Magnitude of thrust of rocket (q50)
The discussion centers around calculating the thrust of a rocket using the formula for mass acceleration (ma) with specific values: (3000-800)*20, resulting in 44 kN. The participant confirms that this approach yields the correct answer but acknowledges not utilizing the thrust equation (thrust = exhaust velocity * dm/dt) or the change in velocity formula (change in velocity = exhaust velocity * ln|initial mass/final mass|). The consensus is that while the method used is valid, it does not fully encompass the complexities of rocket propulsion.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with rocket propulsion principles
  • Knowledge of thrust equations in aerospace engineering
  • Basic logarithmic functions for mass ratio calculations
  • Study the thrust equation: thrust = exhaust velocity * dm/dt
  • Explore the concept of specific impulse in rocket propulsion
  • Learn about the Tsiolkovsky rocket equation for change in velocity
  • Investigate the impact of mass flow rate on thrust generation
Aerospace engineers, physics students, and anyone interested in the principles of rocket propulsion and thrust calculations.
jack1234
For this question:
http://tinyurl.com/ynkshx
I just use ma=(3000-800)*20 =44kN to get the answer, and the answer is correct.
and haven't make use of
thrust=exhause velocity * dm/dt
or
change in velocity=exhause velocity*ln|initial mass/final mass|
So, just want to confirm am I solved this problem with correct approach, if not, what is the correct solution?
That's right. It's not really much of a rocket problem, is it?
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 47 ·
  • · Replies 16 ·
9K
