Resolved shear stress(rss) problem
  • Thread starter Thread starter custer
    Shear
The discussion focuses on calculating the resolved shear stress (rss) for a single crystal of iron (BCC) under a tensile force of 52 MPa applied along the [010] direction. The Schmid law is utilized to relate the shear stress to the tensile stress, with the equations rss = sigma.cos(phi).cos(lambda) and the angles phi and lambda derived using the scalar product method. The final calculation yields the resolved shear stress as rss = 52 * (1/sqrt(2)) * (1/sqrt(3)).
  • Understanding of Schmid's Law in crystallography
  • Familiarity with single crystal mechanics
  • Knowledge of vector mathematics and scalar products
  • Basic concepts of tensile and shear stress
  • Study the application of Schmid's Law in different crystal structures
  • Learn about the mechanics of single crystal deformation
  • Explore advanced vector mathematics for stress analysis
  • Investigate the effects of varying tensile stress on shear stress in BCC metals
Materials scientists, mechanical engineers, and students studying crystallography or material deformation mechanics will benefit from this discussion.
custer
Can anyone tell me how to find the angle between tensile force and slip direction under these conditions:-
1. Tensile force is applied along [010] direction for a single crystal of iron(BCC).
2. rss is directed along (110) plane and in a [-111] direction when tensile stress of 52 MPa is applied. thank you
I am not sure enough but this is my solution:
Suppose lambda is your angle:
tan(lambda)=a*sqrt(2)/a=sqrt(2)
lambda=tan^-1(sqrt(2))
The schmid law allows you to calculate the shear stress as a function of the tensile stress :
rss=sigma.cos(phi).cos(lambda)
where phi is the angle between the tensile direction and the slip plane normal ([110] in your case) and lambda is the angle between the tensile direction and the slip direction ([-111] in you case).
To find cos(phi) and cos(lambda) you can use the scalar product :
1*0+1*1+1*0=sqrt(2)*sqrt(1)*cos(phi) ==> cos(phi)=1/sqrt(2)
-1*0+1*1*1*0=sqrt(3)*sqrt(1)*cos(lambda) ==> cos(lambda)=1/sqrt(3)
Then:
rss=52*1/sqrt(2)*1/sqrt(3)
  • · Replies 18 ·
20K
11K
  • · Replies 29 ·
