Divergence Theorem and Incompressible Fluids
The discussion centers on the application of the Divergence Theorem to incompressible fluids, specifically the proof of the equation \(\nabla \cdot u = 0\). The user references a paper by Bridson, which outlines the relationship between the volume of a fluid and its boundary surface. The key conclusion is that the integral over the boundary surface \(\int \int_{\partial \Omega} u \cdot n = 0\) leads to the result \(\int \int \int_{\Omega} \nabla \cdot u = 0\), demonstrating that the divergence of the velocity field \(u\) is zero when the volume remains constant.
  • Understanding of vector calculus, particularly the Divergence Theorem
  • Familiarity with fluid dynamics concepts, especially incompressible flow
  • Knowledge of integral notation and operations in multiple dimensions
  • Ability to interpret mathematical proofs and notation in academic papers
  • Study the Divergence Theorem in detail, focusing on its applications in fluid dynamics
  • Explore incompressible fluid flow equations and their physical implications
  • Review advanced vector calculus techniques, including triple integrals and surface integrals
  • Analyze the paper by Bridson for deeper insights into fluid volume and boundary relationships
Students in mathematics or engineering, particularly those studying fluid dynamics, as well as researchers and professionals working with incompressible fluid models and vector calculus applications.
Bucky
Hi, I'm trying to follow the proof for the statement
[tex] \nabla . u = 0[/tex]
I'm basing it off this paper:
http://delivery.acm.org/10.1145/119...GUIDE&dl=GUIDE&CFID=25582973&CFTOKEN=82107744
(page 7, 8)
In case that's not accessable (I'm in university just now, and I'm not sure if that's a subscriber only paper) I'll write what I've got.
so they start off with defining a fluid volume [tex]\Omega[/tex], and it's boundary surface as [tex]\partial \Omega[/tex], then defining the rate of change around this volume as
[tex]\frac{d}{dt} Volume(\Omega ) = \int \int_{\partial \Omega} u.n[/tex]
The volume should stay constant, thus
[tex]\int \int_{\partial \Omega} u.n = 0[/tex]
from this step they mention the divergence theorem, then jump to
[tex]\int \int \int_{\Omega} \nabla .u = 0[/tex]
It's this last jump I don't follow. From http://mathworld.wolfram.com/DivergenceTheorem.html" , I figured the divergence theorem changed to fit this problem would be..
[tex]\int_{\Omega } (\nabla .u) d\Omega = \int_{\partial \Omega} u.da[/tex]
they've dropped [tex]d\Omega[/tex] and gained two integrals, and I don't follow how they did this.
I'll admit that their notation isn't really intuitive. Basically, they chose to omit the variables of integration since integration of the surface and volume is implied by the double and triple integrals. However, you should note that what you have,
Is identical to what they have,
Since,
As I said previously, they have simply chosen not to write [itex]d\Omega[/itex] and [itex]dA[/itex], which is acceptable but can be confusing.
