Inelastic collision energy relationship
The problem involves an inelastic collision between a moving electron and an atom at rest, where the goal is to determine the kinetic energy required for the electron to excite the atom into an excited state. The discussion centers around the relationship between kinetic energy and internal energy in the context of this collision.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conservation of momentum and energy in the context of the collision, attempting to relate the initial and final kinetic energies to the internal energy of the atom. There are questions about isolating variables and expressing kinetic energy in terms of other quantities.
Some participants have provided guidance on correcting errors in the setup and equations. There is ongoing exploration of how to express the kinetic energy in terms of the internal energy and the masses involved. Multiple interpretations of the equations are being examined, and participants are actively questioning their algebraic manipulations.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is an emphasis on ensuring that assumptions made during the problem-solving process are valid and correctly applied.
gills
An atom of mass M is initially at rest, in its ground state. A moving (nonrelativistic) electron of mass me collides with the atom. The atom+electron system can exist in an excited state in which the electron is absorbed into the atom. The excited state has an extra, "internal," energy E relative to the atom's ground state.
Find the kinetic energy that the electron must have in order to excite the atom.
Express your answer in terms of E, me, and M.
Inelastic collision:
m1*v1 + m2*v2 = (m1+m2)Vf
and possibly:
[tex]\Delta[/tex]K = Ki - Kf
What I've got so far:
m1*v1 + m2*v2 = (m1+m2)Vf -->
me*ve + (0) = (me + M)*Vf -->
Vf = (me*ve)/(me + M)[tex]\Delta[/tex]K = Ki - Kf -->
Kf = (1/2)(me + M) * [(meve)/(me + M)]^2 --> simplified -->
(me*ve)^2/2(me+M)
Ki = just the Kinetic energy of the electron = (1/2)(me*ve^2 --> so..
(me*ve)^2/2(me+M) - (1/2)(me*ve^2) = E(?.. an assumption) --->
so K_e = (m_e * v_e)^2/2(m_e + M) - E --->
there's the problem, i have v_e in my solution. But first i need to know I'm on the right track which i think i am. Any advice?
You want K_i - K_f = E, since kinetic energy is lost to internal energy.
You are exactly on track, except for the error that I pointed out. Correct that, of course.
Then: Eliminate the v_e in your solution by expressing it in terms of K_e, and then solving for K_e in terms of E and the masses.
Doc Al said:
You want K_i - K_f = E, since kinetic energy is lost to internal energy.You are exactly on track, except for the error that I pointed out. Correct that, of course.
I'm having trouble isolating K_e when i substitute V_e = (2k_e)/m_e
Here's my new eq. as K_i - K_f and V_e in terms of K_e:
K_e =[(m_e *(2K_e/m_e)]^2/[2(m_e + M)] - E ---> I'm having trouble isolating K_e. Is this setup correct? --->
4(K_e)^2/[2(m_e + M)] - E = K_e
That's not quite right. K_e = 1/2 m_e v_e^2 (Don't forget that v_e is squared!)
wow, i keep making dumb mistakes.
I've ended up with this:
K_e = E(m_e + M)/2m_e + M --->
nevermind ^ that.
I got K_e = E(m_e + M)/-M
I don't think the negative sign is correct. I got to check my algebra. What do you think?
The negative sign is not correct. Did you correct the sign error I pointed out in post #2? (Other than that, it's good.)
  • · Replies 27 ·
