Vector addition problem - component method
The discussion revolves around a vector addition problem involving a plane's velocity, wind velocity, and ground velocity, with the goal of finding the unknown ground speed and direction using the component method.
  • Participants discuss using the component method to set up equations based on the cosine and sine of angles to isolate unknowns. There are attempts to manipulate these equations to express the unknown angle and speed in terms of known quantities.
The discussion is active, with participants exploring various algebraic manipulations and trigonometric identities. Some guidance has been provided on how to expand equations and utilize identities, but there is still uncertainty regarding isolating variables and the correctness of derived expressions.
Participants express confusion about isolating angles and the implications of their calculations, indicating a need for clarification on trigonometric identities and algebraic techniques. There is an emphasis on learning multiple methods for solving the problem.
Larrytsai
Vplane = 63km/hr at x degrees and direction
Vwind = 47km/hr at 211 degrees
Vg = unknown speed at 165 degrees
find the unknowns
my attempt using component method:
(Cos 165)Vg = (Cos 211)47 + (Cos theta)63
(Sin 165)Vg = (Sin 211)47 + (Sin theta)63
from here i think I am supposed to isolate Vg and then subsitute to find the unknown angle and then plug the angle into get the speed but I am not quite sure
I know i can use the cosine law or sine law but I have to learn both ways so that's why I am using the component method
find the unknowns
I think the easiest way for you to solve this system of equations is to isolate [tex]cos(\theta)[/tex] in the first equation, [tex]sin(\theta)[/tex] in the second one, and then square both equations, add them together and take advantage of the fact that [tex]sin^2(\theta)+cos^2(\theta)=1[/tex] to sollve for [tex]V_g[/tex]. After that, plug your solution into either equation and solve for [tex]\theta[/tex]. If you post your solution, I'll be happy to check it.
hmmm, that's where i ran into trouble, isolating theta i don't understand how to isolate theta. like do i use Sin-1? and how would it look?
Start with the first equation:
[tex]V_gcos(165^{\circ}) = 47cos(211^{\circ}) + 63cos(\theta)[/tex]
Can you solve this for [tex]cos(\theta)[/tex]?
ohhh okay so now i got (Vg(Cos 165) - 47(Cos 211))/63 = Cos (theta)
i think that's right
Yup, so what is [tex]cos^2(\theta)[/tex] then?
by Cos^2 u mean Cos-1 right? and if so i don't see what will happen to my other unknown
Nope, I mean [tex](cos(\theta))^2[/tex]...it will become clear why I want you to find this in a minute.
oo I am just lost now sorrry =(
If
[tex]cos(\theta)=\frac{V_gcos(165^{\circ})-47cos(211^{\circ})}{63}[/tex]
then
[tex]cos^2(\theta)=\frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}[/tex]
...Now, solve the second equation for [tex]sin(\theta)[/tex] and then find [tex]sin^2(\theta)[/tex]
okay so i got
Sin^2(theta) = ((Vg(Sin165)-47(Sin211))^2)/(63)^2
well now I am wondering does that Cos^2 and Sin^2 isolate theta?
Larrytsai said:
okay so i got
Okay, so now you have:
and
[tex]sin^2(\theta)=\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2}[/tex]
so what is [tex]sin^2(\theta)+cos^2(\theta)[/tex]?
from what u said earlier it = 1
Yes, there is a trigonometric identity: http://en.wikipedia.org/wiki/Pythagorean_trigonometric_identity" that it will equal 1 for any theta.
so you get:
[tex]sin^2(\theta)+cos^2(\theta)=\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2} + \frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}=1[/tex]
And so,
[tex]\frac{[V_gsin(165^{\circ})-47sin(211^{\circ})]^2}{63^2} + \frac{[V_gcos(165^{\circ})-47cos(211^{\circ})]^2}{63^2}=1[/tex]
Now, can you expand this equation to find a quadratic equation for [tex]V_g[/tex]?
okay so i tried to find wat Vg is equal to and i get 2.11 which seems wrong to me
my work is shown here
1=((Vg(cos165)+40.287)^2 + (Vg(Sin165)+24.207)^2)/(3969)
multiply both sides by 3969
3969=(Vg(Cos165)+40.287)^2 + (Vg(Sin165)+24.207)^2
square root both sides
63=-0.7071Vg+64.494
subtract 64 to both sides
-1.494= -0.7071Vg
0.7072 came from cos165+sin165
Vg = -1.494/-0.7071
Vg= 2.11
you can't just take the square root of the right hand side here, because it is a sum of 2 squares not just a perfect square...you have to expand each term first like this:
[tex]\Rightarrow [V_gsin(165^{\circ})-47sin(211^{\circ})]^2 +[V_gcos(165^{\circ})-47cos(211^{\circ})]^2=63^2[/tex]
[tex]\Rightarrow [V_g^2sin^2(165^{\circ})-94V_gsin(165^{\circ})sin(211^{\circ})+47^2sin^2(211^{\circ})] +[V_g^2cos^2(165^{\circ})-94V_gcos(165^{\circ})cos(211^{\circ})+47^2cos^2(211^{\circ})]=63^2[/tex]
[tex]\Rightarrow [sin^2(165^{\circ})+cos^2(165^{\circ})]V_g^2-94V_g[sin(165^{\circ})sin(211^{\circ})+cos(165^{\circ})cos(211^{\circ})]+47^2[sin^2(211^{\circ})] +cos^2(211^{\circ})]=63^2[/tex]
Now, there are two useful Trig Identities: (1) [tex]sin^2(x)+cos^2(x)=1[/tex] and (2) [tex]sin(x)sin(y)+cos(x)cos(y)=cos(y-x)[/tex].
Using these you get:
[tex](1)V_g^2-94cos(211^{\circ}-165^{\circ})V_g+(1)47^2=63^2[/tex]
[tex]\Rightarrow V_g^2-94cos(46^{\circ})V_g+(47^2-63^2)=0[/tex]
Now, can you solve for [tex]V_g[/tex]?
You should get 2 solutions!
  • · Replies 21 ·
