Converting listbox items to a string.
  • Thread starter Thread starter jazFunk
    String
The discussion revolves around the challenge of converting items from a list box into a single string in the context of programming, specifically using VB (Visual Basic). Participants are exploring methods to achieve this task and sharing their experiences with different approaches.
  • Technical explanation, Homework-related
  • One participant expresses difficulty in completing what they perceive as a simple task of converting list box items to a string.
  • Another participant inquires about the programming language being used, which is identified as VB.
  • A suggestion is made to use the function Str(List1.List(x)), with the note that indexing starts from 0.
  • A participant reports that the suggested method did not work, citing an error related to the 'List' member of 'Systems.Windows.Forms.ListBox'.
  • The same participant shares their attempt to convert items using Me.lstLegend.Items.ToString(), but indicates it does not yield a single string as desired.
  • Another participant provides a code snippet that successfully concatenates items from the list box into a label, stating it worked perfectly for them with three items in the list.
The discussion contains multiple approaches to the problem, with some participants reporting success while others encounter issues. There is no consensus on a single solution, as different methods are being explored.
Participants have not fully resolved the issue of converting all items into a single string, and there are indications of varying levels of success with different code snippets. The specific requirements for the function processing the string are not detailed.
Individuals working with VB who are facing similar challenges in manipulating list box items and converting them into strings for further processing.
jazFunk
It seems like it would be a fairly simple task, yet I have been unable to complete this task.
Technology news on Phys.org
what language are you using?
I'm using VB.
try with Str(List1.List(x))
where x = the item # you want. Remember it starts from 0
That didn't work either. The error was that 'List is not a member of the 'Systems.Windows.Forms.ListBox'.
I try this with no error but it's not converting the items to a single string:
Dim OrigString As String = Me.lstLegend.Items.ToString()
Essentially I need to convert all of the items in a list box to a single string which can then be processed through a function.
Thanks, in advance.
Private Sub Command1_Click()
For x = 0 To 2
Label1.Caption = Label1.Caption & CStr(List1.List(x))
Next x
End Sub
That worked perfectly for me, try it. I had 3 items in my List.
  • · Replies 28 ·
  • · Replies 17 ·
