Right-handed coordinate systems
The discussion centers on the importance of using right-handed coordinate systems in mathematical and physical calculations. Deviating from this convention can lead to incorrect results, particularly in operations involving determinants and cross products. The determinant operator is orientation-dependent, meaning that using a left-handed system will yield negative values compared to the standard right-handed system. While some argue that it is merely a convention, the implications for calculations in fields like electromagnetism underscore its significance.
  • Understanding of coordinate systems, specifically right-handed and left-handed systems
  • Familiarity with determinants and their properties in linear algebra
  • Knowledge of vector operations, particularly cross products
  • Basic concepts in electromagnetism and their mathematical representations
  • Research the properties of determinants in linear algebra
  • Study vector operations, focusing on the implications of using different coordinate systems
  • Explore the applications of right-handed coordinate systems in electromagnetism
  • Learn about the conventions in various fields of physics and mathematics
Students and professionals in mathematics, physics, and engineering who need to understand the implications of coordinate system conventions on calculations and physical phenomena.
ehrenfest
Everyone tells me that I should use right-handed coordinate systems. But no one tells me what happens if I don't. What is the danger of not using right-handed coordinate systems?
What do you mean? How exactly are you going to "use" left-handed coordinate systems?
It's a convention, nothing more. Your signs will be backwards in some calculations.
(The real reason has to do with the fact that the determinant operator is uniquely determined by a basis AND an orientation. If you choose a different orientation than everybody else, your determinant will be the negative of theirs. It's a convention, but it's a convention that really matters. I'm guessing that this doesn't mean anything to you, and you probably just want to label your axes differently when you're graphing stuff. If so, please disregard.)
cross product changes too (related to the change in determinant operator)
many things like electromagnetism etc... motivate the use of right hand system as just a convenient way to present certain physical phenomena. But at the end of the day, it is just matter of convention. nothing else
  • · Replies 30 ·
  • · Replies 24 ·
