Relationship between density and elastisity
  • Context: Undergrad
  • Thread starter Thread starter soandos
    Density Relationship
The discussion revolves around the relationship between density and elasticity, particularly in the context of various materials, including neutron stars. Participants explore theoretical and practical aspects of how these properties interact, raising questions about definitions, models, and specific examples.
  • Homework-related
  • Some participants inquire about the relationship between density and elasticity for a given material, questioning whether this is a homework assignment.
  • There is uncertainty regarding the properties that determine density, with distinctions made between mass density and atomic density.
  • Participants discuss the properties that determine the elastic (Young's) modulus and suggest plotting elastic modulus as a function of density for various elements.
  • One participant mentions that for a neutron star, the relationship between elasticity and density may not hold due to different interactions at the nucleon level compared to atomic interactions.
  • Another participant argues that there is no established phenomenological relationship between density and elasticity, noting that fluids can have similar densities to solids without being elastic.
  • Questions arise about how density can be varied, including factors like temperature and the presence of voids.
  • Some participants express uncertainty about whether a neutron star should be classified as a solid or liquid, and whether this classification matters.
  • There are references to classical mechanics and its limitations when applied to complex materials like colloids or under extreme conditions.
  • Participants seek formulas that relate temperature and density, with one suggesting a specific textbook as a resource.
Participants do not reach a consensus on the relationship between density and elasticity, with multiple competing views and uncertainties expressed throughout the discussion.
The discussion highlights limitations in current models to predict macroscopic material properties from microscopic properties, especially for complex materials and extreme conditions.
Readers interested in materials science, solid mechanics, astrophysics, and the properties of materials under varying conditions may find this discussion relevant.
soandos
what is the relationship between these two things for a given material?
Is this a homework assignment?
What properties of an element determine density? Is this mass density or atomic density?
What properties of an element determine the elastic (Young's) modulus?
Try to plot the elastic modulus as a function of the density for the corresponding element.
http://www.webelements.com/periodicity/youngs_modulus/
http://www.webelements.com/periodicity/density/
For a specific element, e.g. Fe - http://www.webelements.com/iron/physics.html
http://en.wikipedia.org/wiki/Elastic_properties_of_the_elements_(data_page ) - need to verify data.
http://en.wikipedia.org/wiki/List_of_elements_by_density
to answer your questions in order:
1) no, it is a question to help explain another post of mine
2) i am not really sure if there is a difference here as the object in question is neuron star, with a density approaching that of an atomic nucleus
3) the material is roughly a constant, assume it is a mix of the lighter elements
i can see the young modulus and density at the point that it becomes a solid, but i do not see a way to relate the two
Well, if the matter in question is a neutron star, then relating elasticity and density of atoms will not hold since the interactions of nucleons are fundamentally different than atoms. Is the question one of the 'acoustic' behavior?
The speed of sound is related to the bulk modulus and density. The more massive the particle - or more dense - the more resistance there is to the propagation of waves, which are basically a transfer of momentum/pressure through the medium.
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe2.html
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/soundv.html
http://hyperphysics.phy-astr.gsu.edu/hbase/permot3.html
no. it is related to how easily the minor axis would shrink if it was spinning.
I am unaware of any phenomenological relationship between the two. For nearly any solid material you provide me, I can provide a fluid with the same (or nearly so) density, and yet is not elastic at all.
For all but the most simple materials, there is currently no model to predict macroscopic material properties from microscopic properties.
i am not asking about anything special, just the norm.
is this clearer:
what amount of force is needed on the poles to extend the major axis by a given amount?
How would the density be varied? Via temperature or by having voids (in a vacuum so air wouldn't fill the voids)? Via varius shapes (is a spring more elastic than a solid cylinder)?
is a neutron star a solid or a liquid?
does it even matter?
solid, i do not know
Um I can't remember the exact expression at the moment, but this is a pretty basic kind of question from solid mechanics; I suggest the book "Mechanics of Materials" by Gere. However, as Astronuc was trying to tell you, this question is quite dependent on material composition. The book by Gere mainly talks about metallic substances, at typical temperatures and densities. Once you start talking about colloidal substances (gels), high-temperature, high-pressure applications (e.g., subsurface rock mechanics), and especially, something like a neutron star, I'm not sure how much classical mechanics really applies.
thank you. are there any formulea that i can use though that have temperature and density as variables?
Yes; such formulas exist. See book listed above.
if you have a copy of the book can you please give me the formula?
it seems kind of silly to pay $92 for a book that i just need a page out of.
Library...
none of the ones in nassau county have it
27K
  • · Replies 18 ·
  • · Replies 16 ·
