Designing a Reclining Binocular Chair: Ideas and Techniques
  • Thread starter Thread starter Saladsamurai
    Building Ideas
The discussion revolves around designing a reclining binocular chair, focusing on mechanisms for reclining and raising/lowering the chair. Participants explore various ideas, techniques, and materials for achieving a smooth and controlled reclining motion, as well as the integration of binocular mounts.
  • One participant suggests using a hand crank mechanism with a spiral jack to raise and lower the chair slowly.
  • Another participant describes a hinge-based system with ridged circles that allows for reclining by pulling a handle, but expresses concern about the smoothness of the motion.
  • Some participants propose using electric motors from car seats for a more effortless reclining mechanism, discussing the feasibility and comfort of using the entire car seat.
  • A suggestion is made to use a screw jack directly attached to the chair for a simple and effective lifting mechanism, with the potential to power it with a cordless drill.
  • One participant mentions the importance of controlling the range of inclination and suggests using secondary leverage or gearing to achieve desired angles.
Participants express a variety of ideas and preferences regarding the mechanisms for reclining and raising the chair. There is no consensus on a single approach, and multiple competing views remain on the best method to achieve the desired functionality.
Participants discuss various mechanisms and their implications, including the need for smooth motion, the practicality of using existing components, and the potential for modifications. Some ideas may depend on specific designs or materials that have not been fully explored.
Individuals interested in DIY projects, mechanical design, or those looking to create custom furniture solutions may find this discussion beneficial.
Saladsamurai
Okay so completed a similar project the other day,but I am addicted now.
I built a parallelogram binocular mount similar to this.
Now I am trying to come up with ideas for a binocular chair...like this
I would like to make the chair recline though. This is where I need help. I need to make it so goes up and down slowly (since in my design, the binos will be attached directly to the chair) , perhaps by use of a hand crank.
I was thinking of using some kind of spiral jack or something...
It needs to be cheap and the premise should be something along the lines of, I turn a crank and it raises or lowers a cylinder or something to that effect.
Any ideas are appreciated and images of those ideas too if possible.
I am also going to use a similar method to make the chair rotate about the vertical axis too.
You will notice that most chairs do their reclining feature through the use of pulling a handle and allowing you to freely recline the chair while you hold that handle, and it relocks when you release it.
So what you do is you use a hinge, and you attach a ridged circle at the end, and then you attach another ridged circle that locks with the hinge, and connect it to a handle that has a pivot just before the second ridged circle, and a spring to keep it in place until moved. Then pivoting the handle will allow you to recline.
NOTE: I'll draw you a diagram and attach it in a few minutes.
Though the simplicity of the idea is attractive, the motion needs to be very slow and controlled. The motions cuased by this kind of mechanism, I believe, would be too jagged.
Thanks though!
Actually, it would not be jagged at all, as in pulling the handle, it would release the two ridged circles, and if you add a small amount of friction between the chair and the area that reclines, the movement will actually be very smooth.
(The drawing is terrible btw, so interpret the best you can)
You can buy one of those reclining chairs (or get a broken chair from somewhere) .. remove the base (those wheels) and just hammer it into your system
Is that something that PF does automatically...or did you really just link me to a definition of friction?:smile:
Any ideas on the hand crank mechanism?
No. PF did that automatically.
I'm a really lazy bastard, so I'd go electric. There's nothing like good old scrap-yard power seat packs for strong, fluid movement. Of course, you need a 12VDC power supply, but that's never been a problem for me.
I had this idea too, I think. You mean getting pulling a motor out of a car seat? What do these look like after you remove one from the actual seat? Is it easy to convert for my purpose?
I don't know whether or not they're all the same. The jaw-drive mechanism for my 'Alien' Hallowe'en costume was the 6-way pack from a '65 Mustang. It's essentially 3 motors in one case, with cable drives off of both ends of all 3 rotors. For my purposes, I removed 2 of the rotors, which still left it weighing at least a kilo. (That left me truckin' around with about 15 kg of steel on my head, but I had it suspended on springs from a welding helmet harness, so it was painless. :biggrin:)
The pack itself was about 50% larger than a package of Smokies. (Maybe twice as big as a pack of wieners.)
these above mentioned measurements are standards from National Bureau of standard weights and measures. (Danger, your my hero)
instead of getting the electric motors from a car seat, why not use the whole car seat? everything is already there, just need power. pretty comfortable too
That's pretty much the way that I was thinking, although not all functions are necessary for the purpose. One advantage is that you can snipe the control buttons from the driver's door panel while on site. That can save a couple of bucks down the road.
Needs to be portable. I think I have ruled out the seat pack.
I am thinking of using some sort of combination of springs and dampeners...like a screen door or something...
I open to more suggestions...
If you want super simple, how about a car jack, i.e. screw jack, directly attached to the back of the chair? If you wanted, you could increase complexity by putting a right angled drive in the back, then run one end up to the back of the chair and then the other out the front between the legs of the person sitting in the chair. Then you could even look into providing a drive to attach a cordless drill to power it.
http://img.directindustry.com/images_di/photo-p/214004.jpg
Good idea, Fred. A screwjack is probably my favourite actuator mechanism for just about any purpose that doesn't require high speed. Awesome torque and controllability, and just about bullet-proof.
I like this idea...hopefully I can find a decent jack at the scrapyard for short money.
Thanks
I found one online. It goes from min height of 6.4" to max height of 13.5"
I am wondering if this what the best range of inclination I can get out of this will be.
Taking the horizontal as a reference axis and sitting upright to be 90 degrees.
Sitting at 90 and laying at 0 degrees are unnecessary.
Hmmm. Time to get out some paper here to see what the compromise will be.
No need to compromise, pal. You can always add secondary leverage or gearing to your primary unit to obtain the results that you want.
Could you elaborate on what you mean? I know there is a way around this...
I am thinking something like this
Where the circle is a hinge and where the length of the overhanging portion d is part of the back rest (all one piece). By changing the length of d and having the actuator act at the end of d i can vary the range of the angle of inclination.
I think this is a simple but effective idea. I like simple...less can go wrong...supposedly.
(remember when images actually showed up in threads? not just links to them...what gives?)
Can anyone tell me about http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100595199&langId=-1&catalogId=10053&ci_src=14110944&ci_sku=100595199&cm_mmc=1hd.com2froogle-_-product_feed-_-D25X-_-100595199"?
What does it mean 2 stages?
W insisted upon hosting a BBQ for the the whole neighbourhood tonight, so I'm afraid that I'm far too drunk to address this right now. I'll take a crack at it tomorrow.
How about a set of bicycle cranks to operate the mechanism hands-free?
I planned on using the sprockets from a bike to operate the rotational aspect of the chair.
However, using the actual pedals with my feet was not something I had thought of. This is a great idea that I may use! thanks!
That's actually kind of cool! I've never seen a screw-jack in that configuration before; it looks like a hydraulic bottle jack. It appears obvious from the rotary input that 2-stage refers to a secondary gearing system incorporated before the screw mechanism. The 2-ton capacity would tend to support that. I can't be sure about this without seeing a cut-away of the unit, though.
I got that two stage screw jack. We'll see...
How about http://yhst-1469288697390.stores.yahoo.net/smsmch.html"
My chair will recline, which will eliminate the need to physically look up and thus eliminate neck and back discomfort.
So I am thinking of doing something like this now. The seat will be a box and the actuator will go inside of it here is a crappy drawing
the back rest looks like this from the front (before installation)
I just need to decide how large (diameter) a wooden dowel I should use (or can find) for the cylindrical part.
I need it to be sufficiently strong. I need to cut out a groove where I will set the backrest into and I also need to make a slot into which part B (the thing the actuator pushes on) will slide and be set.
Open to comments and ideas/opinions.
Thanks
I just thought of something. If you can find a scrapped recliner/rocker chair (such as a La-Z-Boy) at a scrapyard, you could just replace the lever assembly with a gear drive and reupholster it.
  • · Replies 18 ·
  • · Replies 86 ·
11K
