Ellipse Circumscribed In Triangle
  • Thread starter Thread starter _FlaMe
    Ellipse Triangle
The discussion centers on the area of a triangle RST formed by tangent lines to the ellipse defined by the equation \(\frac{x^2}{100}+\frac{(y-5)^2}{25}=1\). The area is expressed as \(A(x)=-f'(x)[x-\frac{f(x)}{f'(x)}]^2\), where \(y=f(x)\) represents the upper half of the ellipse. The participants analyze the geometry and slopes of the tangent lines, concluding that the ellipse's symmetry about the y-axis is the only relevant property for calculating the area, as the ellipse itself does not directly influence the area calculation.
  • Understanding of ellipse equations and properties
  • Knowledge of calculus, specifically derivatives and tangent lines
  • Familiarity with geometric area calculations
  • Ability to manipulate algebraic expressions and functions
  • Study the properties of ellipses and their equations
  • Learn about derivatives and their applications in geometry
  • Explore geometric interpretations of tangent lines
  • Investigate area calculations for triangles formed by tangent lines
Mathematicians, geometry enthusiasts, students studying calculus, and anyone interested in the properties of ellipses and their applications in geometric problems.
_FlaMe
Let P(x,a) and Q(-x,a) be two points on the upper half of the ellipse
[tex]\frac{x^2}{100}+\frac{(y-5)^2}{25}=1[/tex]
centered at (0,5). A triangle RST is formed by using the tangent lines to the ellipse at Q and P.
Show that the area of the triangle is
[tex]A(x)=-f'(x)[x-\frac{f(x)}{f'(x)}]^2[/tex]
where y=f(x) is the function representing the upper half of the ellipse.
- I know f'(x) is the slope of the tangent line
- I have the equations for the top half of the parabola as well as the derivation
- I tried doing slope point form but for some reason it didn't work as I kept getting height = f(x)
The ellipse appears to be completely irrelevant to the proposition, except for the purpose of imposing a symmetry about the y-axis. I am going to make one small change and call the points on the ellipse (x_0, a) and (-x_0, a).
I am assuming that the base of the triangle RST is the x-axis, since nothing is given about that in the problem. The tangent lines to the point on the ellipse meet on the y-axis at a point (0, b). Since the slopes on the tangent lines will be +/- f' , the x-intercepts of those tangent lines will be (-b/f' , 0) and (b/f' , 0). Thus the area of the triangle is
A = (1/2) · (2b/f') · (b) = (b^2)/f' .
Now the slope of the tangent line from (0, b) to (x_0, a) is
f' = (a - b)/(x_0) ,
which is negative, which is also evident from the geometry. We can solve to find
b = a - (x_0)·f' = f - (x_0)·f' ,
since a = f(x_0) and I am transferring to the notation of the problem.
Substituting this into our area formula gives
A = { [ f - (x_0)·f' ]^2 }/f'
= { (f'^2)·[ (f/f') - (x_0) ]^2 }/f'
= f' · [ (f/f') - (x_0) ]^2 .
Since I have used the half of the triangle in the positive-x half-plane, f' < 0 , so taking the absolute value of this expression to obtain a positive area will introduce a minus sign.
Nowhere in this does it seem necessary to use any property of the ellipse other than its symmetry about the y-axis.
