Calculating the Volumetric Strain for a Rectangular Steel Bar
  • Thread starter Thread starter cicatriz
    Strain
The discussion focuses on calculating the volumetric strain of a rectangular steel bar subjected to various forces. The bar dimensions are 250 mm in length, 50 mm in width, and 25 mm in thickness, with a compressive force of 450 kN and tensile forces of 450 kN and 45 kN applied on different faces. The calculated stress values are \sigmax = -0.036 kN/mm², \sigmay = 0.072 kN/mm², and \sigmaz = 0.036 kN/mm², leading to strain values of \epsilonx = 3.6x10^{-4}, \epsilony = -3.204x10^{-4}, and \epsilonz = 1.332x10^{-4}. The correct formula for change in volume is identified as ΔV=V₀[(1+ε₁)(1+ε₂)(1+ε₃)-1], which indicates that the previously calculated change in volume of 25.92 mm² is incorrect and should be approximately double that value.
  • Understanding of Hooke's Law and its application in material mechanics.
  • Familiarity with stress and strain calculations in solid mechanics.
  • Knowledge of volumetric strain and its significance in material deformation.
  • Basic proficiency in using equations for calculating changes in volume under applied forces.
  • Study the derivation and application of Hooke's Law in three-dimensional stress states.
  • Learn about volumetric strain calculations in different loading conditions.
  • Explore the effects of Poisson's ratio on material deformation.
  • Investigate the relationship between hydrostatic pressure and volumetric strain in materials.
Mechanical engineers, materials scientists, and students studying solid mechanics who are involved in analyzing stress and strain in structural components.
cicatriz
A rectangular steel bar has length 250 mm, width 50 mm, and thickness 25 mm. The bar is subjected to a compressive force of 450 kN on the 250 mm x 50 mm face, a tensile force of 450 kN on the 250 mm x 25 mm face, and a tensile force of 45 kN on the 50 mm x 25 mm face.
(a) Find the change in volume of the bar under the force system.
The forces can be assumed to be uniformly distributed over the respective faces.
Take E = 200 kN/mm[tex]^{2}[/tex] and Poissons ratio = 0.26
I have calculated [tex]\sigma[/tex]x = -0.036 kN/mm[tex]^{2}[/tex], [tex]\sigma[/tex]y = 0.072 kN/mm[tex]^{2}[/tex] and [tex]\sigma[/tex]z = 0.036 kN/mm[tex]^{2}[/tex].
With these values, using Hooke's Law: [tex]\epsilon[/tex] = 1/E[[tex]\sigma[/tex]1 - [tex]\upsilon[/tex]([tex]\sigma[/tex]2 + [tex]\sigma[/tex]3)] I have calculated:
[tex]\epsilon[/tex]x = 3.6x10[tex]^{-4}[/tex], [tex]\epsilon[/tex]y = -3.204x10[tex]^{-4}[/tex] and [tex]\epsilon[/tex]z = 1.332x10[tex]^{-4}[/tex].
Furthermore, using the equation for volumetric strain: [tex]\nabla[/tex]V/Vo = [tex]\epsilon[/tex](1-2[tex]\upsilon[/tex]) I have calculated the change in volume to be 25.92 mm[tex]^{2}[/tex]. This, according to the answer I have been provided with, appears to be incorrect.
I would appreciate any guidance with this.
Hi cicatriz, welcome to PF. Try using this equation for change in volume:
[tex]\Delta V=V_0\left[(1+\epsilon_1)(1+\epsilon_2)(1+\epsilon_3)-1\right][/tex]
I'm not sure how the other one was derived (hydrostatic pressure maybe?) but it doesn't look right. I checked your strain values and they look fine. The change in volume should be about twice what you got previously.
12K
