the distance is in feet?). This will enable you to solve the quadratic for the time, say T, it takes the first stone to hit the water.
for part b the second stone takes one second less to hit the water, T - 1 (it was thrown one second after the first one - see the attachment).
They both travel the same distance in these times. So you can equate the two
ut + 1/2 a t^2
for both stones. For the second stone u is unknown, and it is the only unknown in the resulting equation.
-50m= -2.00t + .5(-9.80m/s^2)t^2
t= 3.00s
so since t-1 is the 2nd stone t-1= 3.00s-1= 2.00s
and to find vxi I plugged in for the unknown vxi
0+ vxi*2+ 1/2(-9.80)(2^2)= 0 + (-2* 3) + 1/2 ( -9.8)(3^2)
vxi= -15.25m/s
Is this alright? It looks kind of funny (the number for the velocity I got for the 2nd stone)
_______________________________________________
For C.) where I have to find the speed of each stone at the instant the 2 hit the water?
I think that I plug the numbers I got into the eqzn vxf= vxi + ax*t
If I'm correct then It would be
vxf= vxi + axt
stone 1: t= 3
(-2) + (-9.80* 3)= -31.4m/s
stone 2: t= t-1 = 3-1= 2s
(-15.25) + (-9.8)(3-1)= -34.85m/s
~Thank You~
I also get 3.00 seconds for the time for the first stone to reach the surface of the pool.
vxi= -15.25m/s
seems ok, but you could have made it a bit easier on yourself by just:
-50 = 0 + vxi*2+ 1/2(-9.80)(2^2)
then I get -15.2 m/s on the dot. One would expect that it would need quite a large speed to catch up with the first stone in only two seconds.
The intial speeds seems fine.
On further investigation the relative speeds are not the same at the beginning and end
beginning: 15.2 - 2 = 13.2 m/s
end: 34.8 - 31.4 = 3.43 m/s
It seems it is only true that the relative speed of the objects will be constant throughtout the motion if they are launched simultaneously. That is my "proof" in #4 should include the time difference:
[tex]v_1 = u_1 + gt[/tex]
[tex]v_2 = u_2 + g(t + \delta)[/tex]
so that the relative speed is time dependent:
[tex]v_{rel} = u_2 - u_1 + \delta t[/tex]
So the last part I did was incorrect?
I included the t-1 in the equation though...
No, it is correct. My previous remark that the relative speed of the two stones should stay the same was wrong. That is what I was trying to explain.
Oh okay...Thanks andrevdh! :smile:
11K
