What are Ampere-turns and Ampere turns per meter?
  • Context: High School
  • Thread starter Thread starter jearls74
Ampere-turns (NI) is a unit used to measure the magnetomotive force of a current-carrying coil, calculated by multiplying the number of turns (N) by the current in amperes (I). The strength of the magnetic field increases with more turns of the coil, as each loop contributes to the overall magnetic field. Ampere-turns per meter quantifies the number of ampere-turns per unit length of the electromagnetic coil, providing a standardized measure for comparing different coils. Understanding these concepts is crucial for applications in electromagnetism and device design.
  • Basic understanding of electromagnetism
  • Knowledge of electric current and magnetic fields
  • Familiarity with coils and their properties
  • Mathematical skills for applying the formula F = NI
  • Research the applications of electromagnetism in modern devices
  • Study the principles of magnetic field strength and its measurement
  • Explore the design and construction of electromagnets
  • Learn about the relationship between current, turns, and magnetic fields in practical scenarios
Electrical engineers, physics students, and professionals involved in designing electromagnetic devices will benefit from this discussion on ampere-turns and their significance in electromagnetism.
jearls74
could someone please explain in simple terms what ampere-turns and ampere turns per meter means?
Electromagnetism:
It has been found that an electric current sets up a magnetic field
similar to that produced by a permanent magnet. This action is known as
Electromagnetism and is very important in many devices. A desirable
feature of electromagnetism is that it is possible to control the strength
and polarity of the magnetic field. When current exists in a coil, the coil
has all the magnetic qualities of a permanent magnet and is called an
Electromagnet. If this electromagnet is brought near a permanent
magnet or another electromagnet, the like and unlike poles react exactly
as explained for the permanent magnets. Moreover, an increase of current
in the coil increases the strength of the magnetic field, and a decrease
of current weakens the field.
Ampere-Turns:
When the number of loops or turns of the coil is increased and the
current remains the same, the strength of the magnetic field increases.
Each loop or turn of the coil sets up it's own magnetic field, which unites
with the fields of the other loops to produce the field around the entire
coil. The more loops, the more magnetic fields unite and reinforce each other
and, as a result, the total magnetic field becomes stronger.
To compare the magnetic strength of different coils, and to obtain
a basis for measuring the magnetomotive force of an electromagnet, the number
of turns of wire is multiplied by the number of amperes of current carried
by the wire and the result is called Ampere-Turns (NI). The ampere-turn
is the unit for measuring the magnetomotive force of a current-carrying
coil. In a formula, the magnetomotive force in ampere-turns can be expressed
as:
F = NI
F = magnetomotive force in ampere-turns
N = number of turns
I = current in amperes
For example:
A coil with 10 turns and a current of 10 amperes has an F of 100
ampere-turns.
The above excerpted from: http://ourworld.compuserve.com/homepages/boyce_smith/magnets.htm
Ampere-turns per meter is just as it reads, the number of ampere turns per length of the electromagnetic coil.
Chris
very good explanation
thanks chris, that explained it very clearly
