Calculating Air Drag for Projectiles Lab
This discussion centers on calculating air drag for a projectile lab involving elastic bands. The key parameters include a mass of 0.37 grams and a spring constant (k) of 31 N/m. The initial drag force can be calculated using the equation 1/2 ACdrag p v^2, but to find the average drag force over time, the final velocity must be determined. The average velocity can be calculated as the change in position divided by the change in time, and the final velocity can be deduced through integration of the average value of the drag force function.
  • Understanding of basic physics concepts such as projectile motion and drag force.
  • Familiarity with calculus, specifically integration and average value of functions.
  • Knowledge of elastic potential energy and its conversion to kinetic energy.
  • Experience with measuring and calculating physical quantities like mass and velocity.
  • Learn about the principles of air resistance and drag coefficients in projectile motion.
  • Study integration techniques for calculating average values in physics applications.
  • Explore the relationship between elastic potential energy and kinetic energy in elastic bands.
  • Investigate numerical methods for estimating final velocities in dynamic systems.
Students in physics courses, educators teaching projectile motion, and anyone conducting experiments related to air drag and elastic materials.
bwong
I am unable to calculate air drag for a projectiles lab I am doing.
It involves shooting elastic bands and measuring the distance they travel and compare it to the theoretical distance(with and without friction).
It takes 0.45 seconds for the elastic band to fall and its initial velocity is dependent upon the stretch. I also have measured the mass(0.37grams) and the k value (31 N/m).
the equation 1/2 ACdrag p v^2 is only valid for the initial drag force, but since the projectile loses velocity as time increases, how would i calculate the average drag force. (I also do not know the final velocity)
I have thought about integrating the graph Fdrag v.s V, however, I do not have the final velocity.
The average velocity is easy. It's just the change in position divided by the change in time. You'll need to do this for both the horizontal and vertical components of the motion. You can deduce the final velocity as follows. In Calculus I you would have learned that the average value [itex]f_{av}[/itex] of a function [itex]f[/itex] is given as follows.
[tex]f_{av}=\frac{1}{b-a}\int_a^bf(x)dx[/tex]
Since you know [itex]f_{av}[/itex], as well as the integrand and the lower limit of integration, you can find the upper limit of integration (which in your case will be the final speed).
  • · Replies 24 ·
  • · Replies 31 ·
