Ionic Potentials across Cell Membranes
The discussion focuses on the ionic potentials across cell membranes, specifically regarding the resting potential of neurons, which is approximately -80 mV. It addresses the electric potential energy of sodium (Na) ions outside the cell (0 meV) and potassium (K) ions inside the cell (-80 meV). The participants seek to determine the work done by the electric field during depolarization and repolarization phases, with emphasis on understanding the magnitude and sign of the work done on Na and K ions. The correct approach involves calculating the change in electric potential energy and considering the direction of force relative to displacement.
  • Understanding of neuronal resting potential and ionic concentration gradients
  • Knowledge of electric potential energy and its relation to ion movement
  • Familiarity with the concepts of depolarization and repolarization in action potentials
  • Basic principles of work done by electric fields on charged particles
  • Study the Nernst equation for calculating equilibrium potentials of ions
  • Learn about the role of ion channels in neuronal action potentials
  • Explore the concepts of capacitance and resistance in biological membranes
  • Investigate the effects of different ion concentrations on membrane potential
Students in neuroscience, biophysics, or physiology, as well as educators and researchers interested in cellular membrane dynamics and ionic transport mechanisms.
mtbgymnast
In its resting state, the membrane surrounding a neuron is permeable to potassium ions but not permeable to sodium ions. Thus, positive K ions can flow through the membrane in an attempt to equalize K concentration, but Na ions cannot. This leads to an excess of Na ions outside of the cell. If the space outside the cell is defined as zero electric potential, then the electric potential of the interior of the cell is negative. This resting potential is typically about -80 \rm mV. A schematic of this situation is shown in the figure.
Image 1 http://session.masteringphysics.com/problemAsset/1011446/22/1011446A.jpg
Image 2 http://session.masteringphysics.com/problemAsset/1011446/22/1011446B.jpg
There are 4 parts to this question.
A) Question: During the resting phase, what is the electric potential energy of a typical Na ion outside of the cell?
Answer: 0 meV :smile:
B) Question: During the resting phase, what is the electrical potential energy of a typical K ion inside of the cell?
Answer: -80meV :smile:
C) :rolleyes: During depolarization, what is the work done (by the electric field) on the first few Na ions that enter the cell?
The answer is one of the following:
-40 {\rm meV}
+40 {\rm meV}
-80 {\rm meV}
+80 {\rm meV}
-120 {\rm meV}
+120 {\rm meV}
0 {\rm meV}
D) :rolleyes: During repolarization, what is the work done (by the electric field) on the first few K ions that exit the cell?
-40 {\rm meV}
+40 {\rm meV}
-80 {\rm meV}
+80 {\rm meV}
-120 {\rm meV}
+120 {\rm meV}
0 {\rm meV}
There are 4 parts to this question. I already answered parts A and B, but can't figure out Parts C and D
How do I find the magnitude?
How do I figure out the sign?
The work done on a force is positive if the force and displacement are parallel, but negative if they are in opposite directions. For this problem, the magnitude of the work done is equal to the change in the ions electric potential energy.
I thought for part C the answer was either +40 or -40, but I tried those answers and they were wrong. I thought the magnitude was 40 because of a change from 0 to 40 meV so I'm confused on what the change is.
For part C and D, I do not know the magnitude or the sign of the answer.
Where is the force? I am having trouble figuring out where the force is in relation to the displacement, so I don't know if the answers are positive or negative.
The work done on an object is equal to the magnitude of the object’s change in energy. The energy is the potential energy. For depolarization, the difference in potential energy can only be the initial values because nothing else has occurred yet--->-80meV inside and 0 outside => delta U= 80meV=magnitude of work. The sign is dependent on whether the object is moving in the direction of the force. It is positive, since in an effort to reach equilibrium the Na ions are rushing in, so they are going with the force.
9K
10K
  • · Replies 23 ·
13K
