Water State in Space: Liquid, Gas, or Freeze? Find out now!
  • Context: High School
  • Thread starter Thread starter kudoushinichi88
    Gas
The discussion revolves around the behavior of water in different states (liquid, gas, solid) when placed in space, particularly focusing on scenarios involving a closed container. Participants explore the effects of temperature, pressure, and radiation from the sun on the phase transitions of water in a vacuum.
  • Some participants propose that if the container remains intact, the water will stay in liquid form due to constant pressure and temperature.
  • Others argue that once outside the spacecraft, the water has no means of heat transfer except radiation, which could lead to cooling and freezing over time.
  • A participant suggests that solar radiation could keep the water warm, while another questions the impact of distance from the sun on this process.
  • Some participants discuss specific cases, such as water in a closed container in dark space potentially freezing due to radiative cooling, while an open container might lead to boiling and freezing simultaneously.
  • There are considerations about the rigidity of the container affecting the water's state, with some asserting that if the container is indestructible and airtight, the water will remain in its initial state unless influenced by external radiation.
  • Mathematical calculations are presented to estimate the rate of cooling for water in a closed container based on its properties and environmental conditions.
  • Participants express uncertainty about the outcomes, particularly in scenarios involving solar radiation and the effects of pressure on phase transitions.
Participants do not reach a consensus, as multiple competing views remain regarding the effects of radiation, pressure, and container properties on the state of water in space. The discussion includes various hypotheses and conditions that lead to different conclusions.
Several parameters remain undefined, such as the exact distance from the sun, the specific conditions of the container, and the initial temperature of the water, which all influence the outcomes discussed.
kudoushinichi88
Let's say you have water in liquid form in a closed container on a spaceship in space. Then you bring the container filled with water out from the spaceship into free space.
Will the water freeze, stay in liquid form or turn into gas?
Assume the container didn't break.
Science news on Phys.org
Assuming the container wouldn't break, the water would stay in liquid form.
The pressure stays the same and the temperature doesn't change as well, so no phase transition for you :).
Assaf
"www.physicallyincorrect.com"[/URL]
Oh, the temperature inside the ship and outside the ship is the same?
Once outside the water has no way of transferring heat - not by convection, nor by conduction (to what? there is nothing in space). It will radiate, but it would take it a looong amount of time to lost its heat energy that way.
What about the radiation from the sun?
It actually doesn't take that long to radiate heat away. If shaded from the sun, it could freeze in a few hours. If not shaded from the sun, solar radiation would probably keep it warm (though I'd have to calculate that to be sure).
So the water can, in fact be either in solid, liquid or gaseous state depending on how much is the container shaded from the sun?
Ah, never said anything about the sun :).
Exactly how far from the sun are we talking about?
(and we ARE talking about OUR sun, right?)
Assaf
As far as I know all material emit electromagnetic radiation because they contain charged particles which accelerate at random directions because of the thermal energy the object has.
If you have an object in a perfect vacuum far far away from any other objects,
why shouldn't it emit electromagnetic radiation ? as i see it - it emits the radiation because of its own properties and not only because of the environment.
I think it even should be cooled faster if it has no other object around it which can reflect back the radiation it emits, or radiate energy back to it.
Does it make sense what I say ?
The water will not change if the container retains its volume, regardless of any influences.
If the container changes volume then it's a whole different ballpark.
eh?
Anyway.. as other people said. What happens to it depends on how much radiation it receives.
Yes this question has way too many undefined parameters to have any meaningful answer, though you could consider a few specific cases.
Case 1. Water in the dark of space in a closed container.
In remote space it is very cold (about 3 degrees k background radiation) so yes the water would cool and freeze if contained in a closed container. The radiative cooling need not be that slow.
Take for example 1 litre of water enclosed in a 10cm per side cube as an example. If the wall material radiates somewhere close to a blackbody then the rate of loss of energy at say 10C (283k) is about 5.7E-8 * 600E-4 * 283^4, which comes to about 21 Joules per second. One litre requires 1000 Joules per degree C of cooling so that’s about one degree every 50 seconds. For a very rough calculation if the one litre started at around 20C to 25C then it could freeze in as little as about 20 minutes.
Case 2. Water in the dark of space in an open container.
Space is close to a vacuum, certainly less than the triple point pressure (about 600 Pa) for water, so an open container of water (at say 20C) would immediately boil if removed from the pressurized space-craft into the (near) vacuum of space. In fact it may even boil and freeze at the same time. That is, it might not boil away completely but instead to partially boil away while leaving a frozen residue (that would eventually sublimate (convert directly from solid ice to water vapour).
Ah, I understand now that water freezes in space far influences such as the sun.
Now I'm interested in the case where our container is somewhere in a geosynchronous orbit above the earth. Will the water stay in liquid form when facing the sun? Will it freeze when Earth is blocking the sun?
Question:Does the water have room to expand and contract as it changes state? Is the container rigid enough to defeat this or allow it?
If the container resists expansion and contraction, the water will remain in whatever state it started in.
Okay, let's assume that the container is full with water and it's rigid and indestructible. So, from my understanding of your post is that the water will stay in liquid form even when sunlight shines upon it?
No.. the water will eventually vaporize then plasmarize if the temperture gets high enough.
Plasmarize?
Okay, let's make give the details of the problems...
Case 1: A rigid, indestructable, transparent, air tight container full with water is floating in deep dark space far from the sun. Initially the water is in liquid form at temperature 25 degrees celsius. Will the water continue to be in liquid form or will it freeze or turn into gas?
From the answers given in previous posts, I understand that the water will radiate away it's heat and freeze in a few hours. Correct?
Case 2: A rigid, indestructible, transparent, air tight container full with water is floating in space. Initially the water is in liquid form at temperature 25 degrees celsius. But this time, it receives radiation from the sun.
Now this one... depending on the amount of radiation, the water will either stay in liquid form or freeze? Since the container full of water and not expandable, the water cannot turn into gas, correct?
Case 3: A rigid, indestructible, transparent, air tight container full with water is floating in deep dark space far from the sun. Initially the water is in liquid form at temperature 25 degrees celsius. This time, the cover of the container is opened. What will happen?
In case 1, the water will stay in liquid form. We see this happen all the time. Water under pressure stays liquid even if heated above the boiling point. Happens in a pressure cooker and undersea thermal vents.
In case 2, the water will stay on liquid form. Water under pressure cannot crystalize, so its stays liquid.
In case 3, the water will boil away. While it's cold enough to normally cause it to freeze, there's no pressure to keep the molecules of water from simply floating away.
Plasmarize?
Correct
Incorrect. If it gets hot enough, it can turn to gas without expanding. We can go all out and place the indestructible container in the core of the sun. The matter there is 150 times more dense than water on earth, and yet it is plasma.
In this case, part of the water would boil immediately, supercooling the rest and leaving behind a hunk of ice.
How can something turn into gas without expanding? The water in the container if heated, wouldn't display the characteristics of a gas, would it? Does that mean it will turn into plasma without going through the gas state?
nanoWatt said:
I think the water would probably be flash frozen in space. Liquid Nitrogen is around -321 degrees F. That is still not as cold as outer space.
Bad comparison. Liquid nitrogen is nothing like the vacuum of space:
1] It has pressure. Vacuum does not.
2] It takes heat by conduction. Vacuum allows only radiative heat transfer. (And, I suppose, ablative heat transfer)
Say, I've always understood that there are only 3 methods of heat transfer: convective, conductive and radiative. Could ablative be considered a fourth?
That's only true for tempertures close to the freezing point. As ice cools, it contracts, until eventually its density is lower than that of water. At this temperture, water can crystalize to ice without expanding beyond its orginal volume. Beyond that, water has several different solid states. If the water is cooled quickly enough (admittedly, that would not be the case here), it can freeze into amorphous ice. In that case, no cryallization is required.
I have wondered that same question before, although I would probably call it something like "state change" rather than "ablative" because "ablative" sounds like it would specifically apply to evaporation and melting, but not condensation and freezing or crystalization.
I think that the key difference between convection, conduction, and radiation and state changes is that the former three can act without a mass transfer, i.e. they are purely energy transfer. On the other hand evaporation etc. are necessarily mass as well as energy transfer mechanisms.
No, I was specifically referring to ablative: the transfer of heat away by physical transportation of portions of the substance containing heat. In the case of the water, the heat is contained in the parts of the water that leave the box.
It seems to me that stage change can only transfer heat via one of the other three (or four) methods.
But I know naught of things thermodynamic.
The OP should give the additional condition: how far is it from the sun?. It's important because temperature of an object in space depends on.
If it is far from the sun (say half a billion miles), then the water inside must be ice. Hope the container can hold because the expansion force is great.
Normal Ice is still less dense than water at absolute zero at normal pressure. If the pressure is high enough, which it will be with a rigid container, otther kinds of ice will form, which can be denser than water. The web page with the most info about this that I could find was:
http://www.lsbu.ac.uk/water/phase.html"
It looks like I was wrong about this. So.. now the conclusion is that it would form a nonstandard ice?
  • · Replies 16 ·
  • · Replies 60 ·
  • · Replies 32 ·
10K
