Torque and Power (looks pretty simple)
  • Thread starter Thread starter odie5533
    Power Torque
The discussion focuses on calculating the torque and lifting capacity of an industrial motor with an output of 225 kW operating at an angular speed of 4260 RPM. The torque developed by the motor is determined to be 504 Nm using the formula τ = P/ω. The calculations reveal that the motor can lift a weight of approximately 77.9 kg at a linear velocity of 147 m/s, although this scenario is deemed unrealistic due to the power requirements and the assumptions made regarding the mass of the drum and cables.
  • Understanding of torque and power relationships in mechanical systems
  • Familiarity with angular velocity and its conversion to radians per second
  • Knowledge of linear velocity calculations from rotational motion
  • Basic principles of force and mass calculations in physics
  • Study the relationship between torque, power, and angular velocity in depth
  • Learn about the implications of mass and radius in torque calculations
  • Explore practical applications of industrial motors in lifting mechanisms
  • Investigate the limitations of theoretical calculations in real-world scenarios
Mechanical engineers, physics students, and professionals involved in industrial motor applications will benefit from this discussion, particularly those interested in torque calculations and lifting mechanisms.
odie5533
(a) Compute the torque developed by an industrial motor whose output is 225kW at an angular speed of 4260 RPM. (b) A drum with negligible mass, 0.660 m in diameter, is attached to the motor shaft and the power output of the motor is used to raise the weight hanging from the drum. How heavy can the motor lift at a constant speed? (c) At what constant speed will the weight rise?
[tex]\omega = 4260 rev/min * \frac{2\pi}{60} = 446 rad/s[/tex]
(a)[tex]P = \tau\omega[/tex]
[tex]\tau = \frac{P}{\omega} = \frac{225000}{446} = 504 Nm[/tex]
(b) This is where I got confused. I'm not sure how to figure this out. The only thing I could think of was [tex]v = r\omega = (0.660 m)(446 rad/s) = 294 m/s[/tex]. But that doesn't answer the question. Any help would be greatly appreciated.
*EDIT* I thought of something:
[tex]\tau = Fl[/tex]
[tex]F = \frac{\tau}{l} = \frac{504 Nm}{0.660 m} = 764N[/tex]
[tex]m = 764 / 9.81 = 77.9 kg[/tex]
77.9 kg moving at 294 m/s.. that sounds incredibly wrong.
I think I'm going about this wrong. Putting a max weight on motor would use up a lot of the power, so it would go really slow, if not just be able to keep the weight from falling. I really don't understand this one at all.
This seems to be fine.
Be careful: if [tex]l[/tex] is the moment arm for the torque, that will be the radius of the drum. The mass will be twice that much.
The linear velocity of the edge of the drum would be (0.33 m)·(446 rad/sec) = 147 m/sec.
Well, let's see if this is remotely credible as an answer. Raising 156 kg at 147 m/sec would require a power of
P = mgv = (156 kg)·(9.81 m/(sec^2))·(147 m/sec) = 225,000 W.
So that does check. It sounds excessive, but recall that 225 kW = 302 horsepower. Consider how fast a '60s "muscle car", which easily massed over 1000 kg, could be pushed up to...
What is a bit unrealistic about this problem is that a motor that powerful used in a winch would not be doing lifting and hauling with massless cables and take-up drums. (I think the drum would also be a bit bigger than 2 ft. across...)
Thanks for the help on the problem, and the explanation of why it's possible, which really helped me understand this problem better. Thanks again!
