Why is electric field inside a conductor zero?
The discussion revolves around the behavior of electric fields within conductors, specifically addressing why the electric field is zero inside a hollow conductor. Participants explore the implications of external electric fields and the movement of charges within conductors.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the mathematical proof of the electric field being zero inside a conductor and question the conditions under which this holds true. There are inquiries about the implications of external electric fields on charge distribution and the resulting electric field inside the conductor.
The discussion is ongoing, with participants sharing insights and asking for clarification on various points. Some guidance has been offered regarding relevant concepts like Gauss' Law and the Shell Theorem, but no consensus has been reached on the mathematical proof or the conditions necessary for the electric field to be zero inside a conductor.
Participants mention the need for mathematical rigor and the importance of uniform charge distribution for the electric field to be zero. There is also a recognition of the complexities introduced by external electric fields and the polarization of conductors.
zarbanx
i wanted to ask why the electric field inside a hollow conductor zero throughout and not just at the centre.
please explain it mathematically and not logically
Thread moved to homework help.
zarbanx, please tell us what you know about electric fields in the presence of conductors. What happens to the electrical charges in conductors when an electric field is present?
We do not do your studying for you -- you must show some work and effort before we can offer tutorial assistance.
okk as u say well i have done a lot of work and research i know tht there is no electric field inside a conductor bt i am not able to prove it mathematically and moreover electrical charges in conductors move to the surface becoz no electric field is there in a conductor becoz if there is a field then charges will move to neutralizze it.when an external electrical field is present then charges rearrange tso that no electric field is there in the conductor bt still mathematically i am not able to prove it
Well, if you open up your textbook, and skim to the sections on Gauss' Law and spherical distributions of charge, do you see some hints about what is going on with a hollow conductor? What kind of boundary condition volume is typically used with Gauss' Law?
Since electric charges are free to move in a conductor in response to an Electric field, what will the charge distribution look like on a hollow conductor when embedded in an electric field?
That should be enough hints to get you going. If your textbook isn't showing this to you for some reason (which text are you using?), try searching some at wikipedia.org
i am using resnick and halliday
Well H&R definitely talks about this. Remember, we do not do your work for you. Post your work, and we can offer tutorial help.
The field is zero inside only if any charge is evenly distributed on the surface. That's a mathematical theorem, sorry I don't have the proof handy. But when you measure the electric field inside a charged sphere, the charge you use might be large enough to redistribute the surface charge. In this case the electric field will not be zero. Only if you measure at the centre.
Now, what happens if there is an external field that is causing a redistribution of surface charges, I don't know. It may be another just as unexpected theorem. If you find proof for this, let me know.
There is an analogy to this that you might find helpful; it has to do with the gravity force acting on a person inside a hollowed-out shell of a planet. By symmetry the force must be zero when a person is at the center, but it is not so intuitive to see that the force is zero everywhere inside the shell. Isaac Newton used what is called "Shell Theorem" to rigorously prove some important things about spherical shells, one of which is what I mention above, and another of which is that any spherical object can be modeled as a point mass when you are located outside the object.
So go to Wikipedia as berkeman suggested, and read about Shell Theorem. You will find more than enough mathematical rigor, believe me. And since gravity and electrostatic force are both inverse-square forces, the methods are almost the same for analyzing a conducting spherical shell. From there move on to non-spherical shells, if you like.
okk thanks i was thinking tht electric field cease to exist inside the shell bt now i know tht they mutually cancel out...right
prob solved bt ulysses said tht charge's uniform distribution is necessary for electric field to be zero inside the sphere .....is tht necessary?
Yes, Shell Theorem relies explicitly on a uniform distribution of mass/charge/whatever. If a thin spherical plastic shell had a small section made of lead, for example, that section would clearly exert a stronger force on a person inside and ruin the symmetry.
that means in an external field there can be a net field inside the hollow conducting shell
Merryjman, are you familiar with the math involved in here? I have got stuck in another similar problem:
https://www.physicsforums.com/showthread.php?t=212711
I'm not sure that's true. What happens in an external field is that the conductor will become polarized, and it polarizes in such a way that the field inside is still zero.
The thing is, proof for this statement still eludes us. It is certainly quite unexpected, as unexpected as the Shell Theorem, so I'd appreciate some proof.
I wrote some of the Wikipedia article on Shell Theorem, so I am familiar with most of the math. I'll look at that thread.
As far as the conductor goes, I'd have to look in Griffiths to find a rigorous mathematical proof (I seem to remember LeGendre polynomials being a part of this), but I can at least hand-wave it. Since electrons on a perfect conductor are completely free to move, they are going to rearrange themselves until they are in equilibrium. The presence of an external field is going to make electrons move upfield because they are being attracted to (or repelled from) whatever charge distribution set up the external field. That's just a consequence of Coulomb's Law, which can't be proved - this so-called "Law" is based on experimental observation of the force between charged particles, not on any sort of mathematical construct. Newton's "Law" of gravitation is the same - it was based on observational data, and more modern data have shown that NULoG is incomplete; hence general relativity.
If the electric field inside a conductor was NOT zero, then there would be a force acting on the mobile charges, and so they would rearrange until the force WAS zero.
It's conceivable the total force is zero on the surface, where each infinitesimal charge sits, and non-zero inside.
But if the force was non-zero inside, charges would still be moving, and the situation would not be electrostatic. Electric fields are nonzero in current-carrying wires, for example. If you were looking at the conductor at the instant the external electric field was applied, there would be internal fields and currents as the charges rearranged.
Why? The field inside need not be identical to the field on the surface. Might be zero inside and non-zero on the surface or vice versa when equilibrium is reached.
In fact an electron on the surface might experience no net force (in equilibrium) but still produce a field of its own in its vicinity. So equilbrium of electrons does NOT imply zero electric field around them.
Inside a conductor, charges are free to move. If there were a non-zero field there, they'd move. (They move until the field is canceled.)
In equilibrium there are no charges inside. So electric field inside can be non-zero in equilibrium (under the influence of an additional external field).
Even without an external field, if the object is not spherical the electric field inside will be non-zero, in equilibrium. That's for a charged object of course.
Ulysees said:
In equilibrium there are no charges inside. So electric field inside can be non-zero in equilibrium (under the influence of an external field always).
Why do you say that there are no charges inside a conductor? There is no field inside a conductor.
Wrong again. On what basis do you say this? The field inside a conductor does not depend on the shape of the conductor.
True, but it does imply zero NET field, in terms of vectors. The electric fields you speak of, produced by the polarization, would serve to balance the external field.
Again, the important thing to remember here is that in order to analyze this electrostatics problem, all charges must be in equilibrium and therefore at rest.
Perhaps what is giving you trouble is that electrostatics is a fictitious world. If a conductor were placed inside an external field, and not held at rest, then the subsequent polarization would cause the conductor to move. But in electrostatics objects are assumed to be fixed in space.
Doc Al I am sorry, but you are saying incorrect things and in a patronizing way. It is well known that charges accumulate on the surface of a conductor when equilibrium is reached. Shall I dig up the relation between curvature and charge density, or you agree now?
So in equilibrium there is no charge inside. And electric field can be non-zero, which it will be if the object is a cube say.
If you put a charge inside any object, you'll have to hold it there, otherwise the charge will go to the surface. It will move under the influence of the non-zero field caused by the other charges redistributing on the surface.
Except if the object is a sphere and you hold it at the centre, no re-distribution of surface occurs then and the charge you put stays at the centre of the sphere itself.
Imagine just 4 electrons in a circular disk. They'll form a square. Each will be in equilibrium. But in the vicinity of each electron the e-field will be non-zero. Shall I draw a diagram and calculate the e-field somewhere in the middle between electrons, on the surface?
I admit (and apologize) for being a bit patronizing. But it's you who are saying incorrect things. OK, you mean no NET charge within the conductor. I'll give you that one.
In electrostatic equilibrium, the field within a conductor is zero. Regardless of shape. Don't think so? Tell us why.
I'm not understanding the relevance of this to the fact that the field within a conductor is zero. (Of course if you start sticking charges inside it you've destroyed equilibrium.)
You can think of the field within the conductor as composed of two contributions: (1) The field from some external source (if any), and (2) The field from the surface charges. They add up to zero.
Doc knows more physics than you and I will probably ever know, so be careful. It sounds like no amount of discussion will dissuade you from your position, so I will leave you to your own devices. Good luck!
Then I'll have to draw you a diagram of 4 electrons in a circular disk. Diagrams are so much easier to clarify things.
Back in a bit.
