Can Sperm Survive Long Enough to Fertilize an Egg Inside the Vagina?
  • Context: Medical
  • Thread starter Thread starter quasar987
The discussion revolves around the survival of sperm in the context of potential fertilization after ejaculation, specifically addressing the scenario of sperm being transferred from a hand to the vagina. Participants explore the time sperm can survive outside the body and the factors affecting their viability in the female reproductive tract.
  • Some participants suggest that sperm can survive for a few hours outside the body, while others indicate that they can live for about three days once inside the female reproductive tract.
  • There is a discussion about the impact of drying on sperm survival, with some noting that dessication would significantly reduce the lifespan of sperm.
  • Participants question whether the sperm are retained in the ejaculatory fluid or if most of the fluid has been wiped away, which would affect the survival of the sperm.
  • One participant explains that sperm must transition from the ejaculatory fluid to vaginal fluid for survival, mentioning a process called capacitation that is necessary for fertilization.
  • There is a humorous acknowledgment of uncertainty regarding sperm survival, with some participants expressing surprise at the longevity of sperm.
Participants express varying views on the survival time of sperm and the conditions affecting it. While some agree on the general idea that sperm can survive for a limited time, there is no consensus on the specifics of how long they can survive outside the body or the implications for fertilization.
Limitations in the discussion include assumptions about the conditions of sperm transfer, the effects of drying, and the specifics of the capacitation process, which are not fully resolved.
quasar987
Homework Helper
Say, hypothetically, that I ejaculate on a hand, and 5 minutes later, said hand is introduced in a vagina. Are the sperms dead by that time?
Thx
Biology news on Phys.org
Doubtful. It is more like little less than a few hours.
Okay, are you hypothetically retaining the sperm within the ejaculatory fluid, or are you hypothetically wiping most of the fluid away and concerned about the survival of the remaining sperm? Dessication (drying away the fluids) would substantially reduce the survival time. However, in the ejaculatory fluids, or once transferred into the female reproductive tract, sperm can live for several days (about 3 days on average).
Hypothetically, one would be best off washing their hands in such a situation. :wink:
As Moonbear points out, the key factor is whether the ejaculatory fluids remain intact. The sperm will survive in it.
Now, there are other practical factors in play, such as amount of transfer, degree of penetration and such, which will dramatically cut down the odds (of fertilization - which, I presume is the issue here), but the odds are definitely not zero.
Hypothetically.
Ok, that helps a lot.
Basically, since most of the fluid was wiped away and the rest had plenty of time to dry in 5 minutes, a great deal of sperms died. But, since they probably did not all die, and those that made it into the vagina can survive for 3 days, the probability of fertilization is non zero.
And a side question: The way it works is that sperms are shot in the vagina embedded in their ejaculatory fluid. Once inside, however, they must exist this fluid and into some other vaginal fluid, in which they can survive just as well, that paves the way to the ovaries. Correct?
Basically, yes. The process is a little complex, environments acting partly to stymie the invaders and partly acting to aid them, but yes.
I thought they died straight away! :biggrin:
How long sperm live is up to the male. I guess it's all down to luck... :-p
I rather suspect quasar isn't smiling.
If he's worried that much, he should logout and get down the chemist... :-p
Pretty much. The ejaculatory fluid actually needs to be diluted by the vaginal/uterine fluids for a process called capacitation to take effect (something in semen is an inhibitor of this process). Capacitation is a change in the head of the sperm that gives it the ability to penetrate through the membrane of an ovum and fertilize it (primarily an enzymatic process).
11K
