RIemann-Weyl formula and application
  • Context: Graduate
  • Thread starter Thread starter mhill
    Application Formula
The Riemann-Weyl formula relates sums over the non-trivial zeros of the Riemann Zeta function, specifically under the assumption that the Riemann Hypothesis holds true. The formula is expressed as: ∑_t f(t) = f(i/2) + f(-i/2) + 2g(0)π - (2π)^{-1} ∫_{-∞}^{∞} dr f(r) (Γ'(1/4 + ir/2) / Γ(1/4 + ir/2)) + ∑_{n=1}^{∞} Λ(n) n^{-1/2} g(lon). The convergence of this formula is contingent upon the existence of the Fourier transform of the function f(x). The discussion raises the question of the conditions under which the Riemann-Weyl summation formula can be applied, particularly when f(x) is a function and g(u) is its Fourier transform.
  • Understanding of Fourier transforms and their properties
  • Familiarity with the Riemann Hypothesis and non-trivial zeros of the Riemann Zeta function
  • Knowledge of the Riemann-Weyl formula and its mathematical implications
  • Basic concepts of complex analysis, particularly related to the Gamma function
  • Study the properties of the Fourier transform in relation to convergence criteria
  • Research the implications of the Riemann Hypothesis on the distribution of Zeta zeros
  • Explore advanced applications of the Riemann-Weyl formula in analytic number theory
  • Investigate the role of the Gamma function in complex analysis and its applications in summation formulas
Mathematicians, theoretical physicists, and researchers in number theory interested in the Riemann Hypothesis and its applications in Fourier analysis and complex functions.
mhill
given a real function 'f' so the Fourier transform of f(x) exists and assuming Riemann Hypothesis is true so all the non-trivial zeros of Riemann Zeta are of the form 1/2+it then the Riemann-Weyl formula
[tex]\sum _{t} f(t) = f(i/2)+f(-i/2)+2g(0)\pi- (2\pi)^{-1} \int_{-\infty}^{\infty}dr f(r) \frac{ \Gamma '(1/4+ir/2) }{\Gamma (1/4+ir/2)}+ \sum _{n=1}^{\infty} \Lambda (n) (n)^ {-1/2}g(lon)[/tex]
the first sum run over the non-trivial zeros, my question is if all the zeros are 1/2+it with 't' real number , the only condition for Riemann-Weyl formula to converge is that the Fourier transform of f(x) , which can be a function or a distribution must exists ? , under what conditions can be apply Riemann-Weyl summation formula? , if f(x) is a function g(u) is its Fourier transform
Lets clarify this. The question is confusing. Please use more simple sentences if you can.
Sorry Ramsey , my question was
I have given a formula (Riemann Weyl formula) that relates a sum over the imaginary part of the zeros of Riemann zeta that are in the form 1/2+it
assuming Riemann Hypothesis is true so all the 't' are real, i think that the formula is correct in case the Fourier transform of f(x) exists but i am not sure.
for example if i wan to obtain the sum of [tex]e^{-t^{2}}[/tex] where 't' runs over the imaginary part of all Zeta zeros in the form [tex]\zeta (1/2+it)=0[/tex] , assuming RH is real could we use the Riemann-Weyl formula ? that was all thanks.
  • · Replies 26 ·
  • · Replies 16 ·
