Solving Radicals for A,B,C and D: 2^11-1
  • Context: Undergrad
  • Thread starter Thread starter ramsey2879
    Radicals
The discussion revolves around finding integer solutions A, B, C, and D for a specific equation involving powers of 2. The context includes recursive sequences and their properties, as well as the linear independence of certain numbers over the rationals. Participants explore various approaches to solving the problem, including algebraic manipulation and series analysis.
  • One participant expresses uncertainty about their skills but believes there is an integer solution for A, B, C, and D based on a recursive sequence.
  • Another participant reiterates the belief in the existence of a solution and provides a detailed explanation of their reasoning involving recursive series.
  • A different participant states that the numbers 1, 2^{1/4}, 2^{1/2}, and 2^{3/4} are linearly independent over the rationals, suggesting that the equation can be split into four equations with four unknowns.
  • One participant claims to have found a solution with specific integer values for A, B, C, and D.
  • Another participant introduces a different series form and discusses divisibility properties related to the sequences, questioning the potential usefulness of these properties in factoring expressions involving powers of 2.
  • Several participants acknowledge the linear independence of the numbers mentioned, reinforcing the idea that linear algebra could be applied to find a solution.
Participants generally agree on the linear independence of the numbers involved and the potential for applying linear algebra. However, there are multiple competing views regarding the specific integer solutions and the methods to approach the problem, leaving the discussion unresolved.
There are limitations regarding the assumptions made about the recursive sequences and the definitions of the variables involved. The discussion does not resolve the mathematical steps necessary to reach a conclusion.
ramsey2879
I am weak in this topic but I am certain that the following is has a solution in integers A,B,C,D.
Find A,B,C and D as integers such that
[tex](3*2^{.75} + 7*2^{.50} + 7*2^{.25} + 7)*(A*2^{.75} + B*2^{.50} + C*2^{.25} + D) = 2047*(2^{.75} + 2^{.50} +2^{.25} + 1)[/tex].
I deduced this by studying the recursive sequence [tex]S^{n} = 3*S_{n-1} - 2*S_{n-2}[/tex] That is {1,3,7,15,31, ...}
Thanks for any pointers.
Sorry but I couldn't do the math associated with the above problem. I will give an explanation of how I came up with it though. The recursive series [tex]S_{n} = (C+1)*S_{n-1} - C*S_n[/tex] always has embeded within two intermeshed series [tex]A_{i} = S_{2i}[/tex] and [tex]B_{i} = S_{2i +1}[/tex] which both are of the form [tex]S_{n} = (C^{2} + 1)S_{n-1} - C^{2}S_{n-2}[/tex]. In the above series if we let [tex]S_0 = 0[/tex] then [tex]S_i|S_{ni}[/tex]. I correctly deduced that this works recursively both forwards and backwords i.e if we let [tex]C^{'} = C^{2}[/tex] etc. Thus there should is a recursive series where [tex]C = 2^{.25}[/tex] and [tex]S_{44} = 2047S_4[/tex] Indeed If S_0 = 0 and S_1 = 1 then [tex]S_4 = (2^{.75}+2^{.50}+2^{.25} + 1)[/tex] and [tex]S_44 = 2047S_4[/tex].
[tex]S_{11} = 3*2^{.75} + 7*2^{.50} + 7^2^{.25} + 7[/tex] and of course S_11 divides S_44!
The numbers [itex]1, 2^{1/4}, 2^{1/2}, 2^{3/4}[/itex] are linearly independent over Q. Therefore, you can split your equation into four equations in four unknowns, and so you would usually expect to be able to apply linear algebra to compute the unique (rational) solution.
thanks
solution A= 4, B = 32, C = 256, D = 1
Another question,
My series is of the form [tex]S_{n} = G*S_{n-1} + H*S_{n-2}[/tex] where [tex]S_0}=0[/tex] and [tex]S_{1}=1[/tex].
Also [tex]S_{n} = \{A,B,C,D\} = A + B*2^{1/4}+C2^{1/2} +D2^{3/4}[/tex]
If a = floor n/4 then S_n
[tex]\{2^{a}-1,2^{a}-1,2^{a}-1,2^{a}-1\}[/tex], or
[tex]\{2^{a+1}-1,2^{a}-1,2^{a}-1,2^{a}-1\}[/tex], or
[tex]\{2^{a+1}-1,2^{a+1}-1,2^{a}-1,2^{a}-1\}[/tex], or
[tex]\{2^{a+1}-1,2^{a+1}-1,2^{a+1}-1,2^{a}-1\}[/tex], depending upon
the value of n mod 4, as 0,1,2,3 respectively.
If [tex]p = \prime > 3[/tex] then S_3 divides [tex]S_{4p+1}[/tex] or [tex]S_{4p+2}[/tex]
So If p = -1 mod 4 both S_2 and S_3 divide S_(4p+2).
If we allow radicals of the form [tex]2^{1/8}[/tex] then [tex]S_3[/tex] can be factored as [tex](1+2^{1/4} + 2^{1/8})*(1 + 2^{1/4} -2^{1/8})[/tex]
Also S_2 can be factored as (1+2^{1/4})*(1+2^{1/2} and each factor can be also be expressed as the difference of two squares if we allow units in "i".
And of course as I showed earlier S_(2p) divides S_(4p) and S_2 divides both S_2p and S_4p.
Could any of this be useful in factoring 2^{p} -1?
Hurkyl, Really nice! DJ
  • · Replies 0 ·
  • · Replies 17 ·
