Massive objects moving too fast
  • Context: Graduate
  • Thread starter Thread starter Coughlan
The discussion revolves around the gravitational interactions of massive objects moving at relativistic speeds. Participants explore the implications of relativistic mass, gravitational forces, and the relationship between gravity and time, considering both special and general relativity.
  • One participant questions how to calculate gravitational forces between a 1 kg mass moving at relativistic speeds and a stationary 0.5 kg mass, considering whether Newton's law applies.
  • Another participant suggests that gravitational force can be calculated using Newton's formula at a specific instant, but notes that general relativity provides a different framework for such calculations.
  • A participant introduces the idea that gravitational interactions between masses in relative motion may be better understood through general relativity rather than Newtonian gravity.
  • There is a discussion about whether the mass used in calculations should be rest mass or relativistic mass, with one participant expressing uncertainty about the implications of relativistic mass on gravitational attraction.
  • Some participants argue that mass does not increase in a directional sense at relativistic speeds, but rather that mass should be interpreted as a measure of resistance to changes in motion.
  • Another participant emphasizes the importance of using rest mass in calculations and cautions against applying the gamma factor to mass, suggesting that relativistic effects should be viewed in terms of momentum rather than mass changes.
  • There is a mention of the need to generalize Newton's laws to a four-dimensional framework to properly address gravitational interactions in the context of special relativity.
  • One participant asserts that all Newtonian laws can be converted into four-dimensional laws, but with careful consideration of relativistic effects.
Participants express differing views on the applicability of Newton's laws in relativistic contexts, the interpretation of mass at high speeds, and the relationship between gravitational mass and inertial mass. The discussion remains unresolved with multiple competing perspectives present.
Participants highlight the complexity of integrating Newtonian gravity with relativistic frameworks, noting that assumptions about mass and gravitational interactions may vary based on the chosen theoretical approach.
Coughlan
I've been puzzling over this for quite sometime and have not been able to find it anywhere here which is stunning. What if you had a structure that was moving fast enough to have it's relativistic mass be...1 kg for now. And we had this 1 kg mass zipped by something that was 0.5 kg for sake of argument. What would be the "grativistic(sp?)" forces at work here? Should I try and use Newton universal law to figure it out? or would the speed negate any other forces because it is just simply moving too fast. Here's another thought: Is gravity affected by time or is time affected by gravity?
Thank you for reading and if it has already been said please just post a link or a few keywords I can search for. :)
-Coughlan
No, that gravitational force, at a specific instant, would be calculated, in special relativity, by using Newton's gravitational formula with the distance between the objects and their masses at that instant.
I specified "in special relativity" because, of course, general relativity has a completely different way of computing gravity.
I'm not clear on your scenario, but if it involves gravitational interaction between masses which are in relative motion, there is a newer theory than Newton's gravity, called general relativity which deals with this.
Clocks are affected by gravity. Obviously the gravitational field at a certain place may vary if masses are moving nearby.
is this the question?
I think what you're asking is:
Gravitational force depends on mass and distance.
Is that mass the ordinary mass (rest-mass) m, or, for something moving at a very fast speed v, is it the increased mass [tex]\frac{m}{\sqrt{1\,-\,v^2/c^2}}[/tex]?
Erm … I don't actually know the answer to that! :redface:
Well what I was referring to was this. In order to calculate a relitivistic mass you need to take into account its energy. Thus the fast you go the more mass you have. So what if this high speed object with its new mass passes a stationary object half its weight? What happens? Is the second object attracted to the first? I hope that helps
I'm going to take a guess here. From my understanding, at relativistic speeds, an object doesn't gain mass, per se. By that I mean it doesn't gain particles or anything. Gaining mass at high speeds is a bad interpretation because it leads to weird conclusions when you talk about a mass traveling at, say, a 30 degree angle between the x and y axis. Does it gain more mass in the x direction than the y since the velocity component is higher in that direction? As you can see, different masses in different directions of the same object doesn't make much sense. But, if you interpret mass as a quantity that tells you the resistance to change in its trajectory, I think it makes more sense. Then, in my analogy about traveling at 30 degrees, its conclusion would be that it's harder to accelerate the mass in the x direction than in the y direction. So the big point is, if something is going at a relativistic speed in a particular direction, it harder to make that object go any faster in that direction than if it were going at a lower speed. In your question, I assume you're talking about some big object passing beside another big object at a high speed. I think you should break things down into vector components. Let's say object B is at the origin in the x-y plane, and object A is traveling in the y-direction and passed the x-axis at some distance "d" from the origin. Since object A is going beside object B, and the gravitational force is one of attraction, object B wouldn't cause A to go any faster in the y-direction--it's pulling it towards the origin. So the effect would be that object A would gain a velocity component in the -x direction, toward object B. Since object A is not traveling at relativistic speeds in this direction, it's normal mass would be used. If you want the situation of the gravitational pull being in the same direction as the relativistic velocity, you need General Relativity. Special Relativity does not apply to non-inertial frames. Hope this helps.
increased mass is the same for each direction
AcidBathSDMF said:
I'm going to take a guess here. From my understanding, at relativistic speeds, an object doesn't gain mass, per se {snip} different masses in different directions of the same object doesn't make much sense {snip}
Sorry, but this is just wrong. Momentum in each direction is rest-mass times velocity-in-that-direction times the same factor, [tex]\frac{1}{\sqrt{1\,-\,v^2/c^2}}[/tex], where v is the total velocity.
The increased mass, rest-mass times [tex]\frac{1}{\sqrt{1\,-\,v^2/c^2}}[/tex], is the same for all directions.
Yes, but the question is whether B's normal mass would be used. I believe the answer is no, because of the equality of inertial mass and gravitational mass, but that's general relativity, so I'd rather let someone else comment on it.
You are trying to unify Special Relativity with Newtonian gravitation, I guess.
At the moment I have no idea about how doing that, but on one point I am quite sure. Newton's gravity has as framework the Euclidean space and three-vectors, while Special Relativity resides in the space-time (Minkowski space) and uses four-vectors.
So, Newton's law cannot be used as it stands, but needs to be generalized to the four-dimensional case, as one usually does for Electromagnetism, introducing the four-potential A^{\mu}.
However, the generalization of Newton's law to Minkowski space (if it is possible) has not to be trivial!
If we assume it possible, then one uses four-momenta and four-forces and should be able to deal properly with Newtonian gravity.
I think I have been right!
No. All Newtonian laws can be converted into four-dimensional laws. :smile:
You just have to be careful!
Usually, it just involves multiplying the mass by [tex]\frac{1}{\sqrt{1\,-\,v^2/c^2}}[/tex].
In electromagnetism, for example, E and B are parts of a six-component tensor in four-dimensional space, and would be different for an observer with a different velocity, but for any particular observer the usual three-dimensional rules for E and B apply. :smile:
tiny-tim said:
Yes, but the question is whether B's normal mass would be used. I believe the answer is no, because of the equality of inertial mass and gravitational mass, but that's general relativity ...
You will be much better off applying the accepted standard of only using rest mass.
Just ignore any impulse to apply the gamma factor to mass at all to satisfy any apparent effect you think you see from your point of view.
Energy is defined by applying gamma to momentum no more than that is needed.
No need to assume that the momentum value change is the result of a change in any actual mass inside the equation for momentum. Physicist today find it makes much better sense to view the momentum itself as being altered relativisticly by time and distance changes defined in the gamma factor. Those effects are what is important not the idea that it “looks as if the mass changed”. That is all that has happened, the relativistic effects are real. Not what only seems like a change in mass from our point of view.
We apply the "gamma factor", [tex]\frac{1}{\sqrt{1\,-\,v^2/c^2}}[/tex], because the Lorentz equations tell us to. That then tells us what effects will be apparent, not the other way round!
What? :confused:
I don't really understand what you're saying here.
I'm quite happy to accept that there's more than one way of looking at the same mathematics, and which you choose is largely a matter of taste.
My taste is to say that the mass increases. That's perfectly consistent with the mathematics.
If you want to state clearly what your taste is, I'll probably be happy to agree with you that that's fine too. :smile:
I'll just add that if you have two identical boxes containing identical flywheels, one flywheel rotating and one not, and you can't see inside the box, then you'll find that the one with the rotating flywheel is more difficult to push, and you have little alternative but to say that that box has increased mass! :smile:
Electromagnetism is a very special case! In fact Einstein conceived Special Relativity starting from it (in his pioneer work "Zur Elektrodynamik bewegter Körper", "on the electrodynamics among bodies").
He also said that Special Relativity was already contained in Maxwell equations, for which Galileo transformations give problems.
The same problems are absent for Newtonian gravity, so one has to investigate some sort of "gravitodynamics among bodies"! :-)
Namely, which are the relativistic effects in Newtonian gravity? And how do you build the gravitational four-potential?
Anyway, in my opinion the rest mass, being a scalar, should be used as the source of the gravitational force. The gamma factor would enter through Lorentz transformations!
So far as I know, all forces are affected in the same way by the Lorentz transformation.
No, they're there, but gravity is many many orders of magnitude weaker than electromagnetism (think how fast an electron can be accelerated form rest across a cathode ray tune, and how long gravity would take to pull it the same distance!), so nobody noticed them.
Wow thanks for the response. I had no idea that this topic was so unclear. I figured that I was just missing something. I still don't know what to think but it has been a great thought provoking experience non the less!
There's a big problem trying to reconcile Newtonian gravity with special relativity. In Newtonian gravity, two masses exert equal and opposite forces on each other simultaneously. In relativity, there's no such thing as "simultaneous", so if the masses are moving relative to each other, you are in trouble.
I stand to be corrected, but I believe you have no choice but to use general relativity. I'm no expert, but I recall other answers to similar questions saying that, in GR, gravity relates to energy-momentum rather than to (rest) mass. So even photons have some (tiny) gravitational influence.
...I was afraid someone was going to say that. Unfortunately I couldn't do Tensor Calculus to save my life. As a matter of fact I'm barely hanging on with regular calculus. So I guess I'll just have to take your guys' word for it. Thank you for the prompt responses! :)
I agree.
(...and mine is not!)
I would suggest to everyone that when we talk about mass, we should make it clear whether we mean "relativistic mass" (proportional to energy, including kinetic energy) or "rest mass" (="invariant mass"). The modern fashion is for "mass" to mean "invariant mass". In these forums, many readers are struggling to work out what mass is, so we should avoid ambiguity.
Yes, it has increased invariant mass. A rotating flywheel has more invariant mass than an identical non-rotating wheel (one reason why "rest mass" isn't such a good name).
For the benefit of anyone who doesn't know why, the invariant mass mtot of a collection of particles can be defined by
[tex](\Sigma E)^2 = m_{tot}^2 c^4 + ||\Sigma \textbf{p}||^2 c^2[/tex].
which reduces to
[tex]\Sigma E = m_{tot} c^2[/tex]
in the box's frame, where the total momentum is zero. For each individual particle of invariant mass m,
[tex]E^2 = m^2 c^4 + ||\textbf{p}||^2 c^2[/tex], so [tex]E > m c^2[/tex], and [tex]m_{tot} > \Sigma m[/tex].
invariant mass
As you say, invariant mass = rest mass.
And you agree something can have "increased invariant mass".
Which is the same as "increased rest mass"! :smile:
Which is why my taste is to regard mass as increased in all situations!
(And don't forget, there's nothing unusual about rotational motion contributing to invariant/rest mass: the electrons in you and me have very fast rotational motion which does contribute to increasing our "rest mass"! :smile:)
which reduces to [tex]\Sigma E = m_{tot} c^2[/tex] in the box's frame, where the total momentum is zero.
No. If a wheel is rotating so that its rim is moving with speed U relative to the centre of the wheel, and if the whole wheel is moving parallel to its axis with speed V relative to us, then the Lorentz-increased mass (energy) of the rim is the rest-mass multiplied by:
[tex]\Large\frac{1}{\sqrt{1 - U^2}\sqrt{1 - V^2}}[/tex]​
Even in the box's frame, the Lorentz-increased mass (energy) of the rim is still multiplied by [tex]\Large\frac{1}{\sqrt{1 - U^2}}[/tex].
thank you jtbell. I will look when my boss isn't here!
Lorentz equations do not require they be applied to mass.
I did state it – I use gamma on momentum and NOT on mass as most modern science does.
In the rotational case you are comparing the effects of inertia.
Inertia is not defined by changing mass but by Energy, Momentum, and invariant Mass. You are simply attempting to justify changes in Energy and Momentum following relativistic rather than Classical rules by attributing the changes in Energy and Momentum to actual changes in the physical mass of an object.
Most modern practicing science does not find it necessary to use that way of thinking as a crutch to understanding what is going on. They are able to think in terms of Energy and Momentum as being independent things that need to be treated relativisticly, that’s all.
True you can treat Energy and Momentum Classically by correctly applying relativistic effects only to mass, most of modern science just does not do that.
I suppose either way might be OK, with the possible exception that applying it to mass might require using a preferred reference frame- but I’m not sure on that point. Probably not that important a distinction since a preferred frame is desirable to some anyway.
If you want to survey how most scientists think, I think you find I’m correct on how the majority view the issue.
I'll have to rethink my reasoning--thanks for pointing out the troubles. I found a different thread on here that explains what I wanted to say in a much better way. Here is the conclusion, and I'll give a link to the mathematics:
"Given this form of the dynamics equation for special relativity it becomes evident that a mass "changing with speed" is not the correct explanation for why a massive object can not be accelerated up to the speed of light. The mass m here does not change with speed. The correct explanation is that given this law of motion an arbitrary amount of ordinary force produces a diminishing coordinate acceleration as the coordinate velocity approaches c due to the time dilations involved in relating coordinate to four-vector expressions. These time dilations are in turn due to the Lorentzian structure of spacetime(the Lorentzian structure being why we defined the momentum four vector in terms of a Lorentz transform in the first place). So the reason really that nothing with mass can be accelerated up to c speeds in special relativity is ultimately that spacetime has a Lorentzian structure."
https://www.physicsforums.com/showthread.php?t=11072
You've quoted me out of context (and without giving the post's reference).
I was simply denying that I was getting the gamma factor from what you called the "apparent effect", as in:
Sorry … that's too unclear for me to either agree or disagree with.
In the rotational case you are comparing the effects of inertia … {saving space} … preferred frame is desirable to some anyway.
I'm really not following most of this.
For example, you say "They are able to think in terms of Energy and Momentum as being independent things that need to be treated relativisticly" - but Energy and Momentum are most certainly not independent - they're components of the same four-vector, and they get mixed up by the Lorentz transformation in the same way that time and position do.
The simple fact is that "Most modern practicing science" does regard my mass as already taking into account the "increased mass" of the electrons whizzing around inside me. No-one would try to define it or measure it any other way.
physicists make measurements, and give those measured things names
Hi AB! (btw, I wish you'd use paragraphs! :smile:)
AcidBathSDMF said:
{snip} The mass m here {of something accelerating towards the speed of light} does not change with speed. {snip}
Yes, in that the rest-mass or inertial mass is the same for all observers.
But that doesn't help with the case of something with moving parts, which has an increased inertial mass even when the things as a whole is stationary!
I can't see any useful reason for avoiding incorporating the gamma factor to make what is after all a very straightforward physical measurement! :confused:
Ultimately, I think the difference here is between physicists and mathematicians.
For example, mathematicians will say that:
But physicists are entitled to say "we want to relate the maths to things which we, as experimental physicists, can actually measure."
Now, no experimental physicists in their right minds are going to measure the rest-mass of the individual bits of me, or of a vehicle containing a rotating flywheel. They'll measure the mass as a whole, either by weighing or by pushing.
It might be better if they called it the "resistance-to-movement" or "inertia" - but:
it is measured in the same units as mass; and
it is the same for all observers (no gamma factor); and
it can be used as [tex]m_0[/tex] in all equations I know of
so they prefer to give it a name with the word "mass" in it.
Some call it "rest-mass", but that's slightly misleading because it takes account of some parts which aren't at rest.
Some call it "inertial mass", which is probably best because it is a measure of its resistance to movement (which is, of course, the way it is usually measured).
A mathematician may say "you are missing the fundamental nature of the group structure of space-time." :frown:
But a physicist should reply "you are missing the simplicity of your equations, and the necessity of applying them to observable measurements in the actual universe!" :smile:
This thing - whatever we call it - is a perfectly valid measurement, and we are entitled to put brackets in the equations round the terms that describe it, and to defend those brackets against all attacks! :smile:
jtbell said:
The "gravitational field of a moving object" has been discussed fairly regularly here. Note particularly Pervect's posts in the following threads.
https://www.physicsforums.com/showthread.php?t=205073
https://www.physicsforums.com/showthread.php?t=153173
https://www.physicsforums.com/showthread.php?t=150342
Thank you for mentioning this. Yes, it is a frequently asked question, and many of the answers given here have been rather speculative.
There are some fine technical points here which make the gravitational field of a moving mass hard to even talk about rigorously.
If you think of the gravitational field of a moving mass as being like the electric field of a moving charge, i.e. concentrated in the transverse direction, however, while you will be wrong, you won't be far wrong. By "not far wrong", I mean that you'll probably get the right order of magnitude when you translate the not-well-defined concept of "gravitational field" into experiment so you can actually measure it.
I have the feeling from skimming the threads that most posters here aren't even familiar with how relativity treats the electric field of a relativistically moving particle (a much simpler question. See for instance
http://www.phys.ufl.edu/~rfield/PHY2061/images/relativity_14.pdf
and look and numbers above and below 14 in the url to get a fuller treatment.
Lorentz equations on electric field
pervect said:
http://www.phys.ufl.edu/~rfield/PHY2061/images/relativity_14.pdf​
Goodness! That page is one of the most confusing treatments I've seen for a long time. :frown:
It obscures the simple facts that:
(a) electric force in the direction of movement is unchanged ("[tex]E_x = E_x\,'[/tex]");
(b) electric force perpendicular the direction of movement is multiplied by the "gamma factor" ("[tex]E_y = \gamma E_y\,'[/tex]"). :smile:
(And, of course, a magnetic field is also produced "from nothing" - but its effect on the observer is zero, since by definition the observer is stationary, and therefore unaffected by magnetic fields!)
So, using special relativity, the gravity from a moving object at closest approach (so the field is at that moment perpendicular to the line of motion) would be multiplied by the gamma factor: in other words, at closest approach the gravitational mass would equal the "Lorentz-increased mass" (but using general relativity, presumably the answer is different). :smile:
I don't disagree there are important interrelationships between Energy Momentum and Mass.
All I’m saying you do not at all need to assume the something like momentum must be defined by a changing mass. And that most modern applied science does not. That you think otherwise only tells me you haven’t discussed the issue with real scientists to see how modern science actually does this kind of work.
Arguing with me won’t change the facts. And you your opinion will depend on who you listen to. So with that there is no further advice I can give you.
Measuring the mass of something with moving parts
I agree you don't need to, but you can if you want, and it seems both clearer and more consistent with the way physicists actually measure the mass of something with moving parts. :smile:
You haven't answered my (implied) question: when "most modern applied science" measure my mass, do they measure the "increased mass" of the electrons whizzing around inside me (as I say they do), or do they somehow regard the mass or momentum of the electrons separately, and do a calculation different from that of the rest of me? :confused:
which reduces to
I am getting a different result, for a system of particles:
The total energy is:
[tex]E=\Sigma e= c^2 \Sigma \gamma_i m_i[/tex]
The total momentum is :
[tex]\textbf{P}=\Sigma \textbf{p}=\Sigma \gamma_i m_i \vec{v_i}[/tex]
[tex]E^2-(\textbf{P}c)^2=c^4 \Sigma m_i^2 +c^2 \Sigma \gamma_i \gamma_j m_i m_j (c^2-\vec{v_i} \vec{ v_j} )[/tex]
On the other hand:
[tex]Q^2= \Sigma ||\textbf{p}||^2 =\Sigma \gamma_i^2 m_i^2 v_i^2[/tex]
so:
[tex]E^2-c^2Q^2=c^4 (\Sigma \gamma_i m_i)^2-c^2\Sigma \gamma_i^2 m_i^2 v_i^2[/tex]
Comparing with your definition, I arrived to:
[tex]m_{tot}=\Sigma \gamma_i m_i > \Sigma m_i[/tex]
Dependence on velocity of the system as a whole
I'm not following that. :frown:
Anyway, both your formula and Dr Greg's formula are simply working out energy/momentum for a system of particles without any mention of the velocity, V, of the system as a whole.
The question for the "rest mass" or "invariant mass" or "Lorentz mass" or "increased mass" or … of an object with velocity V but with moving internal parts is:
What are the properties of a system of particles of masses [tex]m_i[/tex] and velocities [tex]\vec{V}\,+\,\vec{v_i}[/tex] (where the "+" denotes the relativistic rule for addition of velocities)?
If you work it out (I can't be bothered right now :zzz:), it's:
[tex]E_{tot}\,=\,\frac{M}{\sqrt{1\,-\,V^2/c^2}}\qquad,\qquad P_{tot}\,=\,\frac{M\,\vec{V}}{\sqrt{1\,-\,V^2/c^2}}\qquad,[/tex]​
where M is a constant (= [tex]E_{tot}[/tex] for [tex]\vec{V} = \vec{0}[/tex]). :smile:
(Incidentally, I suspect the original formula came from http://en.wikipedia.org/wiki/Invariant_mass,
where it refers to the total mass of the particles from a decay of one particle as being equal to that of the original particle.)
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 95 ·
  • · Replies 61 ·
18K
  • · Replies 0 ·
