Transform a vector from Cartesian to Cylindrical coordinates
The discussion revolves around transforming a vector from Cartesian to Cylindrical coordinates, specifically focusing on the vector Q provided in the original post. Participants are examining the correctness of the transformation equations and the resulting components in the cylindrical coordinate system.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are analyzing the transformation equations for the cylindrical coordinates and questioning the validity of the original poster's calculations. There are discussions about the role of the phi coordinate and whether it should be included when certain components are zero.
The conversation is ongoing, with some participants expressing uncertainty about the correctness of the transformation equations. There is a mix of agreement and disagreement regarding the interpretation of the phi coordinate, and some participants are reconsidering their previous statements based on the original equations provided.
There is mention of class notes that provide a matrix form for the transformation, which some participants are referencing. Additionally, the discussion reflects a need to clarify the assumptions regarding the coordinate system and the implications of having zero components in the vector.
VinnyCee
Transform the vector below from Cartesian to Cylindrical coordinates:
[tex]Q\,=\,\frac{\sqrt{x^2\,+\,y^2}}{\sqrt{x^2\,+\,y^2\,+\,z^2}}\,\hat{x}\,-\,\frac{y\,z}{x^2\,+\,y^2\,+\,z^2}\,\hat{z}[/tex]
Use these equations:
[tex]A_{\rho}\,=\,\hat{\rho}\,\cdot\,\overrightarrow{A}\,=\,A_x\,cos\,\phi\,+\,A_y\,sin\,\phi[/tex]
[tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A}\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex]
[tex]A_z\,=\,A_z[/tex]
[tex]x\,=\,\rho\,cos\,\phi[/tex]
[tex]y\,=\,\rho\,sin\,\phi[/tex]
[tex]Q_{\rho}\,=\,\frac{\sqrt{\left(\rho\,cos\,\phi\right)^2\,+\,\left(\rho\,\sin\,\phi\right)^2}}{\sqrt{\left(\rho\,cos\,\phi\right)^2\,+\,\left(\rho\,\sin\,\phi\right)^2\,+\,z^2}}\,cos\,\phi[/tex]
[tex]Q_{\rho}\,=\,\frac{\rho}{\sqrt{\rho^2\,+\,z^2}}\,cos\,\phi[/tex]
[tex]Q_{\phi}\,=\,-\,\frac{\rho}{\sqrt{\rho^2\,+\,z^2}}\,sin\,\phi[/tex]
[tex]Q_z\,=\,-\,\frac{z\,\rho\,sin\,\phi}{\rho^2\,+\,z^2}[/tex]
Does the above look correct?
Hi VinnyCee! :smile:
No … these are the equations for an ordinary rotation of the x and y axes through an angle phi.
hmm … you want polar coordinates of a vector along the x-axis … so what will its phi coordinate be? :smile:
Really? The equations for transforming from Cartesian to Cylindrical were given in the notes for the class in a matrix form and then solved out to a formula, the one below.
Here is a more detailed version for the [itex]\rho[/itex] coordinate transformation only:
[tex]A_{\rho}\,=\,\hat{\rho}\,\cdot\,\overrightarrow{A} \,=\,\left(\hat{\rho}\,\cdot\,\hat{x}\right)\,A_x\,+\,\left(\hat{\rho}\,\cdot\,\hat{y}\right)\,A_y\,+\,\left(\hat{\rho}\,\cdot\,\hat{z}\right)\,A_z\,=\,A_x\,cos\,\phi\,+\,A_y\,sin\,\phi[/tex]
Is that incorrect? If so, what is the correct way to transform from Cartesian to Cylindrical?I think the [itex]\phi[/itex] coordinate would be zero in this case since there is no y-component, right?
Here you've included the Ax cos(phi) term, but forgot the Ay sin(phi) term
[itex]A_y[/itex] is zero, so it need not be included, right?
Oops, I was confusing Ay and Az. My bad.
Your results from post #1 look okay to me. My understanding is the dot product of the vector Q with the coordinate unit-vector is the component of Q in that coordinate direction, which is exactly what you did.
On the other hand I'm hesitant to disagree with tiny-tim, since he knows this stuff pretty well also.
That's right! for x > 0 and y = 0, phi must be zero. :smile:
No!
A three-dimensional vector needs three coordinates …
if one coordinate is 0, you have to say so!
Is that incorrect?
No, that is correct … the other one is wrong.
Isn't that the same expression as in post #1 for Aρ ?
ah … I meant the phi-coordinate [tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A}\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex] is wrong. :wink:
Um, if we use the convention that φ's unit vector points counterclockwise, and φ is taken counterclockwise from the positive x-axis, then I agree with VinnyCee's formula.
So, does that mean that the original post contains the correct answer? Or is the [itex]Q_{\phi}[/itex] variable still going to be zero even though the formulas given produce the expression I wrote in the first post?
The expression written from a matrix in class is:
[tex]A_{\phi}\,=\,\hat{\phi}\,\cdot\,\overrightarrow{A} \,=\,\left(\hat{\phi}\,\cdot\,\hat{x}\right)\,A_x\,+\,\left(\hat{\phi}\,\cdot\,\hat{y}\right)\,A_y\,+\,\left(\hat{\phi}\,\cdot\,\hat{z}\right)\,A_z\,=\,-A_x\,sin\,\phi\,+\,A_y\,cos\,\phi[/tex]
Since...
[tex]\hat{x}\,\cdot\,\hat{\phi}\,=\,-\,sin\,\phi[/tex]
[tex]\hat{y}\,\cdot\,\hat{\phi}\,=\,cos\,\phi[/tex]
[tex]\hat{z}\,\cdot\,\hat{\phi}\,=\,0[/tex]
Right?
sorry!
Hi VinnyCee and Redbelly98! :smile:
Yes, I completely mis-read the original question.
Your original answer was totally right.
Please ignore my previous posts.
Sorry. :redface:
  • · Replies 34 ·
