Purpose and function of accumulators in a pump system?
Accumulators in pump systems serve as pulsation dampeners and store hydraulic energy. They are essential for mitigating pressure transients and optimizing pump operation by allowing smaller pumps to charge the accumulator instead of cycling larger pumps. Sizing and design of accumulators are based on thermodynamic principles, with API Specification 16D providing equations for volumetric efficiency. Understanding these concepts is crucial for effective implementation in hydraulic systems.
  • Thermodynamics principles
  • Fluid Mechanics fundamentals
  • API Specification 16D knowledge
  • Hydraulic Power Handbook familiarity
  • Study API Specification 16D for volumetric efficiency equations
  • Learn about hydraulic accumulator sizing techniques
  • Explore the principles of pulsation dampening in hydraulic systems
  • Investigate the design and operation of hydraulic machines using accumulators
Engineers, hydraulic system designers, and technicians involved in pump system optimization and accumulator implementation will benefit from this discussion.
James3849
Hi,
Can anyone help me understand the purpose and function of accumulators in a pump system? Also if anyone has any information on the sizing and design of accumulators, it would be helpful.
James3849 said:
Hi,
Accumulators serve multiple purposes in pumping systems. First, they can act as pulsation dampeners to mitigate pressure transients. Secondly, they serve as stored hydraulic energy once they are charged.
They are generally sized based on Thermodynamic relations. API Specification 16D gives some equations for determining the volumetric efficiency of them. That would be a good start for you (depending on your background). If you don't know much about Thermodynamics and Fluid Mechanics, I would suggest a Hydraulic Power Handbook and a Thermo book for starters.
Hope that helps.
CS
Good advice from stewart.
Think of an accumulator as a hydraulic cylinder, with its piston being compressed by a large spring.
A good example of its use would be a hydraulic machine (such as a press) which is required to operate for 10 seconds in every minute. Rather than switch a massive pump on and off every minute, a much smaller pump can be used together with an accumulator. The pump will run constantly (thus avoiding thermal and mechanical cycling issues). For 50 seconds of each minute, the pump will 'charge up' the accumulator by filling it up, and compressing the spring. Then, for 10 seconds, a valve will operate, letting the spring push the fluid out into the press to do its work, before closing and repeating the cycle.
Get it?
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 29 ·
11K
