Kinetic Energy Ping Pong ball Question
The discussion revolves around calculating the speed of a 2.40 g Ping-Pong ball required to match the kinetic energy of a 7.0 kg bowling ball moving at 2.35 m/s. The key equation used is the kinetic energy formula, KE = 1/2 mv². The user initially attempted to simplify the equation incorrectly by omitting the squaring of the speeds, leading to an erroneous calculation. The correct speed for the Ping-Pong ball to achieve equivalent kinetic energy is 127 m/s.
  • Understanding of kinetic energy concepts
  • Familiarity with the formula KE = 1/2 mv²
  • Basic algebra for solving equations
  • Knowledge of unit conversions (grams to kilograms)
  • Review the derivation of the kinetic energy formula KE = 1/2 mv²
  • Practice solving kinetic energy problems with varying masses and speeds
  • Learn about energy conservation principles in physics
  • Explore the implications of mass and velocity on kinetic energy
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of kinetic energy and its calculations.
islanderman7
[SOLVED] Kinetic Energy Question
A 7.0 kg bowling ball moves at 2.35 m/s. How fast must a 2.40 g Ping-Pong ball move so that the two balls have the same kinetic energy?
m1= 7.0kg
v1= 2.35m/s
m2= .0024kg
v2=?
I know that:
KE= 1/2mv^2
I set my equation like so:
KE1=KE2
and I reduced it to this:
m1v1=m2v2
I plugged in the values and solved for v2:
(7.0kg)(2.35m/s)=v2 (.0024kg)
v2= 6854.17
I put this answer in and it tells me...
wrong check mark
Your answer differs from the correct answer by orders of magnitude. m/s
What am I doing wrong? Please point me in the right direction.
islanderman7 said:
I know that:
KE= 1/2mv^2
Good.
KE1=KE2
Good.
m1v1=m2v2
You made an error here. The kinetic energy equation doesn't reduce to this.
(Don't leave off squaring the speeds.)
Thank you Doc Al.
The correct answer was 127m/s
  • · Replies 23 ·
