What is the Resistance in a Discharging Capacitor Circuit from a V-time Graph?
  • Thread starter Thread starter max1205
    Graph Resistance
The discussion revolves around determining the resistance in a discharging capacitor circuit based on a voltage-time graph. The original poster presents a scenario involving a 50 µF capacitor discharged through a resistor, with specific voltage values at given times.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various equations related to capacitor discharge and question the accuracy of voltage readings from the graph. There is discussion about potential errors in calculations and assumptions regarding the values used.
Some participants have offered alternative calculations and pointed out possible discrepancies in the original poster's approach. There is an ongoing examination of the data from the graph, with suggestions to use specific time points for more accurate resistance calculations.
Participants note the lack of exact values in the problem statement and the potential for misinterpretation of the graph data. There is also mention of unit conversion issues that may affect the calculations.
max1205
A 50 uF(microfarad) capacitor that had been charged to 30 V is discharged through a resistor. Figure 31.73 (attachment) shows the capacitor voltage as a function of time. What is the value of the resistance?
Q = Qo e^(-t/RC), o = initial
Qo = CV, o = initial
I = Io e^(-t/RC), o = initial
Original V = 30, the final V at 3ms is approximately 7V. Thus the final charge is 0.233 (7/30) of the initial charge.
Q = Qo e^(-t/RC)
ln (7/30) = -3/(R)(50 uF)
R = 0.041 ohms
The right answer is 36.4 ohms.
Any suggestions?
[tex]R = \frac {-t}{\ln\frac{V}{Vo}C}[/tex]. However that gives me 41.22 ohm so maybe there's a typo in the problem?
edit: added latex
edit2: actually you didn't solve for 1/R like I first thought, you're just off by 3 orders of magnitude because you probably forgot to convert the milliseconds to seconds.
does anyone have an idea?
Well you estimated the 7V at 3ms since apparently all you had to go by was that graph. If you plug in 36.4 ohms as the resistance into the equation you get something like 5.8V which makes sense. Kind of a lame question if they don't give exact values.
thanks!
Don't estimate - you can see exactly what V is at 2ms. R is constant.
V = V_0 * e^(-t/RC)
Solve for R an input data from the graph where t=2ms.
