Pluto & Charon's Center of Mass - 6871.5 km
  • Thread starter Thread starter rsala
    Pluto
The center of mass of the Pluto-Charon system is calculated to be 6871.5 km from the center of Pluto. This calculation assumes both celestial bodies have the same average density and treats them as point masses. The initial approach incorrectly used diameters instead of radii, leading to an inaccurate distance measurement. The correct formula incorporates the radii of both Pluto and Charon, adjusting for their respective sizes to determine the center of mass accurately.
  • Understanding of center of mass calculations
  • Knowledge of basic physics concepts such as mass and density
  • Familiarity with unit conversions (km to m)
  • Ability to apply mathematical equations involving summation and ratios
  • Study the concept of center of mass in multi-body systems
  • Learn about gravitational interactions and mass distribution
  • Explore the differences between diameter and radius in physical calculations
  • Investigate the methods for calculating mass based on volume and density
Students studying physics, particularly those focusing on celestial mechanics, as well as educators looking for examples of center of mass calculations in planetary systems.
rsala
Pluto's diameter is approximately 2370 km, and the diameter of its satellite Charon is 1250 km Although the distance varies, they are often about 1.99×104 km apart, center-to-center.
Assuming that both Pluto and Charon have the same composition and hence the same average density, find the location of the center of mass of this system relative to the center of Pluto. answer in km.
[tex]\frac{\Sigma m*r}{\Sigma m}[/tex]
i didnt know how to approach this problem since i didnt know the masses of the objects, so i treated each unit of kg in its diameter as 1 unit of m, so the mass pluto would be 2370,000*M...? (converted all units to meters, not sure if it matters)
so, since the question asks for center of mass relative to pluto center, i don't include plutos m*r since its initial position is 0.
[tex]\frac{1250,000*M*(1.99*10^{4}*1000)}{2370,000*M + 1250,000*M}[/tex]
i guess m can factor out here.[tex]\frac{1250,000*(1.99*10^{4}*1000)}{2370,000 + 1250,000}[/tex]
this equals 6871547 meters, 6871.5 km
this is incorrect, I don't think this is correct because i just have the feeling that i don't know what I am doing here
You made a very simple mistake.
You used the diameter of the objects and not the radius. Treat the objects as point masses, so the distance between the two objects surfaces plus the radius of each object is the total distance between the two.
EDIT: Also, notice that one is bigger than the other (one diameter is 2370km and the other is 1250km). Given this, one will be more massive then the other. How would you figure out how much more massive one is with respect to the other?
  • · Replies 19 ·
13K
