How Does Maxima Solve the Differential Equation r=Kt/((dr/dt)²-c²)?
  • Context: Graduate
  • Thread starter Thread starter Loren Booda
    Diff eq
The discussion revolves around solving the differential equation r=Kt/((dr/dt)²-c²), where r and t are variables, and K and c are constants. Participants explore various approaches to finding a solution, discussing the nature of the equation, its linearity, and potential methods for solving it.
  • Some participants propose that the equation can be transformed into a third-order differential equation, while others express uncertainty about how to solve it.
  • There is contention regarding the linearity of the equation, with some asserting it is nonlinear due to the first derivative being squared, while others disagree.
  • A participant suggests a change of variables to simplify the equation, leading to a cubic form that can be analyzed further.
  • Another participant presents a detailed derivation involving partial fractions and roots of a polynomial, indicating a potential analytic solution but noting that the function may not be single-valued for a given t.
  • Some participants retract earlier claims or solutions, indicating ongoing refinement of ideas and approaches.
  • There are multiple attempts to clarify and correct earlier statements, with some participants expressing gratitude for contributions while also questioning the validity of certain approaches.
Participants do not reach a consensus on the nature of the equation or the validity of proposed solutions. Disagreements persist regarding its linearity and the correctness of various approaches to solving it.
Limitations include unresolved mathematical steps and the dependence on the definitions of terms used in the discussion. The non-linearity of the equation and its implications for solutions remain points of contention.
Loren Booda
Please solve
r=Kt/((dr/dt)2-c2)
it's not a solution but it's a way:
(d/dt)*r=(d/dt)K*t/((dr/dt)^2-c^2)
dr/dt=dt/dt*K/((dr/dt)^2-c^2)
(dr/dt)^3-c^2*(dr/dt)=k
now this is third order differential equation which i don't know yet how to solve, hope this helps in a way.
First of all find dr/dt free of any power
Does the original equation turn out to be a nonlinear one, or is it in any way exactly solvable?
no its not non linear
It is I order diff equation
and let's see whether it is solvable or not
Yes, it is nonlinear.
The order of the equation has nothing to do with its linearity. The first derivative is squared. That is what makes it nonlinear. Even if we take your suggestion of reducing the power of dr/dt to 1, we will have r (the solution!) appearing under a square root sign, which still makes for a nonlinear equation.
edit: typo
Thanks, Tom! Care to try for a solution?
Oh yes its is nonlinear. Thnks Tom
By re labeling r=y and t=x the equation becomes:
y(y'2-c2)=kx
If we take now y of the form y=Ax+B with A,B=constants results:
(Ax+B)(A2-c2)=kx
[A3-Ac2]x+[BA2-Bc2]=kx
Identifying the terms --->
B[A2-c2]=0 (1)
A3-Ac2=k (2)
In (1) A cannot be equal with (+/-c) --->
B=0 (3)
Let now p=-c2 and q=-k.Solving the third degree eq in A --->
A1=P+Q
A2=[-(P+Q)/2]+i[(P-Q)/2][√3]
A3=[-(P+Q)/2]-i[(P-Q)/2][√3]
where
P=3√ {(-q/2)+√[(p/3)3+(q/2)2]}
Q=3√ {(-q/2)-√[(p/3)3+(q/2)2]}
[edit to add]Of course there is additionally the condition that k2/4 - c6/27 ≥ 0
[tex] r = \frac {K t} { ( \frac {dr} {dt} )^2 - c }[/tex]
[tex] ( \frac {dr} {dt} )^2 - c = \frac {K t} {r}[/tex]
[tex] \frac {dr} {dt} = \sqrt{ \frac {K t} {r} + c }[/tex]
Now let us try a change of variables
[tex] p = \sqrt{ \frac {K t} {r} + c }[/tex]
[tex] \frac {dp} {dt} = \frac { \frac {K} {r} - \frac {K t} {r^2} \frac {dr} {dt} } { 2 \sqrt{ \frac {K t} {r} + c } }[/tex]
[tex] \frac {dp} {dt} = \frac { \frac {p^2 - c} {t} - \frac {(p^2 - c)^2} {K t} \frac {dr} {dt} } { 2 p }[/tex]
[tex] -\frac{ K t ( 2 p \frac {dp} {dt} - \frac {p^2 - c} {t} ) } {(p^2 - c)^2} = \frac {dr} {dt}[/tex]
[tex] \frac{ K t ( 2 p \frac {dp} {dt} - \frac {p^2 - c} {t} ) } {(p^2 - c)^2} = -p[/tex]
[tex] \frac {dp} {dt} = \frac { -p \frac {(p^2 - c)^2} {K } + p^2 - c } { 2 p t }[/tex]
Using separation of variables
[tex] \frac {p dp} {-p \frac {(p^2 - c)^2} {K} + p^2 - c} = \frac {dt} { 2 t }[/tex]
[tex] \int \frac {p dp} {-p \frac {(p^2 - c)^2} {K} + p^2 - c} = \int \frac {dt} { 2 t }[/tex]
Now to do the left hand side integral we can apply the method of partial fractions. First we have to factor the whole denominator and to do this we have to find the polynomial's zeroes...
[tex] -p \frac {(p^2 - c)^2} {K} + p^2 - c = 0[/tex]
we can see when [tex]p = \sqrt{c}[/tex] or [tex]p = - \sqrt{c}[/tex] that the equation is satisfied, therefore these are two of the roots. Expanding...
[tex] p^5 - 2 c p^3 - K p^2 + c^2 p + K c = 0[/tex]
The polynomial is of order 5 therefore we have 3 more roots to find. Writing...
[tex] ( p + \sqrt{c} ) ( p - \sqrt{c} ) ( q p^3 + s p^2 + t p + u ) = 0[/tex]
for constants q, s, t and u. Expanding this out...
[tex] q p^5 + s p^4 + ( t - c q ) p^3 + ( u - c s ) p^2 - c t p - c u = 0[/tex]
comparing this equation to the original expanded polynomial we can solve for the coefficients
q = 1
s = 0
t = -c
u = -K
So to find the remaining three roots we need to find the zeroes of
[tex] p^3 - c p = K[/tex]
Now we make Vièta's Substitution...
[tex] p = y + \frac {c} {3y}[/tex]
after the substitution is made...
[tex] y^3 + \frac {c^3} {27 y^3} - K = 0[/tex]
[tex] (y^3)^2 + \frac {c^3} {27} - K y^3 = 0[/tex]
Using the quadratic formula...
[tex] y^3 = \frac { K \pm \sqrt{ K^2 - 4 \frac {c^3} {27} } } {2}[/tex]
[tex] y = \sqrt[3]{ \frac { K + \sqrt{ K^2 - 4 \frac {c^3} {27} } } {2} }[/tex]
OR
[tex] y = \sqrt[3]{ \frac { K - \sqrt{ K^2 - 4 \frac {c^3} {27} } } {2} }[/tex]
Remember that [tex]p = y + \frac {c} {3y}[/tex]. We will call the two roots [tex]\epsilon_+[/tex] and [tex]\epsilon_-[/tex] respectively. Now we only have one remaining root to get...
[tex] (p - \epsilon_+) (p - \epsilon_-) ( p - v ) = 0[/tex]
Expanding...
[tex] p^3 - ( \epsilon_- + \epsilon_+ + v ) p^2 + ( \epsilon_+ \epsilon_- + v ( \epsilon_- + \epsilon_+ ) ) p - v \epsilon_+ \epsilon_- = 0[/tex]
Comparing this equation to [tex]p^3 - c p - K = 0[/tex], we can instantly see that
[tex] v = \frac {K} {\epsilon_+ \epsilon_-}[/tex]
So now we have all the roots and can factor the whole polynomial...
[tex] \int \frac {p dp} {-p \frac {(p^2 - c)^2} {K} + p^2 - c} =[/tex]
[tex] \int \frac {p dp} {(p+\sqrt{c})(p-\sqrt{c})(p-\epsilon_+)(p-\epsilon_-)(p-v)}[/tex]
Apply the method of partial fractions
[tex] \frac {1} {(p+\sqrt{c})(p-\sqrt{c})(p-\epsilon_+)(p-\epsilon_-)(p-v)} =[/tex]
[tex] \frac {a_1} {p+\sqrt{c}} + \frac {a_2} {p-\sqrt{c}} + \frac {a_3} {p-\epsilon_+} + \frac {a_4} {p-\epsilon_-} + \frac {a_5} {p-v}[/tex]
Therefore...
[tex] 1 = a_1 (p-\sqrt{c})(p-\epsilon_+)(p-\epsilon_-)(p-v) + a_2 (p+\sqrt{c})(p-\epsilon_+)(p-\epsilon_-)(p-v) [/tex]
[tex] + a_3 (p+\sqrt{c})(p-\sqrt{c})(p-\epsilon_-)(p-v) + a_4 (p+\sqrt{c})(p-\sqrt{c})(p-\epsilon_+)(p-v) +[/tex]
[tex] a_5 (p+\sqrt{c})(p-\sqrt{c})(p-\epsilon_+)(p-\epsilon_-)[/tex]
Now [tex]a_1[/tex], [tex]a_2[/tex], [tex]a_3[/tex], [tex]a_4[/tex] and [tex]a_5[/tex] are constants and are chosen so that the equation above is satisfied...
So now we have transformed the differential equation into two doable integrals
[tex] \int p ( \frac {a_1} {p+\sqrt{c}} + \frac {a_2} {p-\sqrt{c}} + \frac {a_3} {p-\epsilon_+} + \frac {a_4} {p-\epsilon_-} + \frac {a_5} {p-v} ) dp = \int \frac {dt} { 2 t }[/tex]
After these integrals have been evaluated you can substitute [tex]p = \sqrt{ \frac {K t} {r} + c }[/tex] back into the equation, solve for r thus solving the differential equation.
MathNerd,
You are quite kind to make that effort. Time may tell me whether your derivation is correct.
Bravo for your elegant solution, MathNerd. Excuse my ignorance, but is my original equation at the end of the day exactly solvable analytically between r and t?
I invite you to see "Booda's Theorem" on my website, http://www.quantumdream.net. The above problem derives from the mathematics of "Relativity's Complex Probability" on that page.
Well yes, the procedure I employed above does give an analytic solution. But the function r of t is not single-valued for any given t. This stems from the non-linearity of the differential equation.
Loren equation...
non-differential solution retracted...
[/color]
Orion that is NOT a solution to the differential equation, the equation still includes [tex]\frac {dr} {dt}[/tex]! Also since [tex]c[/tex] is an arbitrary constant then [tex]c^2 \rightarrow c[/tex] without any loss of generality.
MathNerd
since c is an arbitrary constant then c2-->c without any loss of generality
Agreed (whether I understand the derivation entirely or not).
Orion,
please try completing your approach (which I believe to be equivalent to MathNerd's) while I endeavor to study TEX.
incorrect solution retracted...
Orion that still isn’t a solution to the differential equation!
Your (incorrect) solution is
[tex]r(t) = \frac{t}{ Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} }[/tex]
From this we have
[tex]\frac {dr} {dt} = \frac {1} { Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} } - \frac{-2 C K t^2 e^ \frac{-Kt^2}{}} { ( Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} )^2 }[/tex]
Now the differential equation how you wrote it is
[tex]r = \frac{Kt} { ( \frac{dr}{dt} )^2 - c^2}[/tex]
So this says that
[tex]r ( \frac{dr}{dt} )^2 = Kt + c^2 r[/tex]
but from your (incorrect) solution we can see that
[tex]t ( \frac {1} { ( Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} )^{\frac {3} {2} } } - \frac{-2 C K t^2 e^ \frac{-Kt^2}{}} { ( Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} )^{\frac {5} {2} } } )^2[/tex]
Is not equal to
[tex]Kt + \frac{c^2 t}{ Ce^ \frac{-Kt^2}{} - \frac{c^2}{K} }[/tex]
Therefore your solution doesn't satisfy the differential equation and is subsequently incorrect!
MathNerd,
Would you define "single-valued" as you used it in reference to nonlinearity?
MathNerd,
What I meant by the function r not being single-valued in general for any t means that for any given value of t there are multiple values of r that satisfy the equation between r and t.
e.g. let the function [tex]f(x)[/tex] and the parameter [tex]x[/tex] satisfy the following equation
[tex](f(x))^2 + 2 x^2 f(x) - \frac {4} {x} = 0[/tex]
Now we would say that [tex]f(x)[/tex] is not single-valued in general for any given [tex]x[/tex] because for a given value of [tex]x[/tex] there are two values of [tex]f(x)[/tex] that can satisfy the equation between them.
[/color]
Originally posted by Orion1
[tex]r = \frac{Kt} { \left( \frac{dr}{dt} \right)^2 - c^2}[/tex]
[tex]\left( \frac{dr}{dt} \right)^2 - c^2 = \frac {K t}{r}[/tex]
[tex]\left( \frac{dr}{dt} \right)^2 = \frac{Kt}{r} + c^2[/tex]
[tex]\frac{dr}{dt} = \sqrt{ c^2 + \frac{Kt}{r}}[/tex]
[tex]dr = \int \sqrt{ c^2 + \frac{Kt}{r}} dt[/tex]
differential solution:
[tex]r(t) = \frac{2r \left( c^2 + \frac{Kt}{r} \right)^{3/2}}{3K} + C[/tex]
That is also INCORRECT!
[tex]\int \sqrt{ c^2 + \frac{Kt}{r(t)}} dt[/tex]
is NOT equal to
[tex]\frac{2r(t) \left( c^2 + \frac{Kt}{r(t)} \right)^{3/2}}{3K}[/tex]
because if you differentiate [tex]\frac{2r(t) \left( c^2 + \frac{Kt}{r(t)} \right)^{3/2}}{3K}[/tex] with respect to [tex]t[/tex] then
[tex]\sqrt{ c^2 + \frac{Kt}{r(t)}}[/tex] is not recovered (I believe your problem came from not recognizing [tex]r[/tex] as a function of [tex]t[/tex])
If your (incorrect) solution is [tex]r(t) = \frac{2r \left( c^2 + \frac{Kt}{r} \right)^{3/2}}{3K} + C[/tex]
It is easily seen that
[tex]\frac {dr} {dt} = \frac{2 \frac {dr}{dt} ( c^2 + \frac{Kt}{r})^{3/2}}{3K} + \frac{r ( c^2 + \frac{Kt}{r})^{1/2} (\frac{K}{r} - \frac{Kt}{r^2} \frac {dr} {dt})}{K}[/tex]
and then it is easily seen that this does NOT satisfy
[tex]r ( \frac {dr} {dt} )^2 = K t + c^2 r[/tex]
You could keep posting incorrect solutions all day just to have them refuted by me. It would serve in every ones best interest if you read a book on differential equations before you try to solve the problem again.
Differential Solution...
[tex]r(t) = \frac{Kt} { \left( \frac{dr}{dt} \right)^2 - c^2}[/tex]
[tex]\left( \frac{dr}{dt} \right)^2 - c^2 = \frac {K t}{r(t)}[/tex]
[tex]\left( \frac{dr}{dt} \right)^2 = \frac{Kt}{r(t)} + c^2[/tex]
[tex]\frac{dr}{dt} = \sqrt{ c^2 + \frac{Kt}{r(t)}}[/tex]
[tex]dr = \int \sqrt{ c^2 + \frac{Kt}{r(t)}} dt[/tex]
[tex]r(t) = t \sqrt{ c^2 + \frac{Kt}{r(t)}} + C[/tex]
[/color]
no other known solutions exist.
[/color]
[tex]r(t) \left( \frac{dr}{dt} \right)^2 = Kt + c^2 r(t)[/tex]
[tex]r(t) \left( \frac{dr}{dt} \right)^2 = Kt + c^2 \left( t \sqrt{ c^2 + \frac{Kt}{r(t)}} + C \right)[/tex]
[/color]
I wish I put that after my solution. At least that way I wouldn’t have to keep on refuting your incorrect solutions.
[/color]
That is NOT what the integral equals, that integral with respect to [tex]t[/tex] which includes a function of [tex]t[/tex] is impossible to do. You have to separate [tex]t[/tex] with the [tex]dt[/tex] and [tex]r(t)[/tex] with the [tex]dr[/tex], which is known as separation of variables, to have any chance in solving this differential equation.
And I am wondering if you can't recognize that the first equation, the one that the correct solution satisfies, is VERRRRRY different than the equation your solution satisfies.
Therefore your solutions are ALL INCORRECT.
Integral solution...
MathNerd Theorem:
Integral:
[tex]\int \frac{dt}{2t} = \frac{log(t)}{2} + C[/tex]
semi-differential solution:
[tex]\frac{log(t)}{2} + C = \int p ( \frac {a_1} {p+\sqrt{c}} + \frac {a_2} {p-\sqrt{c}} + \frac {a_3} {p-\epsilon_+} + \frac {a_4} {p-\epsilon_-} + \frac {a_5} {p-v} ) dp[/tex]
MathNerd Theorem:
Integral:
Now you're getting somewhere!
The [tex]p[/tex] integral can be done by using integration by parts, it is trivial though so I won't do it here. You aren't going to get a simple solution in terms of [tex]r(t)[/tex] I suggest you make [tex]t[/tex] the dependent variable and [tex]r[/tex] the independent variable and have the function [tex]t(r)[/tex]. At least then [tex]t(r)[/tex] will be single valued!
3 different solutions
Hi, everybody;
My Maple 9 gave me 3 different solutions (obviously they are connected to each other) for the original equation. Here they are. I think, everything is clear. I beleive, the integrals can be evaluated under some conditions for K and c, e.g.: K=3, c=2, or K=c^2 or K=3*c (all of them are just the examples, not the real conditions leading to explicit solutions for r(t) or t(r)).
Best of luck,
Max.
solutions from Maxima
Hi again;
Maxima gives us the following solutions: MaxSol1and2.gif.
I think that the simplest variants of solutions are those for K=2 and c=sqrt(3)=3^(1/2) (I assume that K>0 and c>0): MaxSol3.gif and MaxSol4.gif.
Good luck,
Max.
P.S. Use Maxima http://maxima.sourceforge.net/download.shtml - it's free, open source and effective for the problems like this one.
  • · Replies 23 ·
  • · Replies 19 ·
