Finding Side AB and Angle ABC of a Park Problem
  • Thread starter Thread starter ur5pointos2sl
    Angle
The problem involves determining the length of side AB and the magnitude of angle ABC in a geometric configuration related to a park's boundaries, which includes a river and a highway. The setup includes specific measurements and angles, with boundaries defined in relation to the highway.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss using coordinate systems and separating the figure into triangles to analyze the problem. Some express difficulty in applying the law of sines and cosines due to multiple unknowns, while others suggest focusing on solving right triangles first.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been provided regarding the use of triangles, but there is no explicit consensus on the best method yet.
Participants mention potential confusion due to rounding errors and the challenge of solving for multiple unknowns simultaneously. There is an indication that the problem may require careful consideration of angles and triangle properties.
ur5pointos2sl
Ok my math is a little rusty. I ran across a problem that states:
"A park is being considered in a space between a small river and a highway as a rest stop for travelers. Boundary BC is perpendicular to the highway and boundary AD makes an angle of 75 Deg. with the highway. BC= 160.0 m , AD= 270.0 m, and the boundary along the highway = 190.0m long. What are the length of side AB and the magnitude of angle ABC?"
I have attached a file that is almost identical to the one in the book. I need help figuring out where to start this problem(not an answer please). Any help would be appreciated.
Thanks
Welcome to PF!
Hi ur5pointos2sl ! Welcome to PF! :smile:
I can't see your picture file yet, but I think the best way is probably to use x and y coordinates, starting with C as the origin. :wink:
My problem is that I can't seem to use law of sine/cosine because there is always 2 things to be solved for. I think I am missing something.
I put C at the origin and looked at it that way. If i separate the figure into two triangles that doesn't seem to lead me anywhere either. I can solve for one but then the other I am completely stuck on.
You don't need coordinates. DO split the quadrilateral into two triangles. Solve the right triangle first. Find length of BD and the two angles. Then you have side-angle-side on the remaining triangle. Solve it.
Thank you. That is exactly what I did last night except I solved for the right triangle then used law of cosine to solve for the other. I finally realized my answer was off because I was rounding to one decimal place.
  • · Replies 19 ·
  • · Replies 24 ·
