Densely defined operators of Fock space
  • Context: Graduate
  • Thread starter Thread starter julian
    Operators Space
The discussion centers on the conditions for an operator \(\hat{O}\) to be densely defined in Fock space, specifically stating that \(\hat{O}\) is densely defined if and only if \(\hat{O} \Omega\) has finite norm. The participants emphasize that Fock space is generated by cyclic operations of annihilation and creation operators acting on the vacuum state \(\Omega\). Furthermore, it is clarified that an operator is densely defined on a separable space if it is defined on at least one vector in that space, although additional assumptions may be necessary for this to hold universally.
  • Understanding of Fock space and its properties
  • Knowledge of annihilation and creation operators
  • Familiarity with the concept of densely defined operators in functional analysis
  • Basic principles of separable Hilbert spaces
  • Study the properties of Fock space and its closure under finite linear combinations
  • Learn about the role of annihilation and creation operators in quantum mechanics
  • Explore the concept of densely defined operators in the context of functional analysis
  • Investigate the implications of separability in Hilbert spaces and its relation to operator theory
Mathematicians, physicists, and students of quantum mechanics who are interested in operator theory, functional analysis, and the mathematical foundations of quantum field theory.
julian
Could someone prove the following (if it is precisely correct):
Since Fock space is the closure of the finite linear span of finite excitations of the vacuum state $\Omega$, then the operator $\hat{O}$ is densely defined if and only if $\hat{O} \Omega$ has finite norm.
Or more generally, an operator is densely defined on a separable space if it is defined on a given single vector in that space.
thanks
I'm not an expert on Functional Analysis, but since no one else has
answered yet I'll have a go...
(BTW, $...$ doesn't work here for latex strings. I've fixed them
below. Click on anyone of them to see the latex source, and a link
to some latex info relevant to PhysicsForums.)
[itex]\Omega[/itex], then the operator [itex]\hat{O}[/itex]
is densely defined if and only if [itex]\hat{O}<br /> \Omega[/itex] has finite norm.
I think you can use the axiom that Fock space is generated by
cyclic operations of the annihilation and creation operators
upon a distinguished vacuum vector (and a subsequent
closure). Under this construction the a/c operators form an
irreducible set, meaning that *any* operator on the Fock
space can be expressed as a sum of polynomials of these
operators. (Since you only want "densely defined",
polynomials are enough -- you don't need to worry about
infinite series and associated existence issues.)
Then you take an arbitrary product of a/c operators.
Eg, for a quadratic in the creation operators it might
be something like:
[tex] O_2 ~:=~ \int dp dq ~ f(p,q) a^*(p) a^*(q)[/tex]
More generally, there might also be annihilation operators
but you can use the CCRs to normal-order them, and if
the result is any naked delta fns (which cannot be
integrated away) then such an operator doesn't give a
finite-norm vector when acting on the vacuum.
I think that's enough to do the proof in one direction
(though you'll have to clean it up and fill in more details).
Once you've seen it in one direction you can probably figure
out the reverse direction.
And if I've got anything wrong in the above, maybe someone
else will enjoy correcting it. :-)
in that space.
I don't think that's true in general without further
assumptions (such as the cyclicity of the vacuum and
maybe some other stuff). "Separability" in this context
only means the space has a countable orthonormal basis,
so you've got to show that the operator acting on any
basis vector results in a finite-norm vector. (Actually,
that's kinda what I did above in a clumsy way for
the Fock, since one gets a countable basis there by
acting on the vacuum with products of creation
operators.)
HTH.
Thanks for the response
sorry I've been a bit busy to reply.
Yes, a lot of operators have the same action on a given vector (in a separable space) but some will give non-normalizable vectors when acting on other vectors - unless addition assumptions are made.
I didn't read the paper carefully anough, te separable space in question is isomorphic to Fock space
Thanks
julian
  • · Replies 59 ·
  • · Replies 0 ·
  • · Replies 16 ·
