Thermodynamics - pressure and temp.
The discussion centers on the relationship between pressure and temperature in gases, specifically through the lens of the ideal gas law (PV=nRT). When a helium balloon is cooled, its volume decreases due to reduced molecular kinetic energy, leading to lower pressure. In a setup with two buckets at different temperatures, the gas in the connecting hose does not expand differently because the gas fills its container uniformly, regardless of temperature differences. Understanding these principles is essential for grasping thermodynamic behavior in gases.
  • Understanding of the ideal gas law (PV=nRT)
  • Basic knowledge of thermodynamics concepts
  • Familiarity with molecular kinetic theory
  • Experience with gas behavior under varying temperature and pressure conditions
  • Study the implications of the ideal gas law in real-world applications
  • Explore the concept of kinetic molecular theory in detail
  • Investigate the effects of temperature changes on gas pressure and volume
  • Learn about non-ideal gas behavior and corrections to the ideal gas law
Students studying physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding gas behavior under varying conditions.
Niles
Ok, I'm a little confused about the connection between pressure and temperature. Let's take two scenarios:
1) I have a balloon filled with helium at 30 degrees, and then I put it in the freezer. Then the volume changes, but the pressure stays constant, right?
2) I have the following setup:
http://peecee.dk/upload/view/98728
The two buckets have different temperature - so the gas inside the hose has different temperatures at the sides 1 and 2. But why isn't the volume in part 1 bigger than the volume in part 2? Is that because the pressure is not constant?
I can't quite figure these things out.
Thanks in advance,
sincerely Niles.
Well why does the volume decrease?
More fundamentally, why is the balloon "inflated"? Because the air inside exerts a pressure that causes the fabric to expand and voila, inflated balloon. If you shove in too much air the pressure is too great and the balloon ruptures. Reduce the pressure and the balloon shrinks a bit. Normally you reduce the pressure by letting air out. Cooling it however will slow the molecules in the air, reducing their average kinetic energy, so they're not going to spread out and cover as much space, and the pressure is reduced, which is why the volume decreases
For part B, it's as simple as the two buckets are the same size. You always assume the gas expands to fill its container, so there you have it.
EDIT: So you can infer everything you'd need to know from the ideal gas law. PV=nRT, even if it's not an ideal gas the basic relationships are the same
If you increase pressure while holding volume constant, temperature has to increase(so that the equality holds, you made the left side bigger, n and R are constants, got to make the right side bigger) and similarly for all the relationships. Basically remember that in a gas the temperature is a measurement of average kinetic energy. If there's a high temperature the molecules are bouncing a lot harder and are going to spread out and hit walls harder, meaning increased pressure, unless you allow the walls to expand, then increase volume. If you have gas with a set temperature and you shrink the volume, you have all those molecules with whatever kinetic energy now confined to a smaller space. If you're bouncing off the walls already, and you make the walls closer, you're going to be bouncing harder, and so on
  • · Replies 35 ·
  • · Replies 67 ·
